Imagine you're in a conversation, but your phone dies! Or, you are driving and you are about to reach your destination, but your car breaks down! Now, imagine you are working or walking in the dark, but your light source is gone! The first two instances might just be an inconvenience, but the last one might be more of a hassle.
Having lights you can trust is essential for everyday activities. From long hikes in the woods to repair work on the factory floor, adding Olight lights to your gear will allow you to do more and go further.
High lumens, long runtime, and ease of use are all must-haves for picking an outdoor headlamp. We strongly recommend that you check out Olight Perun 2. Standout features that make the Olight Perun 2 headlamp ideal for running/adventure/camping/emergency situations include:
Maximum 2500 lumen output
Up to 12.5 days of runtime
Multifunctional: Provides headband as headlight and provides two-way pocket clips as EDC flashlight
Magnetic tail cap: Free your hands while working
Right Angle Lighting
Built-in proximity sensor
Incredible MCC3 cable with up to 2A charging current
IPX8 waterproof
Hunter's Night Lighting Companion
If you are an avid hunter, you are likely to walk into your blind spot or deep forest in the dark.
Olight Perun 2 emits up to 2500 lumens of light, enough to illuminate your surroundings. Illuminates up to 544 feet (166 meters), giving you a clear view of your surroundings.
This rechargeable LED headlamp is powered by a 4000mAh 21700 battery with up to 12.5 days of battery life. In addition to its impressive power, the Perun 2 can also be charged up to 2A via the incredible MCC3 cable. The Perun 2 can adjust the lumens between 5 and 2500 lumens depending on your needs, perfect for close lighting and long-distance viewing. What's more, it has SOS functionality for added protection on your hunting trips.
From your workplace to the campsite, Perun 2 rechargeable headlamp is a good helper
One of the rules of being outdoors is to always be ready. Sometimes it can be a challenge to find the right balance between carrying more than you need (because you want to be prepared for any situation) or carrying only what you need (because your gear weighs more). Perun 2's bright light and durable construction are also perfect for your workplace or campsite.
Made with ultra-thin optical lenses, Perun 2 emits a soft, balanced beam ideal for places where the perception of your surroundings is critical. Waterproof and dustproof, the high-performance Olight Perun 2 rechargeable LED flashlight can be used from a distance of 544 feet (166 meters). Projects up to 2500 lumens at impressive distances.
Olight offers headbands that can be used as headlights. A two-way pocket clip for everyday carry is also provided. You can easily put the Perun 2 on a backpack, belt, or MOLLE system. The Perun 2 Magnetic Back Cap lets you work your hands-free, making it an excellent source of hands-free lighting. Extremely portable, bright, and durable, the Perun 2 measures 4.75 inches long and weighs only 161 grams, packs a powerful punch in a compact design.
The best headlights for trail runners
One of the biggest benefits of trail running is that you can explore different terrains. Running early in the morning or late at night is another way to challenge yourself.
Another benefit of trail running is getting into the "zone," putting your doubts aside, and experiencing your physical abilities. While that's mostly a good thing, it's important to know that a good trail run can last long after sunset or throw you into bad weather.
What makes the Olight Perun 2 running headlight perfect for trail runners?
No matter what terrain or lighting conditions you're used to or what time of day you choose to run, the Perun 2 running headlight can help you run further. Some of the special features that make our headlights ideal for trail runners include:
Multiple lighting modes to meet changing lighting needs
long distance Lighting
Fitted headband
Durable Design
IPX8 waterproof
Running in low light conditions has unique challenges and advantages. Wearing a running headlight can help you meet challenges and enjoy your advantages even more. The Olight Perun 2 running headlight is designed to help you maintain a confident and relaxed pace on the track.
Even a job you love can become frustrating when you use inefficient lighting. If you find yourself encountering shadows and misdirected light on your job site, it may be time to make a change.
While every job may require a different type of light, you can never go wrong with a headlight. Not only will having one make your job easier, but it's also safer hands-free. Olight Perun 2 Rechargeable LED Torch is compact and easy to carry and offers different lighting modes. Whether you're looking for a dual-function torch, a torch that lets you switch between modes or the most portable torch, you'll find it in Olight's line of rechargeable LED torches.
