TL;DR: Leave stove fuel and bear spray out of both bags when flying through U.S. screening. Keep spare lithium batteries and power banks in your carry-on, and put ordinary knives and sharp-tipped hiking poles in checked baggage. Pack a stove only if it meets the fuel-free condition and your airline accepts it.
- 1. Sort the gear by what happens at the airport
- 2. Can I bring backpacking gear as a carry-on when flying?
- 3. Keep spare lithium batteries in the cabin
- 4. Decide which light you need when you land
- 5. Leave stove fuels and bear spray out of both bags
- 6. Follow the sharp-item and pole rules for your exact gear
- 7. Does a 35L backpack count as a carry-on?
- 8. Is a 50L backpack allowed in a flight?
- 9. Walk through the itinerary before departure
- 10. Frequently asked questions
Set out three groups before you load the pack. Put spare lithium batteries and power banks in the cabin group. Set aside gear that needs checked baggage, such as an ordinary knife. Make a third group for things to obtain at the destination. A fuel canister belongs in that third group even if the rest of the kitchen kit is going to the airport.
| Item | Where it goes | What to do |
| Spare lithium batteries and power banks | Cabin only, within limits | Protect each spare from short circuits |
| Headlamp with a battery installed | Cabin preferred. Checking it is conditional | Check the airline rules and protect it from activation |
| Backpacking stove | Either bag, if the conditions are met | Confirm it is free of fuel, residue, and vapors and the airline accepts it |
| Camp stove fuel | Neither bag | Arrange it at the destination |
| Bear spray | Neither bag | Arrange it locally where permitted |
| Ordinary knife or multitool with a blade | Checked only under U.S. screening rules | Protect the sharp edge and check destination rules |
| Hiking poles | Checked. Blunt tips may qualify for carry-on | Check the tip type and carrier policy |
Start with the items that would disrupt the first day if they went missing. Trail lighting, warm clothing, required medication, and navigation may need to be available when you arrive. Place the light where you can find it without emptying the whole bag. A second pouch for the stove and other kitchen equipment makes it easy to leave that kit behind if you decide to rent it instead.
Work through the list by trip segment. Ask what each item needs at your departure airport, on your flight, and after you land. A canister you can use at a campground cannot travel there in passenger baggage. A light that the airline accepts may still need protection from being turned on by a buckle or zipper. A knife that can go in a checked bag may still be subject to different rules after arrival.
Think through the return trip before packing for the outbound flight. Your stove may be unused when you leave home and have been used over the weekend when you fly back. You might also have part of a fuel canister left after the last meal. Plan a legitimate local return or disposal option early. This is easier than trying to solve the problem on the way to the airport.
Yes. Many hiking clothes, ordinary trail supplies, and lights can travel in the cabin if the bag meets your airline’s limits. Sort the contents one item at a time. A backpack that fits in the overhead bin can still contain gear that belongs in checked baggage or needs to stay out of both bags.
Start with the packed bag rather than the promise on the product tag. An empty hiking pack is easy to compress. Add a sleeping bag, a rigid frame, a tent pole bag, or clothing lashed outside and its shape changes. Check the packed dimensions and account for buckles, straps, and anything else that extends past the fabric. The airline’s size rules apply to what you are actually bringing.
Think about the smallest bag you could keep with you if the larger pack had to go in the hold. A removable pouch for the spare batteries can live near the top of the pack. Make room for it in the personal item your fare allows. Before handing over the bag, take that pouch out and keep it in the cabin. The time to check which pocket it is in is at home.
Cabin-only travel works better when you decide which trail functions need a replacement at the destination. If the trip assumes cooking, price and check local stove rental or fuel supply before you settle on your flight and arrival time. A backpacking trip can begin late in the day, and an available shop on paper may be closed when you get there. Have a first meal that works with the itinerary you can actually confirm.
Consider what the trip really asks of a tool. A checked knife may be useful on some trips, while a short trip with prepared meals might need a different kitchen setup altogether. Changing the gear list is often simpler than adding a checked bag that also needs to follow the rules at every airport. Put the method you intend to use on your trail list, then make your baggage choices from that list.
The FAA PackSafe chart treats installed equipment, loose batteries, and power banks as different cases. In the ordinary U.S. passenger baggage rules, spare lithium batteries and power banks go in the cabin, protected from damage and short circuits. The standard limit for lithium-ion batteries is 100 watt-hours per battery. The FAA describes a narrow airline-approval exception for up to two larger spare lithium-ion batteries rated above 100 and up to 160 watt-hours.
Do a physical battery count. There may be a cell inside the headlamp, a spare in a repair pouch, and a power bank clipped inside a pocket. The spare in the repair pouch is still a loose battery. A power bank stays a spare battery for packing purposes even when you think of it as part of your phone kit. The cabin pouch needs space for all of those pieces.
Protect the contacts before you pack. Use the original retail packaging where it still protects the battery, a properly fitting protective case, or another method accepted by the airline and the applicable rules. Keep loose cells away from keys, coins, and metal tools. There is little benefit to buying a tidy battery organizer if several contacts can still meet a metal zipper pull inside it.
An installed device and a spare also need different packing decisions when you check a bag. If a carrier accepts a device with its battery installed in checked baggage, follow the applicable instructions for keeping it fully off and protected from activation and damage. A light that is easy to switch on through a soft pocket deserves separate attention. For a practical companion on installed lights, spare cells, and lockout, see Olight’s guide to travel flashlights and airline battery rules.
Look for the watt-hour rating on the actual battery or the manufacturer’s documentation for that pack. When the label gives volts and milliamp-hours for the same battery rating, divide milliamp-hours by one thousand and multiply by volts. A 3.6-volt cell rated at 5,000 milliamp-hours is 18 watt-hours. That arithmetic explains the rating. An airline can still have additional conditions about the item, its condition, and how you carry it.
Small household-style cells deserve the same attention to chemistry. An AA label describes a size. It does not tell you whether the battery is alkaline or rechargeable lithium-ion. Check each package and apply its actual rules instead of giving every cell in the organizer the same treatment. A rechargeable AA spare identified as lithium-ion goes with the lithium spares in the cabin under the FAA guidance.
If the label is unreadable or the battery has been damaged, resolve that at home. A battery you cannot identify can turn a quick check-in into a complicated conversation. A damaged or recalled battery that may generate dangerous heat or sparks is a separate safety issue. Follow the manufacturer’s and airline’s instructions. Replace suspect equipment before the trip if you cannot establish it is safe and allowed.
A little organization can help at the gate. Put the power bank and protected spare cells in a pouch you can lift out together, then keep the light easy to reach. If your backpack goes down the jet bridge as checked baggage, your cabin kit should come out in one step. Take a look inside before handing over the bag. It is easy to retrieve the power bank and overlook a second battery sewn into a sleeve.
Choose a primary light for the first real task after landing. A late shuttle drop-off, a dark walk to a campground entrance, and reading an address on the side of a building all reward a light you can reach quickly. A headlamp is useful when one hand has the pack and the other needs to handle a zipper, a key, or a transit pass. Keep it where you can take it out while standing.
For a multi-day route, consider the difference between a backup that uses the same cell and a backup that uses a different system. The first keeps the set of spares simple if the equipment is compatible. The second can give you a light when a primary charger or charging lead stops working. Count both battery types as you pack. The right choice depends on what you can realistically replace between the airport and the trail.
Try the setup before the trip. Put the main light in the pocket you intend to use, close the pocket, and wear the loaded pack. See whether you can reach and operate the light easily after a few minutes of walking. If the location is awkward, move it. Access tends to matter more when you are finding a destination with your hands already full. Olight’s headlamps cover different sizes and carrying styles for hands-free tasks.
Pack for the most likely arrival situation instead of the longest possible hike. If a delay puts you on the ground near sunset, a main light and a simple backup are easier to use than several lights buried together under a sleeping bag. Decide what you will have if the checked bag takes a later flight. If the group also brings a shared camping lantern, assign someone to check its battery and packing requirements.
Stove fuel belongs in your destination plan. The FAA chart lists compressed gas fuel, liquid camp fuel, and solid camp fuel tabs as prohibited in both carry-on and checked baggage. Putting a cap on a fuel container or moving it into the checked pack changes its location. The same fuel restriction still applies. Think about fuel and the piece of equipment that uses it as two distinct packing decisions.
The TSA guidance for camp stoves allows the stove in either baggage type only when the item is entirely empty of fuel and cleaned to remove all residual vapors and residue. Airlines can have tighter policies for used gear. If you are taking a stove that has already been used, check your carrier directly before packing it. The condition of the equipment on the way home may be different from its condition when you left.
Build the fuel stop around the real campsite logistics. Confirm which fuel type matches your stove, whether the destination has it, and what time you can collect it. Leave room for a backup plan that works if the shop closes or the ride arrives late. A meal you can eat without the stove can cover arrival night. For a trip that depends on hot meals, a local rental or an agreed pickup may be worth arranging.
Treat bear spray as a separate item. The TSA entry for bear spray lists it as prohibited in both baggage types. A different listing for a different category of spray does not determine whether a bear-spray canister can fly. Check the land manager’s current requirements, obtain the item locally if it is permitted and needed, and plan a legitimate way to return or dispose of it before your flight home.
Consider both the start and the finish of the route. If you fly out of a different airport, a rental picked up at the first end may need an agreed return at the other end. Get that question answered before the trip. The same goes for a fuel container after the last night. Ask the rental provider, outfitter, or land manager about local options rather than assuming the airport can be your place to handle leftover material.
If your route crosses several jurisdictions, look up each land manager’s rules separately. Whether a spray can travel through an airport is a different question from whether you may possess or use it in a particular park. Arrange your plans around the place you will hike. Contact the actual destination rather than relying on a story about what a traveler did in another park several years earlier.
An ordinary knife belongs in checked baggage under U.S. screening rules. Secure the cutting edge according to the rules and check any destination restrictions that apply to the item. The TSA guidance for multitools also puts models with knives into checked baggage, irrespective of the blade length. A model’s folding mechanism or pocket size does not settle the cabin question.
Check the tool you actually own. Two models under one product family can contain different components. If you usually call it a repair tool, look at the actual tools before packing it. Move it to the checked group when its contents require that, or select a lawful alternative or local repair option. Do this at home so you can still choose what the trip needs without rushing at the checkpoint.
Check the walking poles on their own. The current TSA Hiking Poles entry distinguishes blunt-tipped poles, which may be carried on or checked, from sharp-tipped poles, which cannot go in carry-on. The entry also directs travelers to their airline about carry-on poles. Think about both the tip and the packed length before you choose a bag. TSA officers make the final checkpoint decision for the item presented.
Poles attached to the outside of a backpack can also change the dimensions your carrier will measure. Look at the pack from the front and side with the poles in their actual travel position. If the pole has moved the farthest point of the bag beyond the stated allowance, you need a different packing arrangement or a confirmed checked option. The pack’s capacity label cannot answer that question for you.
If your poles need to be checked and you are trying to travel cabin-only, consider whether trained local staff can advise you about rentals. Check whether the rental is available at the trail end you can actually reach. It may make more sense to use a verified local option for a weekend than to count on an item being accepted at a checkpoint or at the gate in a bag that is already full.
A 35-liter backpack may qualify if the packed exterior fits your airline’s carry-on dimensions and your ticket includes that bag. Measure the frame, straps, and any gear you will leave attached. Check the operating airline for each flight, especially on a small aircraft or a route booked through a different carrier.
Put in the gear you normally carry before you measure. An empty pack may lie down flat while a frame and a full front pocket make the loaded pack substantially deeper. Look at the airline’s maximum dimensions and measure the longest point in each direction. If the bag fits when you press on it but expands again immediately, reconsider what you keep on the outside.
Airline allowances have separate gates. Your ticket may include one cabin bag and one smaller personal item, only a personal item, or different benefits on different legs. A backpack that meets the dimensions for a regular carry-on may still be too large to be the included personal item. Build the packing plan from the actual booking details for each segment.
A 50-liter pack can often travel as checked baggage if it meets the carrier’s size, weight, and packing rules. Whether it can travel in the cabin depends on the loaded dimensions and your ticket. Check the operating airline and be ready for a gate check even if your measurements fit its published rules.
A large pack usually takes more effort to keep neat during handling. Secure loose straps and protect fragile gear using a carrier-accepted packing arrangement. Make sure the tag will stay attached and that you can identify the bag. If the bag must be dropped a long walk from the gate, your battery pouch and travel essentials need to be out before the big pack leaves your possession.
The frame may matter more than the soft upper extension. You can remove a jacket from a top pocket, but a fixed frame that is larger than the stated allowance still has the same dimensions. Measure the rigid parts first. If they determine that you need a checked bag, pack the cabin item as a useful kit of its own. That avoids hurried sorting at the airport.
Imagine an evening flight to a one-night campsite. Put the headlamp and spare lithium pouch in the cabin item, along with the layer you need as soon as you get out of the shuttle. Check the spot where you will meet your ride and the time a fuel shop closes. If you cannot confirm the shop will be open, have a first-night meal that does not depend on it. That small decision can keep a late departure from setting the tone for the whole trip.
For a longer route with a checked pack, make a short list of the things you cannot use until the bag arrives. Keep whatever essentials the carrier lets you keep in your cabin bag. When the return trip starts after the hike, reorganize the same three groups. Collect the battery spares into the cabin pouch, settle local fuel and spray disposal or return, and check whether the used stove still meets the carrier’s acceptance conditions.
For an international itinerary, verify each airport and operating airline for the relevant leg. A transfer may involve a second security check or a different carrier. Check whether destination and transit rules change what you can bring in, even when the item cleared the first checkpoint. Build the gear list around the conditions you can establish for the whole route. Contact the carrier directly about anything you cannot classify from the current official sources.
Keep a short note of your household battery types and where you put each one. At home, open the bag and run the cabin-check exercise once. Pull out the power bank, protected cells, and arrival light without digging out your clothing. If you find a battery in the bottom of the pack after you have closed it, move it now. This is easier than trying to remember all the small pockets under time pressure.
Check the ground side again the day before departure. The camp office, a shuttle company, or a rental shop may adjust its hours. Verify who can actually hand over the item, what you need to reserve, and how you will return it. Once the destination plan is in place, prohibited gear can stay out of both bags from the start.
- November 19, 2026 Updated the U.S. airport packing guidance and verified the battery examples against current U.S. Olight product information and the Perun 3 manual.
