Everyday carry (EDC) flashlights have evolved far beyond simple tubes that cast light. Today, users demand versatility, durability, and multi-functional performance packed into flat, pocket-friendly form factors. Olight has pioneered this space with its highly acclaimed flat EDC series.
In this head-to-head comparison, we analyze the battle-tested Arkfeld Pro Flat EDC Flashlight against the upgraded powerhouse, the Arkpro Ultra Premium EDC Flashlight. Whether you are an outdoor adventurer planning your next excursion, a professional inspector, or a casual EDC enthusiast, this guide will dissect the key differences in beam profiles, lighting modes, materials, and charging configurations to help you make an informed decision.
- TL;DR:
- Product Overview
- Arkfeld Pro vs ArkPro Ultra: Specs at a Glance
- The Biggest Differences That Actually Matter
- Which Flashlight Is Better for Your Lifestyle?
- Frequently Asked Questions
- Final Recommendation: Which One Should You Buy?
TL;DR:
The Arkfeld Pro is best for general everyday carry and casual tasks due to its balanced 1,300-lumen output, sleek rectangular profile, and user-friendly circular selector, while the Arkpro Ultra wins for demanding outdoor adventures and tactical setups thanks to its brighter 1,700-lumen output, long-range 205-meter spot beam, ultra-tough O-aluminum construction, and dual USB-C/magnetic charging options.
Product Overview
Arkfeld Pro: A Proven Everyday Carry Favorite
The Arkfeld Pro represents a massive leap forward in multi-light pocket illumination. Built on the foundation of the original Arkfeld, the Pro edition brings a three-in-one setup that incorporates a powerful white light, a high-output UV light, and a precise green laser.
Designed for comfort and intuitive operation, it features Olight's signature unibody rectangular design. Its high-transparency glass lens ensures excellent clarity, and the physical circular selector allows you to transition between modes with zero friction. It is a highly trusted companion for home maintenance, office presentations, and pet interactions.
ArkPro Ultra: Built for More Power and Versatility
The ArkPro Ultra is engineered to push flat-body EDC flashlights to their absolute limit. Featuring Olight’s proprietary self-developed EIP 1 LED chip, it delivers a massive 1,700-lumen combined output with distinct spotlight and floodlight beams.
Beyond its intense raw output, the ArkPro Ultra introduces extreme physical durability. By utilizing Olight's proprietary O-aluminum material—which is 1.73 times harder than standard 6061 aluminum alloy—this flashlight resists impacts, dents, and heavy scratches in the field. Dual charging options (USB-C and magnetic) and the interactive ArkBeat status indicator elevate its utility for serious outdoor and tactical users.
Everyday Simplicity vs All-in-One Capability
When choosing between these two flat lights, you are choosing between streamlined daily execution and maximum extreme-environment performance.
The Arkfeld Pro focuses on giving you an elegant, ultra-portable profile that disappears in a pocket. The ArkPro Ultra, on the other hand, prioritizes raw output power, professional-grade beam throw, and materials that can survive a drop onto rugged, rocky terrain.
To understand the core differences between these flashlights, let us compare their raw specifications side-by-side:
Side-by-Side Specifications Comparison
| Parameter / Feature | Arkfeld Pro | ArkPro Ultra |
| Max Brightness | 1,300 lumens | 1,700 lumens |
| Light Sources | 3 (White LED, UV, Green Laser) | 4 (Flood, Spot, UV, Green Beam) |
| Beam Configuration | Fixed optic (Standard flood) | Dual-beam (Flood & Spot independent) |
| Max Beam Distance | 102 meters | 205 meters (Spot mode) |
| UV Wavelength & Power | 365 nm / 900 mW | 365 nm / High-power |
| Body Material | Standard 6061-T6 Aluminum Alloy | Ultra-hard O-aluminum (1.73x harder) |
| Battery Type / Capacity | Built-in 1500mAh Li-Po | Built-in high-capacity rechargeable |
| Max Runtime | 11 days (Moonlight mode) | 14 days (Moonlight mode) |
| Charging Method | Magnetic USB Charging (MCC) | Dual Charging (USB-C + Magnetic MCC) |
| Interactive Features | Five-level battery indicator | ArkBeat breathing pulse indicator |
While both flashlights share Olight's modern flat aesthetics, several critical engineering differences set them apart in real-world application.
Lighting Options: How Much Versatility Do You Need?
The Arkfeld Pro is a versatile three-in-one light. Its 900mW (365nm) UV light is exceptional for detecting stains, pet urine, and checking currency validity. The integrated Class 3R green laser works flawlessly for business presentations or keeping pets active.
The ArkPro Ultra upgrades this suite by separating its white light output into independent floodlight (1,700 lumens) and spotlight (800 lumens) channels. It features 4 distinct light sources and 7 modes. It allows you to use a wide, expansive wall of light for close-up tasks or a tight, focused search beam. The green beam and UV light remain present, giving the Ultra unparalleled tactical and analytical adaptability.
Beam Performance: Flood Light vs Long-Range Visibility
For general tasks, the Arkfeld Pro's 102-meter maximum throw is more than sufficient. Its beam is wide and pleasant, designed for illuminating paths, engine bays, or dark hallways.
The ArkPro Ultra is built for long-distance observation. Thanks to its dedicated spot lens, it throws a concentrated beam up to 205 meters away. If you find yourself navigating dense woods, looking for trail markers, or inspecting industrial facilities, the ArkPro Ultra's throw ensures nothing stays hidden in the distance.
Premium Materials and Durability
Daily wear and tear can quickly scuff standard aluminum lights. The Arkfeld Pro utilizes standard hard-anodized aircraft-grade aluminum, which provides reliable protection against typical drops and pocket scratches.
The ArkPro Ultra takes durability to a military-grade tier. Its body is composed of O-aluminum, which undergoes a specialized hardening process to make it 1.73 times harder than standard alloy. It shrugs off direct impacts on concrete and resists deep gouges. Additionally, its robust structural design makes it highly dustproof and waterproof, which is perfect for harsh climates.
Battery Life and Charging Convenience
The Arkfeld Pro relies solely on Olight's proprietary magnetic MCC charging system. Its 1500mAh battery delivers an impressive 11 days of runtime on its lowest setting, minimizing power anxiety for casual users.
The ArkPro Ultra extends its maximum runtime to 14 days. More importantly, it solves a major pain point by offering dual-charging compatibility. You can charge it via the convenient magnetic MCC cable at home, or use a standard USB-C cable when traveling. This dual capability makes the ArkPro Ultra highly adaptable for long-term survival situations where specialized chargers might not be available.
Pocket Carry and Everyday Comfort
Both units slide comfortably into pockets without creating the unsightly bulge associated with traditional round tactical flashlights. The Arkfeld Pro is slightly slimmer and lighter, making it highly comfortable for lightweight shorts or business casual trousers. The ArkPro Ultra is marginally beefier due to its dual-optic design and hardened shell, but it still maintains a flat profile that fits easily into tactical pants or backpack organizers.
To help you choose the right light, let us analyze how both flashlights perform across specific, real-world scenarios.
Best for Everyday Carry and Daily Tasks
For everyday carry, weight and ease of use are paramount. The Arkfeld Pro is the clear champion for standard daily routines. Its intuitive circular selector dial is easy to operate with a thumb, and its 1,300 lumens of soft white light are perfect for searching under car seats, checking fuses, or navigating around the house during a power outage.
Best for Camping, Hiking, and Outdoor Adventures
If your weekends involve setting up tents, walking dark trails, or exploring remote regions, the ArkPro Ultra is the superior choice.
Its 205-meter spot beam allows you to scan deep into the woods to spot wildlife or trail markers. The ultra-rugged O-aluminum body ensures that a drop onto sharp river rocks won't shatter your primary light source, while the 14-day battery reserve and USB-C compatibility keep you powered throughout your trip.
Best for Professional and Inspection Work
HVAC technicians, home inspectors, auto mechanics, and crime scene investigators require tools with zero room for error.
The ArkPro Ultra is heavily optimized for professional tasks. The EIP 1 LED produces an expansive, clear beam with high optical clarity, allowing for accurate visual assessments. Its dual-beam versatility allows professionals to switch from floodlighting an entire crawlspace to throwing a tight spotlight onto a distant high-voltage line.
Best for First-Time Olight Owners
If you are new to high-end flashlights and want an all-in-one tool that handles home, office, and outdoor duties, the Arkfeld Pro is an incredible entry point. It offers premium build quality, great battery life, and a highly accessible user interface without a steep learning curve.
Best for Current Arkfeld Users Considering an Upgrade
If you already own an older Arkfeld or Arkfeld Pro, upgrading to the ArkPro Ultra is highly recommended if you require:
- Double the throw distance (205 meters vs 102 meters).
- Universal USB-C charging alongside magnetic charging.
- High impact and scratch resistance for rugged field environments.
- Independent control over distinct spot and flood beams.
How does the price of the ArkPro Ultra compare to the Arkfeld Pro, and is the upgrade worth it?
Can I use standard USB-C cables to charge both of these Olight flashlights?
What are the main differences between the UV lights on the Arkfeld Pro and the ArkPro Ultra?
Is the ArkPro Ultra significantly heavier or larger to carry in a pocket than the Arkfeld Pro?
Can I use the white light and the laser pointer at the same time on these models?
Choosing between these two high-performing EDC flashlights comes down to analyzing your environment and daily requirements.
Choose the Arkfeld Pro If...
- You want a lightweight, sleek flat light for urban carry, office tasks, and casual home use.
- You prefer an intuitive circular dial selector to switch lighting modes quickly.
- Your typical tasks do not require long-range illumination beyond 100 meters.
- You want a proven, versatile three-in-one (White light / UV / Laser) EDC light at an attractive price point.
Olight Arkfeld Pro
The ultimate 3-in-1 flat EDC flashlight with a versatile combination of 1,300 lumens, UV light, and a green laser indicator.
Buy Arkfeld ProChoose the ArkPro Ultra If...
- You are an outdoor adventurer, camper, or hiker who needs a 205-meter spot beam to navigate safely.
- You need a rugged, highly durable tool made of O-aluminum that can withstand impacts and harsh environments.
- You want the charging flexibility of both magnetic MCC and standard USB-C cables.
- You require a professional dual-beam setup (flood and spot) to tackle complex inspection work.
Olight Arkpro Ultra
A premium, ultra-hard O-aluminum powerhouse boasting 1,700 lumens, a 205m dual-beam throw, and dual USB-C charging.
Buy Arkpro UltraOur Final Verdict
For the vast majority of urban and suburban users, the Arkfeld Pro remains the ultimate everyday companion—delivering balanced power and outstanding ergonomics in a slim package.
However, if you demand uncompromising durability, long-distance reach, and universal charging capability for survival or professional use, the Arkpro Ultra is the clear winner of this EDC battle.
