TL;DR: Stop sanding, clear loose dust with your usual extraction or cleanup method, and shine a steady white light across the wood from near surface height. Look for shadows that follow scratches, ridges, and dents. Move the light to a second edge and check ordinary room light before deciding what to correct or whether to apply the finish.
- 1. Make the last inspection before opening the finish
- 2. What low-angle light changes
- 3. Use a controlled source and keep the shop visible
- 4. Check the same area from more than one side
- 5. Read open grain, scratches, and shallow ridges separately
- 6. Trace the edge of a repaired drawer front
- 7. Adapt the check to gypsum board, filler, and metal
- 8. Olight Baton 4 Pro for a movable check along a board
- 9. Olight i3E EOS for a short look into a recess
- 10. Olight ArkPro for a choice between survey and detail light
- 11. Put inspection between sanding and finishing
- 12. Photograph the mark so you can find it again
- 13. Separate a real defect from a lighting artifact
- 14. Know when a visual check calls for a different tool
- 15. What is a raking light?
- 16. What is raking light sanding?
- 17. What are some good lights for sanding?
- 18. Frequently Asked Questions
- 19. Finish the check in the light the piece will actually get
| What you see | Next check | What to decide |
| An arc or straight line stands out from the grain | Move the light across the mark from a second edge | Confirm the line stays in the same place and decide whether it needs local correction. |
| A raised edge throws a shadow | Reverse the direction and check with a straightedge if appropriate | Distinguish a proud joint or sanding ridge from a change in color. |
| A patch reflects light differently | Clear loose dust and look under normal room light | Identify contamination, grain, or sheen before removing more material. |
| A line appears only at the lowest angle | Check the finished piece's intended lighting | Correct it if it matters to the use or the agreed finish standard. |
Set the board on a stable bench and leave enough space to move the inspection light along two edges. Keep ordinary room lighting on for safe footing and tool handling. Stop the sanding operation and let any moving parts come to rest before placing the inspection light, looking closely, or moving the workpiece.
Start with the area that will be easiest to see in use. For a drawer front, that might be along its top edge. For a tabletop near a window, try the edge facing that window first. Looking at the piece from its usual viewing position gives the low-angle check a purpose. A tiny mark in a hidden spot can have different consequences from the same mark across the middle of a dining table.
A final pass goes more quickly when you know what needs a decision. Look for marks that cross the intended scratch pattern, a seam that catches a shadow, and patches of uncertain material. Mark the location on your notes or a nearby label. Do not add more pencil or tape directly to the show surface unless the finishing system and material permit it.
Raking light comes from one side and travels across the surface at a shallow angle. Picture a ridge whose near face catches the light and whose far side falls into shadow. The light-and-dark edge gives your eye another cue for shape, especially when the material itself is nearly one color. Under a broad overhead source, light can reach that darker side and make the same ridge less obvious.
The angle here is measured up from the board's face. A lamp above the middle of the board is nearly perpendicular to that face. A lamp just above one edge throws much of its beam along it. Raise or lower the lamp until there is useful contrast and enough light to make out the surrounding wood. An almost-black surface offers little information even when the angle is shallow.
Yale's visible-light imaging guide demonstrates how raking light records texture and shallow relief. The principle applies to looking for topography on a workbench. A beam direction that suits one feature can miss another, and the mode that best shows shape can disguise changes in color or sheen. Use both views to decide what you are seeing.
When a raised lip lights up on one side, move the beam to the opposite side. A relief shadow will often change direction as the light moves. A stain, naturally dark grain, or old pencil line can still change appearance with the viewing angle, so this is a visual cue. Confirm important findings with a suitable straightedge, a visual check from another position, or your existing finish-preparation process.
A small directional light is useful when its beam can reach the work at a shallow angle without filling the shadows from all sides. An adjustable bench lamp can work well if it fits there. A portable flashlight helps when a cabinet rail, panel edge, or nearby clamp limits where the light can sit. Choose according to placement and the area you want to see.
A wider beam can help you survey a complete panel. Then move closer or use a tighter pool of light to examine the suspect patch. A headlamp is usually useful for seeing where you are looking. It can be harder to keep that beam low and offset from your eyes while you inspect a flat surface. A separately positioned lamp gives you control of where the light starts.
Start at a moderate working level and back away if reflection masks the mark. Bringing a bright light closer can make reflective dust and shiny areas difficult to distinguish. Adjust the light rather than darkening the whole room. Keep an even room light on the route around your bench, particularly if clamps or equipment project into the aisle.
Try a support only if it holds the lamp securely and leaves the front clear. An irregular pile of offcuts can shift and send a light across the bench. For frequent inspections, dedicate a stable spot at the edge of the bench or use a proper lamp stand. Keep chargers and cords arranged according to the manufacturer's instructions, away from dust collection paths and working areas.
Place the lamp at the first edge and look across the board a section at a time. Aim to keep a similar angle as you move along the length. Give your eyes time to settle on each patch. A patch that looks uniform at the center of the beam can appear different as the light moves off it, especially on polished or figured material.
Turn the light, not necessarily the board, for the second pass. Working across a scratch can give its edges more contrast than shining along it. For a wide workpiece, move to an adjoining edge before judging the surface. A good check should give you a view of marks in more than one orientation, so you don't simply get better at seeing one direction.
When fixing a small area, check the surrounding surface too. Inspecting only the lit center can hide an abrupt change between the repair and the adjacent wood. Look along the return edge, near the profile, and at the limits of the sanding or filling you intend to do. A broad view can show whether an isolated repair would leave a visible transition.
Write down where the light was when you found the mark. A note like “left rail, light from handle end” gives you enough of a record to repeat that view after correcting it. Run the same check again and then return to the room-light view. That sequence helps you compare a change in the work with a change in the lighting.
On bare wood, distinguish natural pores and grain from cuts made during shaping. Open-grained stock can show texture even after preparation appropriate to the finish. A set of lines that follows the grain throughout the board can be part of the material. Look for an abrupt pattern across it, repeated machining marks, or a line that appears where work was done.
Small curved marks can come from abrasive movement or trapped grit. Locate the whole cluster before deciding what to do. If a mark crosses a rail and stile, compare how it looks along each grain direction. Avoid assuming that a new coarse scratch is gone because fine marks are visible beside it. Clean the area and compare under the same light before advancing.
Oregon State University Extension's sanding guide describes removing visible mill ridges before finishing. Match the correction to the material and finish you are using. If a door has thin veneer or rounded profile edges, extra sanding can change the surface faster than it solves the visual problem. Use a representative scrap and follow the finishing instructions.
A small shadow also can appear when a fiber stands up or a seam has a slight lip. Check whether the feature is meant to be flush. A deliberate reveal, a chamfer, or an open pore serves a different purpose from a proud joint. Identifying the intended shape first can prevent you from sanding away a detail you wanted to preserve.
Suppose you have filled an old hardware hole on a drawer front and allowed the filler to dry as directed. Under overhead light, a pale circle remains around the patch. Before smoothing it again, inspect the boundary from a shallow angle. The color difference can remain visible even when filler and wood are level. What you need to know before sanding is whether the patch changes the surface shape.
Hold the viewing position and move the beam around that patch. If the edge becomes a bright lip from one side and a dark crescent from the other, confirm it with a suitable straightedge. If the outline is visible in normal room light but no lip or hollow appears, consider whether the concern is color. More sanding may expose a bigger circle without resolving the difference.
Match the next step to the intended finish. A piece of scrap with the same wood and filler can help you judge how the applied product will look before you commit to the visible drawer. For a veneered face, surface thickness matters at the repair boundary. Follow the product instructions and handle uncertain repairs before treating the whole face alike.
Finish by putting the light back at the earlier angle. You can then see whether your response addressed the shape you observed. Carry the drawer toward its installed viewing position only when you can do so safely in normal room light. A check at that distance can resolve whether the repair needs more attention for appearance.
| Material | Where to look | What the light can help locate |
| Bare wood | Across and along the grain, including joints and edges | Repeated machining lines, scratch arcs, and steps between pieces |
| Gypsum board | From the side near a joint, then from the usual room position | Ridges or recesses at seams and local repairs |
| Dry filler or joint compound | Across the repair boundary and neighboring material | A rim, pinhole, or hollow that remains after the material dries |
| Sheet metal | A low beam from one side with the viewer out of its direct reflection | A visible surface ripple or scratch worth verifying by another method |
Look across gypsum board seams before priming, after the material has dried as directed. A low beam can help locate a ridge near a taped joint or an edge where a repair meets the face paper. Montana State University’s design and construction guidelines describe how low-angle side light can emphasize gypsum board irregularities. Check in the intended room lighting too and follow the product and project requirements for any correction.
Check a dry patch of filler at its boundary before deciding whether it needs sanding or another application. Differences in color between the patch and the surrounding material can be visible even if the surfaces are level. Change light direction and use a suitable straightedge if leveling matters. Follow the patching product's drying and preparation instructions before disturbing it.
A smooth metal panel may throw a strong reflection back at the viewer. Move the light or change your viewpoint until the reflection moves away from the area you want to see. Avoid touching a bare sharp edge to judge its shape. Use the correct inspection process for any part where a defect could affect fit, safety, or service. The light is an aid for finding a place to examine.
An angle that works for wood beside the bench may be impractical for a wall or a metal edge. Try moving the light farther along the surface rather than leaning into a reflection or stretching across a work area. Keep the work supported and use the ordinary lighting needed to move around it. When a tool or a different method is needed, stop the visual check and reset the setup safely.
A movable light gives you a quick way to reverse the shadow direction. For a clear answer about the feature, aim across it while keeping the lens away from the board and your eyes out of the beam. If close placement produces too much reflection, try a little more distance or a different working level. A lower setting can be useful when the material is close.
Keep the round light from rolling onto the work or off the bench. Set it in a purpose-made stand or secure cradle if you want to keep the direction fixed. Follow the manual's storage, charging, and heat guidance. If you choose a rechargeable flashlight, plan where it will charge between sessions. Put the light in a safe place before you return to sanding.
The single setting makes placement especially important. Move the light back if the first reflection is too bright. Check that you can still reach the edge without putting your eyes in line with the lens. A flashlight this size can get lost among hardware, so return it to a known shelf or pocket before changing tools.
Start with the wider view if you are trying to find where a change begins. Look closely with the tighter beam if you need to place light by the edge of a seam. The same lumen figure in the two modes does not make their fields of light the same size or shape. Choose the beam according to what the work shows at the bench.
The compact flashlight collection gives examples of different body shapes and controls. If you already have a usable light, try it first. A stable support and two good positions often matter more than another output level. Choose a light you can place where the job requires, including the end of the bench or a narrow drawer.
Use raking light after a sanding step that was meant to remove visible machining or abrasive marks. Clear loose material so that dust does not imitate a defect. Let the tool stop and set it out of the inspection path. Check the same region again before proceeding to the next grit or changing tools.
Save time near the end by looking at likely trouble spots early. Check a joint where uneven sanding can change the shape, and a broad face where a deep mark can hide among the grain. After correcting a problem, compare it with the surrounding surface. Make sure the correction fits the manufacturer's instructions for both the substrate and the finish.
Use your dust-control setup while sanding. The UK Health and Safety Executive’s guide to cutting and sanding wood recommends on-tool extraction when sanding with power tools. Follow the tool, material, and shop safety instructions for dust collection and protective equipment. A flashlight can help you see particles on a board, but it cannot tell you how much fine dust remains in the air.
Do the last check before opening or applying the finish. A test on matching scrap can help you see how the chosen finish changes color, raises grain, or shows a surface mark. Allow it to dry or cure as directed before deciding how it looks. Read the actual workpiece in ordinary room light too, especially if the final piece will sit near a window.
Set the camera at a repeatable position and start with a normal-light reference. Include enough of the board's edge or seam that you can locate the patch later. Move the light down to the side while leaving the camera and workpiece where they are. Save the original frames separately and note which edge the light came from.
Keep exposure and framing consistent if your phone or camera offers that control. Automatic exposure can make a dim image look brighter, and sharpening can make grain look more distinct. Compare location and shape rather than reading the brightness difference as a measured result. If you need another angle, take a third photo and label it with its direction.
For a real example of how one subject looks with different lighting, the Cleveland Museum of Art's comparison describes a photographer and conservators documenting the same area in normal, raking, and specular light. A workbench check uses the same principle of keeping the subject consistent while changing the light. The museum images document a painting and its actual examination.
This method can answer a question about a known mark before finishing. It cannot measure depth, certify flatness, or identify a coating problem from a photograph alone. If a mark matters to fit, use the right physical check. For an appearance concern, walk back to the intended viewing spot and look again at the repaired area under the light it will normally receive.
A broad white reflection that travels with your viewpoint is different evidence from a line that stays attached to the work. Mark the observed position on a sketch, change the lamp position, then check whether the line is still in that place. This is useful on sheet metal, satin coatings, and tightly figured wood. It is also a way to avoid correcting the reflection itself.
Watch for things near the work that can imitate a defect. A clamp above the beam can cast a long shadow over the panel. The lip of the bench can hide the edge you intended to inspect, and a white wall can send enough bounced light back to wash out a shallow scratch. Clear the view and repeat the setup before drawing a conclusion.
If the issue disappears when you remove loose debris, check a nearby clean area before deciding the problem was solved. If it remains after cleaning and can be found again in two positions, record where it is. The remaining question is whether it affects fit or appearance at the intended location. Address that question using the material instructions and a closer check, rather than judging it by shadow size alone.
If a line tells you there is a surface step, use a blunt, suitable measuring tool where needed to check the fit. If a wall patch looks different but feels level under an appropriate straightedge, consider color or surface texture. Give yourself time to identify the issue before you decide to remove material.
For a separate example, the thermal imaging guide explains what that tool is meant to show. Raking light makes patterns from visible light and the workpiece, while thermal imaging addresses another inspection question. Match the method to the information you need, and get qualified help where a finding relates to safety or structural condition.
If you are choosing between a separate handheld beam and a light worn on the head, this flashlight and headlamp comparison provides a related workplace example of beam positioning. At a bench, experiment only with the tool stopped, the work stable, and the beam directed away from people. Set the inspection light aside before you resume.
A raking light is a source aimed across a surface from a shallow angle. It emphasizes small upstanding or recessed details by changing their pattern of light and shadow. Place the source to one side of the work and adjust its height until shape is easy to see. Compare with normal light before deciding what the mark means.
Raking light sanding is checking a surface with side light between sanding passes and before a finish goes on. Stop the tool, clear loose dust as directed, and aim across the work from two directions. Use the visible marks to decide what needs further preparation. Follow the material and finish instructions for the actual sanding and cleanup.
Use a work light that stays steady at a low angle, leaves your workspace visible, and has a useful beam for the area being checked. A small adjustable bench lamp or a handheld flashlight on a suitable support can work. Choose a wider beam for the first pass and a controlled beam for a small mark.
Sweep the edge from two directions and note the feature you can verify. Correct only what matters for the material, the fit, and the intended appearance. Step back into ordinary room light and check the finished piece's likely position. A repeatable final check gives you a practical basis for deciding whether to move on to the finish.
