A strong rechargeable dual beam LED flashlight. Don't let its size fool you; the Olight Marauder Mini powerful led flashli still packs all the remarkable features of the original.
Following the Marauder 2 lens design composed of nine LEDs surrounding the centre, it permits 7 brightness that gives 100 lumen – 7000 lumen. A big round LED has been included to the center, providing a 600-meter spotlight beam.
3 RGB color LEDs are consistently distributed around the converging lens, making it perfect for use as a lightsaber when no one is watching.
The toggle switch in the center of the body permits fast access to pick either floodlight or spotlight modes, while the upper rotary knob adjusts brightness levels. Surrounding the rotary knob switch are indicators that show the battery level, brightness level, and 3 RGB light colors.
Run by a customized 24Wh 32650 rechargeable lithium battery, it provides extended runtime and is compatible with Olight MCC3 magnetic charging cable. Wrapped by 270-degree silicone, the flashlight body surface gives a more relaxed and stable grip.
Little in size but powered like a beast, the Marauder mini powerful led flashlight is a must have for hunters, rescue, search, and all outdoor lovers.
Features of Marauder Mini Powerful Led Flashlight
Little in Size, Yet Amazingly Strong
Marauder Mini powerful led flashlight, the miniature edition of Olight Marauder, has a 7000-lumen max output and a 43.5 hour maximum runtime, thanks to its custom 24Wh 32650 rechargeable lithium battery.
Dual Beam with Flood and Spot
A range of LEDs provides 2 strong beam choices: a 600 meter max throw from the central LEDs spotlight beam, and a 7,000 lumen output floodlight beam from the nine surrounding LEDs.
Improved Safety
Feature a built-in thermal sensor and chilling fins to help make sure safety by dissipating heat and sensing lens obstruction.
Uniformly Distributed RGB Color LEDs
Three RGB LEDs are uniformly distributed around the lens, amazingly increasing its usefulness on any open-air adventure. A silicone coated grip and hidden lanyard hole improve portability, daily use and carrying.
Intuitive toggle switch & Rotary knob switch
A simple toggle switch picks either flood or spot mode, and an intuitive rotary knob switch permits you to immediately pick from 7 different.
Advantages
Beam quality is amazing as usual, with Olight torches.
The Marauder mini powerful flashlight features a round spotlight beam that has reached up to 600m and a floodlight beam with a highest output of a whopping 7000 lumen.
Charging
Charging occurs through Olight signature magnetic charging cable – the magnet is powerful enough to simply attract the charging base by moving the tail of the torch near to the charging pad.
There is a standard USB on the other end that can be used with any portable battery or USB plug.
The magnetic pad on the cable has a charging light next to it that helps up red when charging green once completely charged and it takes five hours to completely charge the battery from flat.
Power Button & Modes
The marauder mini powerful led flashlight has a lot of functions and modes.
Body
The body has a textured pattern that provides an extremely firm grip – even if your hands are wet, you would not find the torch slipping.
Holster
The Marauder mini powerful led flashlight comes with a holster for simplicity of carry.
How to use the Marauder Mini Powerful Led Flashlight
The Marauder mini powerful led flashlight can be simply operated with a single hand. The toggle switch in the center of the body permits fast access to pick either flood light or spotlight, while the upper rotary knob is intuitive to adjust brightness levels.
Surrounding the rotary knob switch are indicators that show the battery level, brightness level, and 3 RGB light colours.
To use the flashlight, first ensure it is turned off by rotating the upper knob all the way to the left. Then press and grip the toggle switch in the heart of the body until it turns on.
To cycle through the various brightness levels, rotate the upper knob. The flashlight will stay on at whatever brightness level you last when you turn it off. To turn off the flashlight, press and grip the toggle switch again until it turns off.
Pros
⚫Smaller than the previous Marauder series flashlight, but strong and very functional.
⚫Round spotlight beam with a long throw from the central LED and 7000 lumen floodlight beam from nine surrounding LEDs.
⚫Green, red, and blue LEDs are uniformly distributed around the converging lens, for specialized uses such as map reading, blood tracing, etc.
⚫Built-in thermal sensor and chilling fins make sure safety in case of overheating and lens obstruction.
⚫Simple toggle the switch to pick either floodlight or spotlight and turn the intuitive rotary dial to active the light and circle via seven output levels.
⚫IPX8 waterproof rated and 1.5m impact resistant
Cons
⚫costly
FAQs
What are flashlight lumens?
Lumens is a measure of intensity of the light appearing from the flashlight, on the highest brightness setting. It may also be shown for multiple light settings. A high lumen output means that the flashlight glows bright.
How many lumens is a good flashlight?
The average flashlight emits about a 100 lumen. Anyway, the higher the lumens, the brighter the flashlight will be.
End words
The Marauder mini is a miniature version of Olight Marauder series of rechargeable flashlights, with 7 brightness levels and a highest output of 7000 lumens of white light, along with green, red, and blue light options. The toggle switch in the center of the body permits fast access to pick either flood light or spotlight, while the rotary dial adjusts brightness. Surrounding the rotary dial are indicators that show the battery level, brightness level, and 3 RGB light colors.
Smaller in size but still run like a beast, the Marauder mini powerful led flashlight is a must have for rescue & research professionals, outdoor lovers and all hunters.
