Olight makes the lights discussed here. Olight specs and regular prices come from its US product pages and user manuals as of September 2026; race rules, body measurements and safety advice come from the official sources linked in each section. The shadow and battery figures are calculations from those published numbers, not measurements.
A trail running headlamp works best at night as half of a two-light setup: a light headlamp that follows your eyes, plus a second light at hip height that throws shadows behind roots and rocks. Our pick is the Olight Perun 3 Mini (54 g, IPX8) on your head and the Oclip 2 Pro on your waistband, $119.98 at regular prices.
You know the problem. The trail looks smooth in your beam, then a root you never saw catches your toe. Turning the headlamp up makes the ground brighter but no easier to read, and in fog the glow gets worse. This guide fixes each moment with geometry, mode plans and race rules.
This gear list shows the trail running headlamp setup by job, with the minimum specs to look for and Olight's regular prices in September 2026.
| Job | Recommended type | Minimum specs to look for | Recommended model (regular price) |
| Head light for runs up to about 2 hours | Small headlamp with a removable cell | 60 g or less; 100 lm steady for longer than the run; immersion rating (IPX7 or better) | Olight Perun 3 Mini, 54 g, IPX8, 100 lm for 4.5 h ($64.99) |
| Second light at hip or waist height | Clip light with a tilting head and a wide floodlight | 100 lm for longer than the run; head that tilts down; clip that holds on a waistband | Olight Oclip 2 Pro, 530 lm floodlight, 115° tilt, 100 lm for 3 h 45 min ($54.99) |
| Head light for long nights | Larger headlamp with a big cell | 100 lm or more for 10 h or more; immersion rating | Olight Perun 3, 120 lm for 25 h, IP68, 150 g ($89.99) |
| Lowest-cost head light | Clip light on a matched strap | Strap listed as compatible by the maker; red mode | Olight Oclip Pro S + Oclip Series Headlamp Strap, 53 g light, IPX6 ($47.98) |
| Spare or fresh headband | Maker's replacement band | Listed for your exact model | Headband for Perun Series ($9.99, Perun 3 Mini version) |
- 1. What Is the Best Headlamp for Trail Running?
- 2. Why Does the Trail Look Flat Under a Headlamp?
- 3. Where Should the Second Light Go: Hip, Chest or Hand?
- 4. How Many Lumens Do I Need for Trail Running?
- 5. Trail Running Headlamp Mode Plan by Terrain and Time of Night
- 6. How Does a Second Light Change Your Battery Plan?
- 7. What Is the Best Headtorch for Trail Running?
- 8. Night Trail Running Race Rules: What Organizers Require
- 9. Keeping the Beam Steady at Running Pace
- 10. Common Mistakes on Night Trails
- 11. Your Night Trail Run Checklist
- 12. FAQ
The best headlamp for trail running is a light of about 60 grams or less that holds 100 lumens for longer than your run and survives a creek, paired with a second light carried lower. Among Olight lights, the Perun 3 Mini fits the head role at 54 g, IPX8 and 4.5 hours at 100 lumens. The Oclip 2 Pro fills the hip role with a 115° tilting floodlight.
Olight's full range of headlamps covers other sizes, and our cross-brand roundup of the best headlamps picks one light per job. Our guide to the best headlamp for hiking and running picks the cheaper Oclip Pro S strap kit for one setup that does both. This guide answers a narrower question, reading technical ground at speed after dark, where the Mini's immersion rating is worth $17 over that kit and a second, lower light earns its $54.99.
Olight Perun 3 Mini: the head light
The head light has to be small enough to forget but strong enough for a rocky descent. The Olight Perun 3 Mini headlamp weighs 1.9 oz (54 g) with its battery and is rated IPX8. Olight lists 6,000 candela and a 508 ft (155 m) beam for the default CW version.
Its full white-light table: Turbo 1,250~350 lumens for 2 + 60 minutes, High 500~350 lumens for 2 + 75 minutes, Medium 100 lumens for 4.5 hours, Low 10 lumens for 30 hours and Moon 2 lumens for 10 days. Red light runs 45 lumens for 150 minutes or 5 lumens for 19 hours. Olight describes the headband as "25% lighter with 3D-breathable mesh and anti-sweat strip," with 360° reflectivity.
The regular price is $64.99 for the default Orange CW version (September 2026). The page also lists a neutral-white HCRI version (920 lumens, 436 ft or 133 m, Medium 85 lumens) and a Premium Edition with a charging case. The limit: 4.5 hours at 100 lumens covers a weeknight run, not an all-night race.
Olight Oclip 2 Pro: the hip light
A second light only helps if it stays aimed at the ground. The Olight Oclip 2 Pro clip light pairs "a 115° head tilt with 360° clip rotation," and Olight says the clip "grips objects up to 14 mm thick, including collars, straps, and MOLLE webbing."
Its floodlight runs Turbo 530~300~100 lumens for 1 + 58 + 5 minutes, High 300~100 lumens for 60 + 5 minutes, Medium 100 lumens for 3 hours 45 minutes and Low 10 lumens for 25 hours. The selector also gives a spotlight and red light (40 lumens for 4 hours, 4 lumens for 27 hours). It weighs 2.66 oz (75.5 g), is rated IP66 and costs $54.99 for the default Tidal Blue version; a Premium version adds a charging dock.
Its main limit comes from the Oclip 2 user manual: "Do not immerse the product in water or other liquids, as it will damage the product." The manual's heart-device warning, quoted in the hip-light section below, also applies because the clip is magnetic and sits on your body.
Olight Perun 3: the long-night head light
On runs longer than the Mini's cell, weight matters less than runtime. The Olight Perun 3 headlamp ($89.99, Black) runs Medium 120 lumens for 25 hours and Low 30 lumens for 89 hours on its 5000 mAh 21700 cell, rated IP68. High is 600~120 lumens for 300 + 30 minutes, and Turbo 3,000~800~600 lumens for 2 + 180 + 30 minutes.
At 5.29 oz (150 g), it is almost three times the Mini. Olight also notes the "Headlamp mounting bracket is METAL - it is expected to scratch the body of the torch if taken in / out repeatedly." For race-night cell planning, see our guide to the best headlamp for ultra running.
Olight Oclip Pro S on a strap: the budget head light
On a tighter budget, the Olight Oclip Pro S ($39.99, Black) rides on the Oclip Series Headlamp Strap ($7.99), which Olight says "is compatible with the Oclip Pro, Oclip Pro S and Oclip Ultra." The light weighs 53 g, runs High at 300~180~100 lumens for 1 + 95 + 10 minutes and Medium at 100 lumens for 3.5 hours. Trade-offs: 1,600 candela, and IPX6 instead of an immersion rating; its manual says not to immerse it. Never look into its UV beam or shine it at anyone's eyes.
A trail looks flat under a headlamp because the light sits at or above your eyes, so every shadow it casts falls behind the obstacle, exactly where you cannot see. Without a visible shadow, a root can look like a dark stripe of dirt. Move a second light below eye level, to your hip, and part of each shadow becomes visible, so roots and rocks stand out again.
The geometry, simplified to flat ground with the light and your eyes in one vertical line: an obstacle of height h at distance d, lit from height H, throws a shadow h × d ÷ (H − h) long. Your eyes, at height E, cannot see a strip h × d ÷ (E − h) long behind it. The visible shadow is the difference.
If the light is at or above your eyes (H ≥ E), its shadow is never longer than the strip your eyes can't see, so the visible shadow is zero. That is the flat look of a trail under a headlamp, and extra lumens can't fix it.
For heights, this guide uses the 50th-percentile standing values in the FAA's Human Factors Design Standard, Chapter 14 (HFDS 2003, amended October 2009, from DOD-HDBK-743A data). Eye height is taken as tragion height, 162.4 cm for men and 150.4 cm for women, because the HFDS glossary says the Frankfort plane "is established by line passing through the tragion (the cartilaginous notch at the front of the ear) and the lowest point of the eye socket." Chest height is suprasternale height (143.7 cm and 132.9 cm). Hip height uses buttock height (88.5 cm and 83.7 cm) as a stand-in for a waistband light.
This table applies the formula to three obstacle heights 3 m ahead of you; each cell gives the visible shadow for the 50th-percentile man, then woman.
| Obstacle 3 m ahead | Headlamp (at or above the eyes) | Chest light (suprasternale height) | Hip light (buttock height) |
| 5 cm root | 0 cm | 1.3 cm / 1.4 cm | 8.4 cm / 8.7 cm |
| 10 cm rock | 0 cm | 2.8 cm / 3.0 cm | 18.5 cm / 19.3 cm |
| 20 cm step or ledge | 0 cm | 6.4 cm / 7.1 cm | 45.5 cm / 48.2 cm |
Check the 10 cm row for the man by hand. Hidden strip: 0.10 × 3 ÷ (1.624 − 0.10) = 0.197 m. Hip-light shadow: 0.10 × 3 ÷ (0.885 − 0.10) = 0.382 m. Visible shadow: 0.382 − 0.197 = 0.185 m, or 18.5 cm. The chest light gives 0.10 × 3 ÷ (1.437 − 0.10) = 0.224 m, so only 2.8 cm shows. The hip light shows about 6.7 times as much shadow as the chest light.
The ranking holds if your waistband light sits higher: at 1.0 m, the 10 cm rock still shows 0.10 × 3 ÷ 0.90 − 0.197 = 0.136 m of shadow. Running posture and uneven ground change the numbers, so treat the table as a comparison of positions, not a prediction.
Put the second light as low as you can keep it steady and aimed, which for most runners means a waistband or hip belt. By the geometry above, a hip light shows about 6.7 times as much shadow as a chest light. A handheld light sits lower still, but its aim swings with your arm.
- Hip or waistband: the most visible shadows. Clip the Oclip 2 Pro to webbing up to 14 mm thick and tilt the head until the floodlight lands a few steps ahead.
- Chest or vest strap: easy to reach, but close to eye height, so it adds brightness more than shadow.
- Hand: low and easy to aim into corners, but the beam swings with every arm stride.
Safety note: A clip light worn on the body sits close to your chest or abdomen. The Oclip 2 user manual says, "If you have an ICD or pacemaker, avoid close or prolonged contact with this product to prevent possible interference." If that applies to you, carry the second light in your hand or ask your doctor first.
The manual also says, "Do not put a hot light into any type of fabric bag or fusible plastic container," so let the light cool before you pocket it.
Two light sources also give you redundancy. Our caving headlamp guide recommends three independent lights underground for the same reason. On a trail you can get by with two, as long as they share no battery.
For trail running at night, plan on about 100 lumens from the headlamp on smooth trail and a combined 200 to 500 lumens on technical ground, split between the head and a hip light. Ragnar's Trail Guide sets a lower bar for its relays: "We recommend one with 70 lumens or more." More lumens from the forehead alone brighten the ground without adding shadows.
The split matters more than the total: 100 lumens from the Perun 3 Mini plus 100 from the Oclip 2 Pro puts 200 lumens on the trail from two heights, and drains each light more slowly, as the battery section shows.
This table sets a lighting target for each part of a night trail run, with the Olight modes that meet it.
| Sub-scenario | Head light target | Second light target | Runtime to plan | Water rating to want | Olight modes |
| Smooth fire road | 100 lm | Off or 10 lm | Stretch length plus 50% | IPX6 or better | Mini Medium; Oclip 2 Pro Low |
| Technical climb or single-track | 100 lm | 100 lm | Stretch length plus 50% | IPX6 or better | Mini Medium; Oclip 2 Pro Medium |
| Technical descent | 350 to 500 lm, short | 300 lm, short | High for the descent only | IPX6 or better | Mini High; Oclip 2 Pro High |
| Fog or mist | 10 lm or off | 100 lm | Until the fog clears | IPX6 or better | Mini Low; Oclip 2 Pro Medium |
| Start to sunrise | 100 lm, then 10 lm | 10 to 100 lm | Until you pass the last tree cover after civil twilight begins | IPX6 or better | Mini Medium, then Low |
| Creek crossings and heavy rain | 100 lm | Held clear of water | Crossing only | IPX7 or better for anything that may go under | Mini (IPX8) or Perun 3 (IP68) |
| Aid stations and passing others | Red, 5 to 45 lm | Off | Short | Any | Mini red; Oclip 2 Pro red |
The "plus 50%" margin is this guide's planning rule, not a rating: it covers a slower-than-planned night, and Olight's runtimes are measured at room temperature.
Plan modes by terrain, not by how dark it feels: Medium on the head for runnable trail, the hip light added for technical ground, a short High for descents, the head light down in fog, and a staged switch-off at dawn.
Smooth Fire Road
Run the Perun 3 Mini on Medium (100 lumens, 4.5 hours) and the hip light on Low (10 lumens, 25 hours) or off. This is where you bank battery.
Technical Climb
Keep the head on Medium and turn the hip light to Medium (100 lumens, 3 hours 45 minutes). The low beam draws the shadows the headlamp can't.
Technical Descent
On a descent you move faster, so a missed rock costs more. Hold the Mini on High (500~350 lumens) and the hip light on High (300~100 lumens, 60 + 5 minutes). The manual notes that "High is memorized as Medium if the interval is over 1 minute," so if you switch off at the bottom for longer than that, it comes back on in Medium. RRCA's trail running tips, linked in the checklist below, add the etiquette: "Uphill runners yield to downhill runners in most situations." When you meet someone, drop your beam to their feet.
Fog and Mist
In fog, a bright headlamp lights the droplets between your eyes and the trail. The National Weather Service gives drivers the same warning about high beams in its fog safety tips: "Using high beam lights causes glare, making it more difficult for you to see what's ahead of you on the road." Turn the headlamp down to Low (10 lumens) or off, and let the hip light carry the trail on Medium. By the heights above, a waistband light sits 1.624 − 0.885 = 0.74 m (men) or 1.504 − 0.837 = 0.67 m (women) below eye level, so its light enters the fog below your line of sight.
In cold fog, note the Oclip 2 manual: "In environments below 0°C (32°F), the white light is limited to Low and Medium modes." The Perun 3 Mini and Perun 3 manuals list a working temperature of 0-40°C.
Start to Sunrise
For a run that ends in daylight, the sky and tree cover set the switch-off, not the clock. The U.S. Naval Observatory's twilight definitions say that "before the beginning of civil twilight ... artificial illumination is normally required to carry on ordinary outdoor activities." At civil twilight (Sun 6 degrees below the horizon), drop the head to Low, switch off once you can read rocks without it, and keep the hip light on under trees.
Aravaipa Running's 2026 Coldwater Rumble runner guide shows how thin that line can be: "You will begin your race just as civil twilight hits the horizon so it's possible to start your race sans headlamp but it's your call- you'll be on a trail 100 yards into the race."
Creek Crossings and Rain
The Perun 3 Mini is rated IPX8 and the Perun 3 IP68, but the Oclip 2 Pro is IP66 and its manual says not to immerse it. Before a deep crossing, unclip the hip light and hold it high.
Warning: The Oclip 2 user manual says, "Do not look directly at the light source or shine it into your eyes, as this may cause temporary blindness or permanent damage to your eyes." On a narrow trail, tilt both lights down before you turn to talk to a running partner.
A second light lets the headlamp stay on Medium through climbs instead of High, so both lights finish a run with about half their charge. For the 90-minute night run modeled below, the Perun 3 Mini used alone on High for technical ground needs about 77% of a charge; with the Oclip 2 Pro on the hip, the Mini uses about 49% and the Oclip 2 Pro about 51%.
Method: minutes on each mode ÷ Olight's rated runtime, added up per light, with stepped High modes as one total (77 minutes for the Mini, 65 for the Oclip 2 Pro). The example run: 30 minutes of fire road, a 30-minute technical climb, a 20-minute descent and 10 minutes of fog.
This table shows the share of a full charge each light uses on each stretch, based on Olight's rated runtimes, not measured.
| Stretch (minutes) | Headlamp only: Perun 3 Mini | Two lights: Perun 3 Mini on head | Two lights: Oclip 2 Pro floodlight on hip |
| Fire road (30) | Medium: 30 ÷ 270 = 11.1% | Medium: 30 ÷ 270 = 11.1% | Low: 30 ÷ 1,500 = 2.0% |
| Technical climb (30) | High: 30 ÷ 77 = 39.0% | Medium: 30 ÷ 270 = 11.1% | Medium: 30 ÷ 225 = 13.3% |
| Technical descent (20) | High: 20 ÷ 77 = 26.0% | High: 20 ÷ 77 = 26.0% | High: 20 ÷ 65 = 30.8% |
| Fog or junctions (10) | Low: 10 ÷ 1,800 = 0.6% | Low: 10 ÷ 1,800 = 0.6% | Medium: 10 ÷ 225 = 4.4% |
| Total used | 76.6% | 48.8% | 50.5% |
| Reserve at 100 lm afterward | 23.4% × 270 = about 63 min | 51.2% × 270 = about 138 min | 49.5% × 225 = about 111 min |
The reserve row is the point. After a wrong turn or a rolled ankle, the headlamp-only runner has about an hour of Medium left; the two-light runner has over two hours on the head and almost two more on the hip.
Note: Olight's tables were "tested per ANSI/PLATO FL 1-2019 standard in Olight's labs for reference" (the manual cites the 2019 edition; the current edition is FL 1-2025), and the Perun 3 Mini manual says the tests "are performed indoors under a room temperature of 25 degrees celsius with windless conditions." Cold nights and older cells shorten real runtimes, so treat the reserve as a best case.
The best headtorch for trail running meets the same tests as a headlamp: light on the head, 100 lumens for longer than the run, an immersion rating for wet hills, and a second torch lower down. "Headtorch" is the British term. On UK fell races, the organiser decides whether a torch is required, so check each race page as well as your kit.
The Fell Runners Association's Requirements for Runners 2026 says "Additional Race Organiser requirements may include, for example, a thermal layer, a bivvy bag, a torch, water etc." The FRA calendar entry for the Hathersage Night Race on November 13, 2024 (8 km, 400 m of climb, 19:00 start) states: "Head torch and full FRA kit required."
On wet hills, the Perun 3 Mini's IPX8 and the Perun 3's IP68 earn their keep; keep the IP66 Oclip 2 Pro out of streams and bogs.
Night trail running races differ widely in what they require, from a required headlamp at a relay to two headlamps at a mountain ultra, and some shorter races list nothing at all. Read your own race's current rules, because the wording decides whether a built-in-battery light or a single light passes a kit check.
This table quotes each organizer's own wording, names the race and year, and translates it into what to pack.
| Race and year (source) | Official wording | Required or advised | What to pack with the setup in this guide |
| Ragnar Trail relays (official packing list, linked from the 2026 race pages) | "Headlamp (required)," plus "Back-up headlamp," "Hand flashlight" and "Extra batteries" on the same list | Headlamp required; the rest listed | Perun 3 Mini plus a charged spare cell, with the Oclip 2 Pro as the second light |
| Lavaredo Ultra Trail by UTMB, 120K and 80K (list posted for the June 2027 event) | "headlamp with spare batteries or two headlamps with batteries" | Mandatory | Two head-worn lights, or one headlamp plus spare cells |
| Lavaredo Ultra Trail by UTMB, 50K (same page) | No headlamp in the mandatory list | Not listed | A light anyway if you may finish after dark |
| Hathersage Night Race, FRA calendar, 2024 | "Head torch and full FRA kit required." | Required | Headlamp, hip light and full FRA kit |
| Coldwater Rumble 100M and 100K (Aravaipa runner guide, 2026) | "Do not get caught out on the trail between aid stations without a headlamp! Bring an extra and be prepared to run through the night from 6pm until after 7am." | Strongly advised | Perun 3 for the 13-hour night, Mini or Oclip 2 Pro as the extra |
Ragnar's packing list is linked from each trail race page, such as the 2026 Ragnar Trail Arizona page, and its Trail Guide carries the lumen advice quoted above. Lavaredo's mandatory equipment page warns that organizers "may modify the list of mandatory equipment" up to 12 hours before the start.
Olight lists the Oclip 2 Pro with a 600 mAh battery that recharges by USB-C or MCC and no spare cell, so count it as your second light, not your "spare batteries," and recheck rules in race week.
A steady beam comes from a light head unit, a snug band set before you start, and a second light that takes work off your forehead. Moving brightness to the hip means the headlamp can run on Medium and stay small, which does more for bounce than cranking the band tighter.
- Fit the band to a jog. Jog 50 m, then adjust the band and tilt.
- Replace a stretched band. The Headband for Perun Series costs $9.99 for the Perun 3 Mini headband, the page's default option; it also lists Perun 3, Perun 2 Mini and Perun Mini bands.
- Fix pressure and slipping. See our guide to headlamp comfort.
Three lighting mistakes make night trails harder than they need to be, and each has a quick fix. Each comes from treating the headlamp as the whole system, not as one part of a plan with a second light and set modes.
- Turning the headlamp up to fix a flat-looking trail. More lumens from eye height add brightness, not shadow. Add a hip light instead.
- Climbing on High to see better. In the battery table above, one 30-minute climb on High took 39% of the Mini's charge. Keep the head on Medium and turn on the hip light.
- Dunking a splash-rated light. IPX6 and IP66 lights are for rain, not creeks. Hold the Oclip 2 Pro clear of the water.
Tip: Practice every button move in a dark room before the run: Medium to High, Turbo and back, red light from off (double press on the Perun 3 Mini), and lockout (press and hold about 2 seconds from off). The Mini's manual describes each of these, and lockout stops the light from turning on inside a pack.
Use this list the day before and at the trailhead. It turns the geometry, mode plan and battery math above into a routine, and adds the safety steps RRCA and the National Park Service recommend for being out after dark.
- Charge both lights (under 90 minutes for the Perun 3 Mini, per its manual), then set the head to Medium and the hip light to Low.
- Tell someone your route. RRCA's trail running tips say: "Let at least one other person know where you are planning to run and when you expect to return." The NPS Ten Essentials page adds: "Be sure to tell someone where you're going and when to expect you back."
- Carry a map and a phone. The same RRCA page warns: "don't depend on your cellphone, as you may have no cellular service once on the trail."
- Be visible. RRCA's runner safety tips say: "Wear reflective clothing or a lighted vest when running in the dark."
- Lose the headphones on quiet trails. RRCA's trail tips: "No headphones when running in the dark on quiet trails."
- Know your fallback. If one light fails, the other gets you home. The NPS notes that "Lighting is important in the outdoors at night, and can help you find your way out or signal for help."
For the road half of a night run, see our routine for how to run at night safely. Pick your trail running headlamp by the job in the gear list at the top, then add the hip light before you add lumens.
