Our Baton 4 Premium includes a powered charging case for storing and recharging the flashlight, with a digital display button that also controls a seated Baton 4 under the manual's stated conditions. Our current US compatibility list separates fully compatible models from models supported for storing and charging. Choose the case around the exact light, the required case functions and the power source you will have available.
- 1. Start with the Exact Baton 4 Charging Case and Light
- 2. Which Lights Work With the Baton 4 Charging Case?
- 3. Compare the Standard and Premium Package Contents
- 4. Locate the Case Display Button Before Using Its Controls
- 5. Adjust a Seated Baton 4 Through the Case
- 6. Understand the Lid-Close Shutoff by Model
- 7. Follow the Flashlight Charging Indicator Through Completion
- 8. How Do You Charge the Baton 4 Case, and How Long Does It Take?
- 9. Use the USB-C Port for Mobile-Device Power Deliberately
- 10. Keep Battery Capacity and Published Runtime in Context
- 11. Pack the Complete Case Arrangement for Its Assigned User
- 12. FAQ
Our Baton 4 page offers Standard and Premium configurations. The charging case belongs to the Premium equipment arrangement. Before comparing a color or package, identify whether the selection contains the flashlight alone with its listed accessories or the flashlight and charging case together. A shared product page can contain several different selections.
Write down the complete name of the light you intend to put in the case. Baton 4, Baton 3 and similarly named lights belong to specific models, with their own instructions. The words Baton, Mini or Premium by themselves do not identify the complete device. Use the product label and the selected package description when preparing an order or sorting equipment already at home.
The same care helps when a case changes hands. One person may remember the package name while another recognizes only the small flashlight. Keep the model identification with the equipment until both people understand which parts belong together. A photograph of your own product label or a saved order description can provide a practical reference when you later look up its instructions.
Start with the required job as well. You might want a charged light ready for short household checks, a case that returns to a desk between uses or a travel arrangement that also carries a USB-C cable. These plans involve the same product in different routines. Decide which components will actually travel and which will remain beside the charging source.
Our current US description lists Baton 4, Baton 3 and Perun 3 Mini as fully compatible with the case. It separately lists S1R II, Perun Mini and Perun 2 Mini as supported for storing and charging. These two descriptions provide the starting point for a useful compatibility check. Preserve the exact model spelling, including the generation number.
The Baton 4 Premium manual explains the case's own operation with Baton 4 and names limitations for some older supported lights. Its lid-close shutoff and case-controlled stepless dimming instructions specifically exclude S1R II, Perun Mini and Perun 2 Mini. A light can therefore have a documented place in the storage-and-charging group while requiring different expectations about those other functions.
| Light named in our current US description | Published compatibility wording | How to use that information |
| Baton 4, Baton 3, Perun 3 Mini | Fully compatible | Keep the exact model's instructions alongside the case instructions |
| S1R II, Perun Mini, Perun 2 Mini | Supports storing and charging | The Premium manual excludes these models from lid-close shutoff and case-controlled stepless dimming |
When reviewing an older manual, keep its publication scope visible. Our current product description names Perun 3 Mini in the fully compatible group, while the Premium manual's illustrated operating examples center on Baton 4. Use the current compatibility listing to identify the supported model and its own instructions to understand that light. This guide's detailed case-control examples use Baton 4 throughout.
The six model names describe a compatibility list. Plan around the particular physical light you place in the case and the task it will serve. If several people own different supported models, make the assigned light clear before somebody takes the case away. That small identification step prevents a shared accessory from becoming an unclear promise that every light will receive every function.
Our published package list gives Baton 4 Standard a flashlight with its battery and pocket clip, an MCC 1A magnetic charging cable, a pouch and a user manual. Premium includes the flashlight with its battery and pocket clip, plus the Baton 4 charging case. Its listed accessories are a lanyard, a USB-C charging cable, a cleaning cloth and a user manual. Compare those lists with what you already own.
The charging route changes the small items that need a place in your bag. Someone using the Standard arrangement may keep the supplied MCC 1A cable with a suitable power source. Someone choosing Premium may instead organize the case and its USB-C cable as the main arrangement. Identify the actual package before assuming the cable from one selection also appears in another.
Consider an existing-light owner separately from a first-time buyer. An existing owner needs to confirm the light's exact identity, the case compatibility wording and what the selected purchase supplies. A first-time buyer needs a complete list of the light, case and charging accessories in that package. Both can use the same checklist, but the missing item may be different.
The case's digital display button has both an information role and a control role. The Premium manual says the case battery level appears when you press that button or open or close the lid. During charging of the case, the lightning symbol on the button blinks, then remains continuously lit when charging is complete. Identify which symbol and component you are reading.
For the illustrated Baton 4 arrangement, place the compatible light in its charging position with the lid open before using the case-control instructions. A press of the case display button turns the flashlight on or off. The manual says normal activation returns to the memorized brightness with its stated memory qualifications. Aim the open light at a suitable working surface before operating the button.
Keep the two physical controls distinct during a handover. The flashlight has its own button, while the case has the display button described in these instructions. Name the control before demonstrating the ordinary action. A reminder saying only press the button can leave the recipient looking at a different part of the equipment from the one you intended.
Use the case display to answer the question it actually addresses. A percentage shown on the case concerns the case's remaining power. The internal charging indicator reports the flashlight's charging process. Looking at those indicators separately gives you a clearer preparation check than remembering that one light or display was visible somewhere in the open case.
The Premium manual describes a separate brightness adjustment for Baton 4 while it is on in the charger. Press and hold the case display button to change brightness smoothly. Keep the light-on condition and the identity of the display button with that instruction. A held action in this state serves a different purpose from the ordinary single press used for on and off.
The manual also gives an off-state Moonlight entry through the case. With Baton 4 off in the charger, press and hold the case display button for at least one second to activate Moonlight. Review that starting condition before using the action. A short reminder can name the seated light, its off state, the display button and the required hold together.
The manual permits the flashlight to stay lit during charging with the lid open. Our product description also presents lighting and charging together in the hand. This can serve a short inspection when you are already holding the open case. Account for that occupied hand when deciding whether the task calls for this arrangement or a separately prepared hands-free light.
For a nearby label or instruction sheet, select a level that makes the information easy to distinguish. Watch the item and its surrounding reflections while making the ordinary adjustment. Keep the open case in an arrangement where the light is aimed usefully and the control remains reachable. Choose a handheld arrangement when carrying the open case would make the task awkward.
Our flashlight modes guide explains the broader differences between working levels and special modes. For this case, the practical preparation is more specific. Learn the normal display-button action and the appropriate starting state, then use the exact Baton 4 instructions for any additional function you need.
The Premium manual says an illuminating Baton 4 or Baton 3 in the charger automatically turns off when the lid closes. It also asks users to keep the flashlight tail and charging port clean. These details belong together when you prepare a close-and-carry routine. Check the relevant model and the contact area as part of returning the equipment to its case.
The same manual expressly excludes S1R II, Perun Mini and Perun 2 Mini from that lid-close feature. Keep their storage-and-charging compatibility separate from the Baton 4 and Baton 3 shutoff example. When preparing one of those older supported lights, use its own off command and confirm its state before packing it according to the instructions.
A useful shared-household routine makes the return action easy to understand. The person finishing a short inspection should know where the light belongs, which model they have and which off instruction applies. The next person should be able to retrieve the intended light without first sorting several similar devices. Agree on that return location before the case becomes a general container for loose equipment.
Include the lid and opening space in the place you choose for the case. A shelf that accommodates the closed dimensions may give you less room to open the case and reach the display button. Check those ordinary movements with the actual equipment. Leave the operating light and the lid clear of nearby stored items while you use the open arrangement.
The case has an internal indicator for charging the flashlight. The manual describes red during charging, followed by green when charging is complete, before the indicator turns off. Read that complete sequence when deciding whether the light has finished charging. A later unlit indicator can occur after the documented completion sequence, so include what happened before it went dark in your observation.
The case display has another stated behavior at low remaining power. If the charger battery level falls below ten percent while charging the flashlight, the remaining level stays displayed. That information can help identify which component needs attention before the next outing. Check the case's supply as well as the light you expect it to replenish.
Prepare a sequence that fits your normal return home. Put the light in its designated charging position, identify the appropriate indicator and leave the instructions available for a question about its response. If the sequence differs from your expectation, record the light model, case state, connected equipment and displayed information. Those details make a support question easier to explain accurately.
Use the supplied care guidance for the actual components. Keep the flashlight tail and case charging contact clean as the manual instructs, and give loose small items their own storage place. Avoid turning the case compartment into a place for unrelated hardware. This makes it easier to inspect the charging position and return the correct light without mixing it with other equipment.
Charge the Baton 4 case through its USB-C input using a suitable power source. The Premium manual lists an input of up to 5 volts and 2 amps. Its charging-time reference is 2.5 hours using a 5-volt, 2-amp, 10-watt power source. The manual adds that charging takes longer when the source capacity is insufficient. Keep that requirement with the time when arranging a recharge between uses.
Identify the cable, source and available charging period together. A cable stored in the correct bag is only one part of that arrangement. You also need the appropriate source and enough opportunity to complete the planned recharge. Our flashlight charging and care guide covers the wider task of keeping model-specific charging components organized.
The manual separately lists one hour for charging Baton 4 from the case. Treat the case recharge and the flashlight recharge as two different entries in your plan. Someone arriving home with a depleted case and light has a different preparation task from someone topping up the light from an already prepared case. Read the condition of each component before deciding what needs charging.
Choose a location where you can identify the display and keep the equipment organized according to its handling instructions. Restore the cable to the place where the next user expects it once the charging task is finished. If the case travels while the source remains at home, record that division when packing. The presence of the case alone does not describe every part of the next recharge opportunity.
Our current US page says the case can charge mobile devices through its USB-C port. The Premium manual lists a USB-C output of up to 5 volts and 2.4 amps. It describes activation and charging when the external device is connected, with remaining case power displayed. Prepare the appropriate cable for the receiving device and review that device's charging requirements as well.
Decide which use of the stored energy has priority during the outing. A case reserved for replenishing the flashlight has a different assignment from one also used for a phone. Make that choice before somebody relies on it as the light's planned reserve. If phone power is a separate essential need, account for that need explicitly in the equipment plan.
The manual includes a specific note for a device with a Lightning port. After that device has been disconnected for one minute, the charger automatically sleeps, and pressing the case display button reactivates it. Keep this note with the stated device condition when referring to it. Use the receiving device's own instructions for questions about its port or charging behavior.
When the case has served an external device, review its remaining power before returning it to the flashlight arrangement. Tell the person responsible for the light that the shared energy has been used. A visible percentage and a clear handover are more informative than leaving the case in the usual pocket and assuming the next person knows which task it just performed.
The case's specification lists a 5,000 mAh battery at 3.6 volts, or 18 watt-hours. It separately lists a rated capacity of 2,650 mAh under its stated 5-volt, 2.4-amp conditions. Keep the associated voltage and rating condition with each number. These entries describe different parts of the power specification and should remain identifiable when you compare equipment.
Our product description says the case can fully charge Baton 4 five times. Keep that claim attached to Baton 4, the named flashlight in the description. The case also supports other listed models, but each has its own battery and operating instructions. Use the applicable model's information when planning its charging arrangement instead of transferring a recharge count solely from the shared case name.
Baton 4's own published modes also have distinct durations. Medium is listed at 60 lumens for eight hours, while Low is 12 lumens for 35 hours. Choose the mode for the information or area you need to see, then plan around that mode's entry. A maximum-runtime headline answers a different planning question from the duration of your chosen working level.
For a brief higher-output task, read the full Turbo sequence. Our specifications list 1,300 lumens for 1.5 minutes, followed by 600 lumens for 2.5 minutes and 300 lumens for 73 minutes. Keep those stages attached to the flashlight's operating entry when comparing the package. The charging case adds a way to replenish its stored power between uses. Its presence does not turn the opening output into a constant level throughout the published sequence.
Keep mobile-device power, flashlight recharge opportunities and the light's runtime on separate lines in a packing note. This helps a household assign the case's energy without turning a battery-capacity number into a promise about a particular phone or every compatible flashlight. The useful record identifies the actual device, its intended task and the next opportunity to restore the equipment.
The manual lists the case at 142 grams, with dimensions of 65 by 32 by 88 mm. It lists Baton 4 at 52.5 grams including its battery. Keep the component names with those weights when comparing what you will carry. Allow room for the actual cable and any other package accessories you choose to take. Our flashlight holster vs charging case comparison explains how a fixed charging holder and a portable powered case fit different carry arrangements.
Keep protection ratings with their named component too. The Premium manual's Baton 4 specification table lists IPX8 for the flashlight. Choose the storage place for the case and its cable using their own handling guidance and the conditions around the bag. Inspect the complete arrangement when returning from an outing before putting it back into its ordinary charging location.
For one user, assign a clear return position in a bag or at home. For a household with several lights, identify which compatible model normally travels in the case and which person restores its charge. Give other lights their own carrying and charging arrangements. A compatibility list helps you choose a model, while the household routine determines which device will actually be available to the next person.
