Olight makes the lights and switches discussed here. Olight details come from its US product pages and manuals as of October 2026; other brands' details come from their makers. Reach, drain and cost figures are calculations, not measurements.
An Olight remote pressure switch only fits the lights named on its own product page, and no light appears on two lists. The ROD-7 covers the Odin and Odin Mini, the sROD-7 covers the Warrior 3S, Warrior X 4, Warrior Ultra, Odin GL and Odin IR, the RWX07 covers older Warrior X and M2R lights, and the sRPL-7 fits only the PL-3R.
The trouble starts at checkout. Four switches look alike, the names differ by a letter, and the compatibility facts sit on four separate product pages. Buy the wrong one and the magnet may still snap on, but the pad will not run your light. This guide puts every official list in one place and works through kit contents, cable reach, drain risk and cost.
This quick-reference table shows which Olight remote pressure switch to buy for each light family, with regular prices as of October 2026.
| Switch | Lights Olight lists as compatible | Regular price | Already in the box with |
| ROD-7 | Odin, Odin Mini, Odin Turbo, Warrior X Turbo, Javelot Turbo | $32.95 (Black or Desert Tan) | Odin Mini |
| sROD-7 | Warrior Ultra, Warrior X 4, Warrior 3S, Warrior X 3, Warrior 3, Javelot, Javelot Pro 2, Odin GL M, Odin GL P, Odin GL Mini, Odin IR, Javelot Tac P / M | $35.95 (Black) | Odin IR, Odin GL M |
| RWX07 | Warrior X, Warrior X Pro, Javelot Pro, M2R, M2R Pro | $19.95 (Black, Camouflage, Desert Tan or OD Green) | None of the current kits |
| sRPL-7 | PL-3R | $19.99 (Black or Desert Tan) | Not listed in the PL-3R box |
| None of the four | Odin S | Not applicable | Odin S ships with its own pressure switch and mount |
- 1. Olight Remote Pressure Switch Compatibility Chart by Light Model
- 2. What Is a Remote Pressure Switch?
- 3. How Olight's Magnetic Tail Connection Differs From Plug-In Remotes
- 4. sROD-7 vs ROD-7: What Is the Difference?
- 5. RWX07 and sRPL-7: Switches for Older Warriors and the PL-3R
- 6. How Does the Switch Pad Attach to an M-LOK or Picatinny Rail?
- 7. Cable Length and Routing: How Far Back Can the Pad Sit?
- 8. What Are the Common Problems With Pressure Switches?
- 9. Why Does Olight Have a Bad Reputation?
- 10. Common Misconceptions About Olight Pressure Switch Fit
- 11. Is a Spare Pressure Switch Worth the Price?
- 12. Your Olight Pressure Switch Fit Checklist
- 13. FAQ
Find your light in the left column, then buy only the switch named beside it. Across the four switch pages, Olight names 23 light entries, and each appears on exactly one list. If your light is not on a switch's page, treat that pairing as not compatible, even when the magnet holds.
The lists split roughly by generation: the ROD-7 for the original Odin and Turbo lights, the sROD-7 for newer Warriors plus the Odin GL and Odin IR, the RWX07 for the first Warrior X and M2R lights, and the sRPL-7 for one pistol light. You can browse the current lineup on Olight's rail mount lights page, and the switches themselves sit with Olight's flashlight accessories.
This reverse-lookup table starts from the light you own and notes whether that light still has an Olight US store page as of October 2026.
| Your light | Switch to buy | Switch in the box? | US store page? |
| Odin | ROD-7 | Yes, listed as "Magnetic Remote Switch (With Stand)" | Yes |
| Odin Mini | ROD-7 | Yes, listed as "ROD-7 Magnetic Remote Switch" | Yes |
| Odin Turbo, Warrior X Turbo, Javelot Turbo | ROD-7 | Not applicable | No |
| Odin GL M / Odin GL P | sROD-7 | M kit: sROD-7; P kit: "Magnetic Remote Switch" | Yes |
| Odin IR | sROD-7 | Yes, listed as "sROD-7 Linear Wire Remote Switch (With Stand)" | Yes |
| Warrior 3S | sROD-7 | No | Yes |
| Warrior X 4 | sROD-7 | None named on its page | Yes |
| Warrior Ultra | sROD-7 | No | Yes |
| Warrior X 3, Warrior 3, Javelot, Javelot Pro 2, Odin GL Mini, Javelot Tac P / M | sROD-7 | Not applicable | No |
| Warrior X, Warrior X Pro, Javelot Pro, M2R, M2R Pro | RWX07 | Not applicable | No |
| PL-3R | sRPL-7 | No; the page calls the sRPL-7 "optional" | Yes |
| Odin S | None of the four | Ships with its own "Pressure Switch" and "Pressure Switch Mount" | Yes |
Count the rows and 14 of the 23 listed entries have no current page in Olight's US store listing, so these switch pages serve owners of older lights as much as new buyers.
A remote pressure switch is a pad on a short cable that works a light's switch from a spot away from the light, usually on a rifle handguard where your support hand already rests. On Olight's Odin-family lights, the cable ends in a magnetic cap that a ring locks onto the light's tail, so holding the pad gives momentary light and a quick press latches it on.
Most weapon-light makers use a plug instead of a magnet. SureFire says its ST tape switch "lets you remotely activate any SureFire WeaponLight that has a switch socket," per its ST07 product page. Streamlight's TLR remote switch sheet lists its plug-in remotes for the TLR-1, TLR-2, TLR HL, TLR-1 HP, TLR-1 GAMESPOTTER and TLR-VIR series, and says they need a special battery door with a remote connector.
At both brands, a remote is built for one family of lights; Olight swaps the plug for a magnetic tail. The Odin Mini, Odin GL and Odin IR manuals describe the same basic behavior: a quick press turns the light on and off, and press and hold gives momentary light that goes out when you let go.
Safety note: Fit and check any weapon light switch with the firearm unloaded. The NSSF's 10 rules of firearms safety say to "always open the action immediately, and visually check the chamber, receiver and magazine to be certain they do not contain any ammunition," and to "Never point your gun at anything you do not intend to shoot." Function checks of a pressure pad point the muzzle wherever the light goes.
On the Odin-family lights, Olight's remote switch replaces nothing on the light. You set the magnetic cap on the tail and lock it with a ring, and the light's own tail switch stays in place. The RWX07 and sRPL-7 pages say only that those switches attach magnetically. Plug-in systems from other makers need a socket: Streamlight swaps in a battery door with a connector, and SureFire plugs into a switch socket on the light.
The Odin Mini user manual gives the first step: "Attach the magnetic remote switch to the tail of the product (make sure the detent ring of the remote switch is unlocked)." Its product page adds that the switch "comes with a locking function for quick operation and a tight fit with a slight push of the ring."
This interface table compares how the three systems connect, based on each maker's own documentation.
| Feature | Olight ROD-7 and sROD-7 (Odin manuals) | Streamlight TLR remotes | SureFire ST07 |
| Connection | Magnetic cap on the light's tail, locked by a ring | Plug into a replacement battery door or switch | Plug into the light's switch socket |
| Parts you swap on the light | None | Battery door/switch 69130 or 69161 | None if the light has a socket |
| Seal at the plug | Not stated on Olight's switch pages | "rotating quick disconnect plug with O-ring seal" | "The plug is O-ring sealed" |
| Published cable length | Not published on the four switch pages | 8 in for 69135 and 69132 | Seven-inch (ST07) |
The practical point is the shared tail. The Olight Odin weapon light page lists one tail that handles "Magnetic charging, tactical handheld operation, and remote switch compatibility." Because charging and the remote share that tail, the switch comes off while the light charges, and the light still works by hand.
The ROD-7 and sROD-7 differ in which lights they fit and in the buttons Olight documents. The ROD-7 serves the Odin and Odin Mini, and the Odin Mini manual shows no separate remote buttons. The sROD-7 serves the Warrior 3S, Warrior X 4, Warrior Ultra, Odin GL and Odin IR, and two kit manuals show separate LO and HI buttons on it.
The Olight ROD-7 costs $32.95 in Black or Desert Tan. Its page lists five lights: Odin, Odin Mini, Odin Turbo, Warrior X Turbo and Javelot Turbo. The Odin Mini manual sets low or high at the light's own tail (a light click for low, a hard press for high) and shows no LO or HI buttons for the remote. The Odin Mini already ships with a ROD-7, along with an RM3R pressure switch mount, so a second ROD-7 is a spare or a second pad position.
The Olight sROD-7 costs $35.95 in Black and lists 12 entries, the longest list of the four. The Odin IR page calls its boxed version an "Upgraded Remote switch: Two-level modes for both indoor and outdoor use," and the Odin IR and Odin GL M manuals show a HI button and a LO button. Both manuals add one rule worth knowing before you mount it: "When in the OFF mode, the operation of LO&HI buttons is disabled." On the Odin IR, OFF is also a position on the head's selector ring, and its manual adds, "When the mode switch is positioned to OFF, all operations are disabled," so a dead pad may simply mean the ring sits on OFF.
This comparison table sets the two switches side by side using only what the product pages and kit manuals state.
| Point | ROD-7 | sROD-7 |
| Regular price | $32.95 | $35.95 |
| Compatible entries listed | 5 | 12 |
| Current kits that include it | Odin Mini (Odin kit lists a magnetic remote switch with stand) | Odin IR, Odin GL M |
| Remote buttons shown in the kit manual | Odin Mini: none shown | Odin IR and Odin GL M: separate LO and HI buttons |
| Fits an Odin Mini? | Yes | Not listed |
| Fits a Warrior 3S? | Not listed | Yes |
Pick by your light, not by the newer-sounding name: the "s" does not add the ROD-7's lights to the list.
The RWX07 and sRPL-7 are the two narrow-fit switches. The RWX07 fits five older lights, the Warrior X, Warrior X Pro, Javelot Pro, M2R and M2R Pro, and costs $19.95. The sRPL-7 fits one light, the PL-3R pistol light, and costs $19.99. Neither switch is listed for any Odin, newer Warrior or other PL model.
The Olight RWX07 comes in Black, Camouflage, Desert Tan and OD Green, all at $19.95. Olight calls it the "World's first magnetically attached remote pressure switch" and lists "Low click noise, long-life electronic switch" and "Extremely low standby current." Because none of its five lights has a current store page, an RWX07 is mainly a spare for an existing setup.
The Olight sRPL-7 comes in Black or Desert Tan at $19.99, and its page states only: "The sRPL-7 is compatible with PL-3R." The PL-3R page says the light is "Compatible with an optional magnetic remote pressure switch (sRPL-7) for larger builds," and its package list shows the light, an MCC 1A cable, a 1913 adapter and screw, wrenches and a manual, with no switch. If you want a pad on a PL-3R, budget for the switch separately. For how the PL-3R compares with smaller pistol lights on price and reach, see our guide to the best pistol light under 100.
Warning: The Odin GL M and Odin GL P on the sROD-7 list carry a green laser. The Odin GL M manual rates its green beam Class 3R and warns: "GL beam light is bright and blinding - DO NOT shine at aircraft or vehicles at any distance." A pressure pad makes it easy to fire that beam by accident, so set the selector ring to white light only when you are not using the laser.
Olight's standalone switch pages do not list a pad mount or stand, so what you get for the rail depends on the light kit. The Odin Mini box lists an RM3R pressure switch mount, the Odin and Odin IR boxes list a switch "With Stand," and the Odin S box lists a "Pressure Switch Mount." A switch bought alone may need a separate pad mount.
Check your box contents before you order a second switch. The four switch pages do not say which rail a stand clamps to, so this guide does not guess. If you are still choosing between handguard systems, our picatinny vs M-LOK guide compares slot sizes, spacing and adapters.
This box-contents table lists the switch and pad hardware each current kit includes, copied from the package lists on Olight's product pages.
| Kit | Switch in box | Pad mount or stand in box | Light mount in box |
| Odin Mini | ROD-7 Magnetic Remote Switch | RM3R Pressure Switch Mount | M-LOK Rail Mount |
| Odin | Magnetic Remote Switch | "With Stand" | Pic Rail Adapter (Highlights also list an included slide rail mount) |
| Odin IR | sROD-7 Linear Wire Remote Switch | "With Stand" | Picatinny Rail Mount |
| Odin GL M | sROD-7 Magnetic Remote Switch | "with Stand" | M-LOK Rail Mount |
| Odin GL P | Magnetic Remote Switch | None listed | Picatinny Rail Mount |
| Odin S | Pressure Switch | Pressure Switch Mount | Rail Mount |
| PL-3R, Warrior 3S, Warrior Ultra | None | None | PL-3R: 1913 Adapter; Warriors: none listed |
On an M-LOK handguard, pad positions come in fixed steps. Magpul's M-LOK installation page says, "Your M-LOK accessory can be adjusted in 20mm increments (1/2 slot length)." Plan the pad and the light together, because moving one by a single step changes how much cable you have left between them.
A pad can sit no farther from the light's tail than the cable allows in a straight, relaxed run. Olight does not publish cable lengths on its four switch pages, so measure yours from where the cable leaves the connector to where the pad begins, then subtract the light's length and that cable from your handguard length.
That mirrors SureFire's method: "Cable length is measured from opening of plug skirt to beginning of tape switch." NIST's length units page confirms that the inch "is exactly equivalent to 25.4 mm," so a 13 in handguard is 330.2 mm and a 15 in handguard is 381.0 mm.
Here is the framework, with each assumption named:
- Handguard length H, in inches.
- Light length from Olight's page (Odin Mini 4.55 in, Odin 5.37 in, Odin IR 5.41 in, Odin GL 5.87 in).
- Assume the light's head sits flush with the front of the handguard and the cable runs straight back along the rail.
- Rail left behind the tail = H − light length.
- Rail the pad cannot reach = H − light length − cable length.
This reach table runs that framework for 13 in and 15 in handguards. The 7 in cable is not an Olight figure: it is borrowed from SureFire's "Seven-inch" ST07 as an illustration, so swap in your own measured length.
| Light (Olight length) | Rail behind tail, 13 in handguard | Rail behind tail, 15 in handguard | Out of reach with a 7 in cable, 13 in | Out of reach with a 7 in cable, 15 in |
| Odin Mini (4.55 in) | 13 − 4.55 = 8.45 in | 15 − 4.55 = 10.45 in | 1.45 in | 3.45 in |
| Odin (5.37 in) | 7.63 in | 9.63 in | 0.63 in | 2.63 in |
| Odin IR (5.41 in) | 7.59 in | 9.59 in | 0.59 in | 2.59 in |
| Odin GL (5.87 in) | 7.13 in | 9.13 in | 0.13 in | 2.13 in |
On a 13 in handguard, a 7 in cable reaches almost the whole rail behind any of these lights. On a 15 in handguard, the rear 2.13 to 3.45 in stays out of reach, so slide the light back a mount position rather than stretch the cable. On M-LOK, 7 in equals 177.8 mm, just under nine of Magpul's 20 mm steps.
These are best-case figures. Any bend or loop uses cable, so leave slack at the magnetic cap.
Tip: Route the cable along the rail with the self-locking bands Olight includes in the Odin, Odin Mini and Odin IR boxes, and keep the band off the magnetic cap itself.
The common problems with Olight pressure switches are a switch that does not match the light, a tight cable pulling on the magnetic cap, debris or salt water at the tail contacts, a selector ring left on OFF, and a slow battery drain when something bridges the tail cap and its ring. Most are fixed by checking the compatibility list and cleaning the tail.
Work through them in this order:
- Wrong switch. Confirm your light is on that switch's page. An unlisted switch can sit on the tail and still fail to work the light.
- Tight cable. A cable with no slack can tilt the cap when the handguard flexes. Re-route with a loose bend at the tail.
- Debris at the tail. The Odin GL M manual warns: "The magnetic tail is easy to attract iron debris. Please keep the tail switch cap and the ring surrounding it clean."
- Wet or salty contacts. The Odin Mini manual says: "The tail switch may not work while immersed in sea water or other conductive media. Please try to keep it clean and dry."
- Selector on OFF. On the Odin IR, a head selector set to OFF disables every operation, including the remote's LO and HI buttons.
One more fault drains batteries in storage rather than stopping the light. The Odin Mini manual warns not to short the switch cap to the ring "for a prolonged period," because it causes "a loss of current below 3mA, and may lead to a complete battery drain if it is in this state for too long." The Odin IR manual gives a ceiling of "below 18mA" for the same fault.
This drain table turns those ceilings into the shortest time a full battery could last if debris bridged the tail. It is based on Olight's rated capacities and the manuals' current ceilings, not measured.
| Light | Rated battery | Manual's current ceiling | Hours = mAh ÷ mA | Days |
| Odin Mini | 2040 mAh 18500 | Below 3 mA | 2040 ÷ 3 = 680 h | 680 ÷ 24 = about 28 |
| Odin IR | 5000 mAh 21700 | Below 18 mA | 5000 ÷ 18 = about 278 h | 278 ÷ 24 = about 11.6 |
Because the real current is below each ceiling, these are lower limits, but on these ratings an Odin IR with a bridged tail could be flat in under two weeks. For storage and travel, the Odin Mini manual says to "unscrew the tailcap and remove the battery to cut off the circuit."
Warning: The Odin IR manual warns, "DO NOT shine the light directly into human eyes. This may cause temporary blindness, or permanent damage to the eyes." When you check a pad after re-routing, point the muzzle at a safe backstop, never at a person or a mirror.
Criticism of Olight that you can check points to two things: a documented 2022 U.S. recall of two flashlight models, and proprietary parts that tie owners to Olight accessories. For switch buyers, the second point bites hardest: each Olight remote fits only its own list of lights, so a remote from one light family will not carry over to the next.
The CPSC recall notice covered about 215,100 M2R Pro and Warrior Mini flashlights that "can be turned on inadvertently and overheat while stored in the holster or a consumer's pocket." It lists 127 reports of lights turning on and overheating, with 22 reports of burn injuries. One of those two models, the M2R Pro, is on the RWX07 list. If you still own one, check the CPSC notice before you build a switch setup around it.
The parts criticism is fair in this category. Moving from a Warrior X to a Warrior 3S means moving from the RWX07 to the sROD-7, and moving from an Odin Mini to an Odin S means using the Odin S's own switch. Plug-based brands work the same way within their families, as the SureFire and Streamlight pages above show. Our is Olight worth it guide weighs these trade-offs across the whole range.
Note: Olight's current warranty page gives flashlights and weapon lights a "Lifetime Warranty" and MCC charging cables a "1-Year Warranty," but it does not name remote switches in its table, and it excludes "Accessories not covered under warranty terms." Lifetime coverage there applies to products purchased after 2023. Ask Olight support how a switch is covered before you assume it is.
The most common misconception is that Olight's four remote switches are interchangeable because each one attaches magnetically. They are not: each of the 23 listed light entries appears on one switch page only, so a switch that snaps on can still fail to run the light.
This table pairs each misconception with what Olight's own pages and manuals say.
| Misconception | Fact | Where it comes from |
| Any Olight magnetic switch fits any Olight light | Each light entry appears on one switch's list only | ROD-7, sROD-7, RWX07 and sRPL-7 product pages |
| Warrior X, Warrior X 3 and Warrior X 4 take the same switch | Warrior X takes the RWX07; Warrior X 3 and X 4 take the sROD-7 | RWX07 and sROD-7 product pages |
| The PL-3R comes with a remote | Its package list has no switch; the sRPL-7 is "optional" | PL-3R product page |
| An IPX8 light means the switch works under salt water | "The tail switch may not work while immersed in sea water" | Odin Mini user manual |
| A locked-on switch is enough for storage | For storage and transport, remove the battery | Odin Mini user manual |
A spare Olight remote pressure switch costs 17% to 30% of the light it serves, based on regular prices in October 2026. That is worth paying if you run two pad positions, swap the light between rifles, or own a light sold without one, such as the Warrior 3S, Warrior X 4, Warrior Ultra or PL-3R.
This cost table divides each switch's regular price by the regular price of a current light it fits.
| Light (regular price) | Switch (regular price) | Switch as share of light | Light plus switch |
| Odin Mini ($139.95) | ROD-7 ($32.95) | 32.95 ÷ 139.95 = 23.5% | $172.90 |
| Odin ($159.95) | ROD-7 ($32.95) | 20.6% | $192.90 |
| Odin IR ($169.95) | sROD-7 ($35.95) | 21.2% | $205.90 |
| Odin GL ($209.95) | sROD-7 ($35.95) | 17.1% | $245.90 |
| Warrior 3S ($119.95) | sROD-7 ($35.95) | 30.0% | $155.90 |
| Warrior X 4 ($129.99) | sROD-7 ($35.95) | 27.7% | $165.94 |
| Warrior Ultra ($139.99) | sROD-7 ($35.95) | 25.7% | $175.94 |
| PL-3R ($99.99) | sRPL-7 ($19.99) | 20.0% | $119.98 |
In the first four rows, at least one kit version already includes a switch, so the total prices a second pad. The last four list no switch in the box or on the page, so the total is the real cost of a pad-ready setup. Among current kits with a switch in the box, the Odin Mini at $139.95 is the cheapest entry point.
A wrong guess costs more than the switch. Buying a ROD-7 for a Warrior 3S wastes $32.95 and still leaves you needing a $35.95 sROD-7, for $68.90 in total.
Use this checklist before you order an Olight remote pressure switch and again when you fit it. Each step comes from the compatibility pages, kit lists and manuals quoted above, and the only tool you need is a tape measure.
- Write down your light's exact model name from the body or box, including any number or suffix (X, X 3, X 4, Pro, Pro 2, GL M, GL P).
- Find that exact name on one switch page: ROD-7, sROD-7, RWX07 or sRPL-7. If it is on none, do not buy one.
- Check your kit's package list. Odin, Odin Mini, Odin IR, Odin GL and Odin S kits include a switch; the PL-3R, Warrior 3S and Warrior Ultra lists do not.
- Check whether a pad mount or stand came in your box; a standalone switch page lists none. Measure your cable from the cap exit to the start of the pad and run the reach math for your handguard.
- Unload the firearm and confirm it is empty before you fit or route anything.
- Wipe the tail cap and ring, lock the switch with its ring if it has one, and leave slack at the cap.
- On an Odin IR, confirm the selector ring is not on OFF; on an Odin GL, select white light only when you do not need the laser.
- For storage or transport, remove the battery as the manual directs.
- October 1, 2026: First published.
