Olight is a well-known brand in the flashlight industry, offering a wide range of high-quality flashlights for a variety of applications. One of the most critical components of an Olight flashlight is its battery, which provides the power necessary to generate light. In this article, we will explore the batteries used in Olight flashlights and discuss their unique properties and benefits.
Olight Flashlight Batteries
Olight flashlights typically use two types of batteries: Lithium-ion (Li-ion) and Lithium-polymer (LiPo) batteries. Both types of batteries offer unique advantages and are suitable for different types of applications.
32650 rechargeable battery (6500mAh)
Battery capacity: 6500mAh
Compatible Model: Marauder mini
26650 3.7 V 4500 mAh battery.
Battery capacity: 4500mAh
Compatible model: R50, R50 PRO lamps.
21700 battery
Battery capacity: Rechargeable 21700 5000mAh 3.6v Battery
Compatible Model: Warrior 3S/ Warrior 3/ Warrior X 3/ Warrior X Turbo/ Warrior X Pro/ Seeker 3 Pro/ Seeker 2 Pro/ Seeker 2/ Odin GL M/Odin/ Odin Turbo/ Odin IR/ Perun 2/Freyr/ M2R Pro / Archer / Baton 3 Pro Max.
18650 battery
Battery capacity: 3500mAh 18650 battery
Compatible Model: Warrior Mini 2, Perun, Baton Pro, Warrior Mini, S30R II, S30R III, S2R Baton, R20 Javelot, H2R.3500mAh 18650 battery specifically compatible for magnetic charging in the Warrior Mini 2, Perun, Baton Pro, Warrior Mini, S30R II, S30R III, S2R Baton, R20 Javelot, H2R.
We have updated the cover of this battery, and all the other materials or parameters remain the same, so you might receive either the battery with the old cover or with the new cover, they are the same batteries.
Battery capacity: Customized rechargeable 18650, 3200mAh 3.6v Battery
Compatible model: specifically designed for the S2R II / Baton 3 Pro.
Battery capacity:18500 rechargeable battery (3.6V 2040mAh)
Compatible models: Odin Mini / Odin GL Mini / Javelot Mini / Javelot Tac
IMR16340 rechargeable battery
Battery capacity: 550mAh, 3.7V
Compatible models :Baton3/S1R Baton II/Perun MINI
Battery capacity: IMR16340 rechargeable battery (3.6V 650mAh)
Compatible models: Perun 2 Mini/Baton3/S1R Baton II/Perun Mini
CR123A battery (3V 1600mAh)
Battery capacity: 1600mAh
Compatible models: BALDR PRO/BALDR RL/BALDR IR/Valkyrie Turbo
Please note that CR123A batteries are not rechargeable.
New CR123A 1600mAh: 3V 1600mAh CR123A disposable Lithium batteries designed for high-drain devices.
Battery capacity:1600mAh,3V
Compatible models: PL-3, Baldr Pro, Baldr RL, Baldr IR, PL 2, and Valkyrie Turbo.
14500 Rechargeable Battery
Battery capacity: 1420mAh, 2.4V
Compatible model: i5R EOS
18650 Battery
Battery capacity: 2600mAh,3.7v
Triple over-heat protection and over-discharge protection to maximize performance, optimal for high-drain devices.
Higher energy density, higher capacity, and lower weight than other types of rechargeable batteries.
Manufactured under ISO9001-2000 to assure quality.
Improved Battery Safety Free from Leakage of Liquid Electrolyte.
Battery capacity: 3400mAh,3.6v
● Up to 500 charge and discharge cycles, maximum 4A constant discharging current, optimal for high-drain devices.
● Using an innovational positive protection circuit and its positions on the positive of battery is different from the traditional circuit.
● With protecting board placement, over-discharge current protection, over-discharge voltage protection, short circuit protection, and overcharge protection.
● Improved Battery Safety Free from Leakage of Liquid Electrolyte.
Kindly Notes: Ordinary 18650 batteries are suitable for ordinary 18650 models, but they cannot be used for turbo gear
14500 Battery
Battery capacity: 750 mAh
Compatible model: S1A
The lithium ion battery in the AA class.
With the Olight 14500 750 mAh lithium ion battery, Olight offers the right battery for a variety of applications in the 14500 / AA class. Herewith you get the maximum power out of your AA flashlight (please check if lamp is compatible with lithium ion batteries).
With its 3.6V and 750 mAh it offers a decent capacity and maximum power for your lamp. Olight uses only high quality branded cells with appropriate protection circuitry for its batteries.
RCR123A Battery
Battery capacity: 6500 mAh ,3.7v
Compatible model:S10R.
HDC 18650 Battery
Battery capacity: 3500mAh,3.6v
Compatible model:M2R Warrior,X7 Marauder
Battery capacity: 3000mAh,3.6v
Compatible model:Warrior X
Battery capacity: Olight 18650 HDC 3500 mAh battery pack of 4.
Compatible model:With the high-current Olight 18650 3500 mAh lithium ion battery, Olight offers the right battery for flashlights with particularly high requirements (e.g. X7 Marauder).
X9R Battery Pack
X9R Battery Pack is only compatible with X9R.
X9R Cell Battery
The X9R Cell Battery is for X9R Cell Keychain Light
Javelot Turbo Battery Pack
Javelot Turbo Battery Pack is only compatible with Javelot Turbo.
Javelot Pro Battery Pack
Javelot Pro Battery Pack is only compatible with Javelot Pro.
Benefits of Olight Flashlight Batteries
There are several benefits to using Olight flashlight batteries, including:
High-Quality Materials: Olight batteries are made with high-quality materials, ensuring long-term performance and reliability.One of the most significant advantages of using Olight batteries is their commitment to quality and safety. Olight batteries undergo rigorous testing and adhere to strict quality control standards to ensure that they are safe and reliable. This means that you can use your Olight flashlight with confidence, knowing that you are using a high-quality battery that has been designed with your safety in mind.
Long Lifespan: Olight batteries offer a relatively long lifespan, making them an excellent investment for those who use their flashlights frequently.
Rechargeable: Olight batteries are rechargeable, making them an environmentally friendly choice and a cost-effective option over the long term.Olight also offers a variety of charging options for their rechargeable batteries, including USB charging and magnetic charging. These charging options make it easy and convenient to keep your batteries charged and ready to use whenever you need them.
Designed for Olight Flashlights: Olight batteries are specifically designed for use in their flashlights, ensuring compatibility and optimal performance. This means that you can rest assured that your Olight flashlight will work seamlessly with an Olight battery, resulting in maximum brightness and longer run times.
Variety: Olight offers a wide range of batteries for their flashlights, ensuring that there is a battery available for every application and need.
In conclusion, Olight flashlight batteries are an essential component of their flashlights, providing the power necessary to generate light. Olight offers a wide range of batteries, including Li-ion and LiPo batteries, to suit a variety of applications and needs. With their high-quality materials, long lifespan, and rechargeable nature, Olight batteries are a worthwhile investment for anyone who relies on their flashlight for work, outdoor activities, or everyday use. Olight's commitment to quality and safety ensures that you can use your Olight flashlight with confidence, knowing that you are using a high-quality battery that has been designed with your safety in mind.
