Olight makes the lights discussed here. Olight specs and regular prices come from its US product pages and user manuals as of September 2026. Lux estimates, runtime budgets and costs below are calculations from those published ratings, not measurements.
The best emergency flashlight setup for a power outage has three layers: one rechargeable flashlight per person, a lantern-style light for each room you share after dark, and a hands-free light for the kitchen and breaker panel. Add one AAA backup that never needs charging. On Olight's ratings, that kit covers a 72-hour outage without a recharge.
Most outage plans fail in small ways. The flashlight is in a drawer nobody can find, the batteries leaked last spring, or one bright beam blinds the room while everyone else sits in the dark. This plan puts a light in each room, shows how much light each one puts where you need it, and counts how long the set lasts.
This table is the power outage flashlight kit in one view: the job, the type of light, the minimum rating to look for and one Olight model that meets it.
| Job | Recommended type | Minimum rating to look for | Olight example (regular price, September 2026) |
| Personal light, one per person | Rechargeable pocket flashlight with a lockout | 10+ lumens for 24+ hours; IPX7 or better | Baton 4: 12 lm for 35 h, IPX8, button lock ($54.99) |
| Shared room light | Lantern, or a flashlight under a diffuser | 100+ lumens in all directions for 24+ hours | Marauder Mini 2 with Lampshade: 150 lm for 27 h ($219.99 + $9.99) |
| Hallway and bathroom marker | Small glow light with a magnetic base | Low mode that runs several nights | Sphere C: 1 lm for 40 h ($17.99) |
| Kitchen and breaker panel | Magnetic clip light with a tilting head | 100 lm with a hands-free mount | Oclip 2 Pro: 100 lm for 3 h 45 min, magnets, 115° tilt ($54.99) |
| Backup that needs no charging | Single-AAA flashlight | Takes batteries you already stock | i3T 2 EOS: 5 lm for 21 h per AAA ($19.99) |
- 1. What Lights Do You Need for a Power Outage?
- 2. What Kind of Flashlight Is Best for a Power Outage?
- 3. Room-by-Room Emergency Lighting Plan
- 4. Why Is a Lantern Better Than a Flashlight Indoors?
- 5. How Many Flashlights Should a Household Have?
- 6. Should I Store Batteries Inside the Flashlight?
- 7. How Long Will One Set of Emergency Lights Last in a 72-Hour Outage?
- 8. How Do Power Banks, Generators and Candles Fit the Plan?
- 9. Your Power Outage Lighting Checklist
- 10. FAQ
You need a personal flashlight for each household member, one diffused room light for each space you use after dark, and a hands-free light for cooking and repairs. Ready.gov's power outage guidance says, "Have flashlights for every household member." A backup light on standard batteries covers the day a charger or cable goes missing.
The same page (last updated June 4, 2026) also says to "Plan for batteries and other alternative power sources to meet your needs when the power goes out, such as a portable charger or power bank." That sentence is the second half of this plan: the lights, then the power to keep them running.
The three layers solve three different problems. A personal light moves with you, so nobody gropes along a wall. A room light spreads low, even light, so the family can eat, read and find things without pointing a beam at each other. A hands-free light frees both hands for a pot, a breaker or a sump pump. Browse Olight's outdoor and camping lights for room and hands-free options, and its EDC flashlights for the personal layer.
The best flashlight for a power outage is a rechargeable LED light with a low mode that runs a full day or more, a switch lock, and an immersion rating of IPX7 or higher. Brightness matters less than runtime: a 12-lumen mode rated for 35 hours carries you through three nights, while a 1,300-lumen turbo lasts minutes.
Four checks separate an emergency flashlight from a drawer flashlight:
- A long low mode. Look for 10 to 60 lumens rated for 8 hours or more. You will use it far more than turbo.
- A lockout. A light that switches on inside a bag is flat when you need it. Per its user manual, the Baton 4 locks with a 2-second hold while it is off, and a locked Baton 4 shows its battery level with one press, so the storage check never turns the beam on.
- A charge path without a wall outlet. USB-C or a cable you can run from a power bank.
- Water resistance. Storm outages mean rain, flooded yards and wet hands.
The Olight Baton 4 ($54.99 for OD Green, the page's default color, regular price, September 2026) passes all four. Olight rates it at 1,300 lumens and 170 m, IPX8, 52.5 g, with Turbo 1,300~600~300 lumens for 1.5 + 2.5 + 73 minutes, High 600~300~60 lumens for 7 + 72 + 16 minutes, Med 60 lumens for 8 hours, Low 12 lumens for 35 hours and Moon 0.5 lumens for 30 days. Its manual lists a charge time of about 1 hour. The limit: the standard edition charges only through its MCC magnetic cable, so keep that cable with your power bank. The Premium Edition's case can also charge it, and Olight says the case "can fully charge the Baton 4 flashlight 5 times."
Give each room one job and one light. Bedrooms get a personal flashlight on the nightstand. Hallways, stairs and bathrooms get a glow marker. The living room gets one diffused lantern-style light. The kitchen and breaker panel get a magnetic clip light. The yard gets the beam of a personal flashlight on high, used in short bursts.
For a yardstick, the 2021 International Fire Code, section 1008.3.5, says for code-required exit paths: "Emergency lighting facilities shall be arranged to provide initial illumination that is not less than an average of 1 footcandle (11 lux) and a minimum at any point of 0.1 footcandle (1 lux) measured along the path of egress at floor level." That rule governs exit routes in buildings covered by the code, not the rooms of a private home, but 1 lux and 11 lux are useful targets for a dark hallway.
The table below asks a practical question: how far from each light does it still meet those two targets? Distance equals the square root of candela divided by the target lux. For a directional flashlight, candela is scaled from Olight's peak rating in proportion to lumens, which assumes the beam keeps its shape at lower output, and the distance applies to the center of the beam. For a light that shines in all directions, candela is lumens divided by 4π, treating it as an even point source. These are estimates based on Olight's rated figures, not measured, and they ignore light bounced off walls.
This scenario table shows the light, mode, estimated reach and rated runtime for each room.
| Room and task | Light and mode | Estimated intensity | Meets 11 lux out to | Meets 1 lux out to | Rated runtime at that mode | Rating |
| Living room table | Marauder Mini 2 in Lampshade, 150 lm floodlight | 150 / 4π = 11.9 cd | 1.0 m (3.4 ft) | 3.5 m (11.3 ft) | 27 hours | IPX8 |
| Hallway walk to the bathroom | Baton 4 Low, 12 lm | 7,225 × 12 / 1,300 = 67 cd | 2.5 m (8.1 ft) | 8.2 m (26.8 ft) | 35 hours | IPX8 |
| Hallway lit for a group | Sphere C White High, 75 lm, stepping to 22 lm | 6.0 cd, then 1.75 cd | 0.74 m, then 0.40 m | 2.4 m, then 1.3 m | 100 + 150 minutes | IP56 |
| Hallway marker left on overnight | Sphere C White Low, 1 lm | 0.08 cd | Not reached | 0.28 m (11 in) | 40 hours | IP56 |
| Bedside, finding glasses | Baton 4 Moon, 0.5 lm | 2.8 cd | 0.50 m (1.6 ft) | 1.7 m (5.5 ft) | 30 days | IPX8 |
| Kitchen counter | Oclip 2 Pro Medium, 100 lm floodlight | Not estimated; Olight lists no floodlight candela | Not estimated | Not estimated | 3 hours 45 minutes | IP66 |
Two findings stand out. First, a 12-lumen beam meets the 11-lux average out to about 2.5 m, one long stride ahead of a walker, so Low is enough for a hallway and it runs 35 hours. Second, a 1-lumen marker meets even the 1-lux minimum only within about 28 cm of the globe. It is a locator, not a path light: it shows where the doorway is, and the personal flashlight does the rest.
Bedrooms
Each sleeper needs a light within reach before their feet touch the floor. Keep the Baton 4 locked on the nightstand, and teach everyone the one press that checks the battery. Moon mode at 0.5 lumens is enough to find glasses without waking a partner.
Safety note: The U.S. Fire Administration's candle safety page says, "Don't use lit candles in bedrooms, bathrooms and sleeping areas." NFPA's candle fire statistics for 2020 to 2024 report that sleep "was a factor in 11% of home structure candle fires, 34% of candle fire deaths, and 17% of candle fire injuries."
Hallway, stairs and bathroom
The hallway is the route you walk half-asleep. The Olight Sphere ambient light ($17.99 for the Stellar Sky Sphere C, the page's default option, regular price, September 2026) is a 93 g globe with a magnetic base, rated IP56 and 1.5 m drop-resistant. The Sphere C runs White Light High at 75~22 lumens for 100 + 150 minutes, White Low at 1 lumen for 40 hours and Red Light Low at 0.5 lumens for 25 hours. The limit is output: at 75 lumens it is a marker and a nightlight, not a room light. Olight also notes that the Sphere C does not include a USB-C cable, so pack one in the outage bag. Its manual warns, "Do not store the product in a car or places where the temperature may exceed 60°C," and labels it a "Non-pet toy."
Cooking by flashlight fails because you need both hands. The Olight Oclip 2 Pro clip light ($54.99 for Tidal Blue, the page's default option, regular price, September 2026) has tail and clip magnets, a 115° head tilt and a clip that grips objects up to 14 mm thick. Stick it to a range hood or a steel breaker panel door and aim the 100-lumen floodlight (3 hours 45 minutes) at the work. Low floodlight runs 10 lumens for 25 hours, and red light 4 lumens for 27 hours.
Its manual adds limits worth knowing. "In environments below 0°C (32°F), the white light is limited to Low and Medium modes," which matters in an unheated winter house, and it "cannot be charged in environments below 0°C or above 45°C," so recharge it in the warmest room. It says, "Do not immerse the product in water or other liquids," so keep it out of standing water despite its IP66 rating. And: "If you have an ICD or pacemaker, avoid close or prolonged contact with this product to prevent possible interference." If anyone in your home has one, mount the Oclip on a surface rather than clipping it to a shirt pocket.
Living room
The shared room needs even light for hours. The Olight Marauder Mini 2 flashlight ($219.99 for Stonewashed Stars and Stripes, the page's default option, regular price, September 2026) carries a 27.75 Wh battery. Olight rates its floodlight at 150 lumens for 27 hours or 50 lumens for 83 hours, and its 5-lumen side light for 10 days. Olight's $9.99 Lampshade, a 63 by 115 mm white polypropylene shade listed for the Marauder Mini 2, turns it into a table lantern. Our reach estimate ignores light the shade absorbs, so treat the 1.0 m figure as an upper limit and set the light near the middle of the table.
The limits are cost and weight: $229.98 with the shade and 465 g. The manual's runtime tables are based on "ANSI/NEMA FL 1-2009," an older edition than the current FL 1-2025, and it auto-locks: "When the flashlight is turned off and no operation is performed within 10 seconds, the lockout mode will be activated automatically."
Yard, garage and generator check
Outside, you want reach, not spread. A Baton 4 on Turbo reaches Olight's rated 170 m, enough to check a fallen limb or a downed line from a safe distance. Use it in bursts: Turbo steps down after 1.5 minutes. Never walk toward a downed line; CDC's page on what to do during a power outage (last reviewed August 26, 2026) says, "Never touch a fallen power line."
A lantern is better indoors because it spreads light in every direction at low output, so the whole table is lit and nobody gets a beam in the eyes. A flashlight packs its output into a narrow cone: the Baton 4's 7,225 candela peak is about 600 times the 11.9 candela a 150-lumen lantern sends in any one direction.
That concentration is great for reach and bad for a dinner table. Point a Baton 4 on Med at the ceiling and you get a bright spot and deep shadows; set it on the table and someone is looking into it. The Oclip 2 manual warns, "Do not look directly at the light source or shine it into your eyes, as this may cause temporary blindness or permanent damage to your eyes."
If you have no lantern, stand a flashlight on its tail under a white shade or a translucent jug so the plastic scatters the beam, and keep it on Low or Med.
Tip: Keep the room light at table height or hang it above the table, not at eye level. A light below or above sight lines lights faces and hands without glare.
A household should have one flashlight per person, one room light for each space used after dark, and one backup on standard batteries. For a family of four using a living room, kitchen and hallway, that is 4 + 3 + 1 = 8 lights. Ready.gov's one-flashlight-per-member rule sets the floor at four, and one shared room light makes five.
This table applies the count to four common households and prices two versions for the family of four with Olight's regular September 2026 prices.
| Household | Personal lights | Room lights | Backup | Total |
| One adult, studio apartment | 1 | 1 (living and kitchen together) | 1 | 3 |
| Couple, one-bedroom apartment | 2 | 2 (living room, hallway) | 1 | 5 |
| Family of four, one story | 4 | 3 (living room, kitchen, hallway) | 1 | 8 |
| Family of four, two stories | 4 | 4 (add the stairway) | 1 | 9 |
Pricing the family-of-four kit shows where the money goes. The full version uses four Baton 4 lights ($219.96), a Marauder Mini 2 with Lampshade ($229.98), a Sphere C ($17.99), an Oclip 2 Pro ($54.99) and an i3T 2 EOS ($19.99), for $542.91. A lean version swaps the Marauder Mini 2 and shade for a fifth Baton 4 set under a diffuser: $542.91 − $229.98 + $54.99 = $367.92. The trade: a Baton 4 room light runs 60 lumens for 8 hours instead of 150 lumens for 27, so it needs a recharge every one to two evenings.
Safety note: Young children should use their light with an adult nearby, and small lights belong out of reach when not in use. The i3T 2 EOS manual says, "Do not give the product to children to play with, in order to avoid accidental swallowing," and the Sphere C manual says to keep new and used batteries away from children.
If you can only start with one light, our best budget flashlight guide explains why a $55 pocket light is the first buy. Families on a strict budget can start with the AAA-based kit in our survival kit under $100 build and add rechargeable lights later.
Not for flashlights that run on alkaline AA or AAA cells: take the battery out when the light goes into long-term storage. The i3T 2 EOS user manual says, "For long-term storage, please remove the battery." Rechargeable lights with built-in or custom cells are different: keep the battery in, charge it fully and lock the switch.
Four rules cover every light in this plan:
- Primary-cell lights: battery out, battery taped to the light. Store the AAA in its retail pack beside the i3T 2 EOS in the same bag, so it is there when you need it.
- Rechargeable lights: charged and locked. The Oclip 2 manual says, "Charge the product completely before storing it for a long period," and, "If the product is carried or transported, please lock it."
- Match the battery to the manual. The i3T 2 EOS manual lists "1 x 1.5V AAA alkaline battery (included)," "1 x 10440 lithium battery" and "1 x AAA NiMH battery." Olight's product page adds that a protected 10440 with a maximum length of 44 mm "can boost the maximum output up to 300 lumens."
- Keep spare lithium-ion cells cool and clear. The U.S. Fire Administration's battery safety page says, "You should store lithium-ion batteries at room temperature when possible," and, "Store spare lithium-ion batteries away from anything that can burn."
Note: An alkaline cell left in a light for months can leak and corrode the contacts. For humid climates, our guide to hurricane supplies storage covers airtight bins, desiccant and where in the house the kit should live.
If you would rather recharge AAA cells than buy them, the i3T 2 EOS accepts NiMH AAAs, and Olight's Ostation Series AAA pack holds four 950 mAh NiMH cells for $5.49 (regular price, September 2026). The Olight Ostation 2 battery station ($139.99 for the Ostation 2 Pro, the page's default option, regular price, September 2026) stores 12 AA and 12 AAA cells and charges two of each at a time. Its manual says, "DO NOT use the device at temperatures below 32°F (0°C)," and, "This product is intended for indoor use only." Olight lists the Pro's input as "PD 3.0 12.0V-1.5A," so during an outage it needs a power bank or car charger that offers 12 V USB-C PD output; a basic 5 V bank will not match that listed input.
On Olight's ratings, the room-by-room kit lasts a 72-hour outage with no recharge and a 7-day outage with about 9 Wh of top-up energy. The daily use is modeled on a December night in Columbia, South Carolina, and the set draws about 7.1 Wh a day against about 42 Wh stored in the lights at the start.
How long outages run sets the target. The U.S. Energy Information Administration reported on December 1, 2025 that U.S. customers "experienced an average of 11 hours of electricity interruptions in 2024," and that South Carolina customers had longer interruptions than any other state, "at nearly 53 hours in 2024," after Hurricane Helene. Those are yearly totals averaged across customers, not the length of any single outage, and customers in states such as Arizona averaged less than two hours. They still show that a bad storm year can add up to days without power, which is why this plan is sized for 72 hours and checked against seven days. Ready.gov's kit page puts it plainly: "After an emergency, you may need to survive on your own for several days."
The schedule comes from the U.S. Naval Observatory's sun and moon data for Columbia on December 21, 2026: civil twilight ends at 5:47 p.m. and begins at 6:58 a.m. With an assumed 10 p.m. bedtime and 6:30 a.m. wake-up, the household is awake in the dark for 4 h 13 min in the evening plus 28 min in the morning, 4.68 hours in all, and asleep in the dark for 8.5 hours.
This table turns that schedule into a daily energy budget. Average power is the battery's rated energy divided by the rated runtime of the mode used.
| Light and mode | Battery energy | Average power | Use per day | Energy per day | Days per charge | Charges for 7 days |
| Marauder Mini 2, 150 lm floodlight, 27 h | 27.75 Wh | 27.75 / 27 = 1.03 W | 4.68 h | 4.81 Wh | 5.8 | 1.21 |
| Sphere C, White Low 1 lm, 40 h | 0.7 Ah × 3.7 V = 2.59 Wh | 0.065 W | 8.5 h | 0.55 Wh | 4.7 | 1.49 |
| Four Baton 4 lights, Med 60 lm, 8 h | 2.34 Wh each | 0.29 W each | 1 h each | 1.17 Wh | 8.0 | 0.88 |
| Oclip 2 Pro, Medium 100 lm, 3 h 45 min | 2.22 Wh (600 mAh, 3.7 V, per its manual) | 0.59 W | 1 h | 0.59 Wh | 3.75 | 1.87 |
| Whole kit | 41.92 Wh stored | 7.13 Wh |
Three days use 3 × 7.13 = 21.4 Wh, and no single light runs out: the shortest, the Oclip 2 Pro, lasts 3.75 days. Over seven days, three lights run short: the Marauder Mini 2 by 5.9 Wh, the Sphere C by 1.3 Wh and the Oclip 2 Pro by 1.9 Wh, about 9.1 Wh in all before charging losses. That is about a third of the 27.75 Wh the Marauder Mini 2 alone holds, so one small power bank covers the lights with room left for phones.
Two cautions keep the numbers honest. The Baton 4, Sphere C and i3T 2 EOS manuals cite ANSI/PLATO FL 1-2019, and the Marauder Mini 2 manual cites ANSI/NEMA FL 1-2009 at a room temperature of 25 °C; a cold house or an aging battery shortens real runtime, and our guide to flashlight runtime shows how much. Battery energy comes from the Baton 4 and Oclip 2 manuals, the Marauder Mini 2 spec sheet, and the Sphere C's listed 3.7 V, 700 mAh cell.
Tip: Run lights one step lower than you think you need. Dropping the four Baton 4 lights from Med to Low (12 lumens, 35 hours) stretches each charge from 8 to 35 hours of use, and the hallway estimate above shows Low still meets the 11-lux mark a stride ahead.
A power bank recharges the lights; a generator runs outside and only outside; candles stay in the drawer. CDC says to "Use battery-powered flashlights and lanterns, rather than candles, gas lanterns, or torches to minimize the risk of fire," and warns that generator exhaust can kill with carbon monoxide.
This table sets each backup source against what it can safely do during an outage and the rule that governs it.
| Source | What it does in this plan | Rule to follow | Source of the rule |
| Power bank | Recharges USB-C lights, the MCC cable and phones indoors | Charge lithium-ion devices above 32°F and below 105°F | U.S. Fire Administration |
| Portable generator | Runs a fridge or charges banks during daylight | "Never use a generator, pressure washer, or any gasoline-powered engine inside your home, basement, or garage or less than 20 feet from any window, door, or vent." | CDC |
| Carbon monoxide alarm | Warns if exhaust gets indoors | "When using a generator, use a battery-powered or battery backup CO detector in your home." | CDC |
| Fuel lantern or camp stove | Not used indoors | "Never use a charcoal grill, hibachi, lantern, or portable camping stove inside a home, tent, or camper." | CDC |
| Candles | Not used | "Use flashlights, not candles, if you have a power outage." | U.S. Fire Administration |
The CDC lines come from the same power outage page cited in the yard section above. Ready.gov adds that "Generators and fuel should always be used outdoors and at least 20 feet away from windows, doors and attached garages," and to "Install carbon monoxide detectors with battery backup in central locations on every level of your home."
Warning: Charge the lights from a power bank indoors, not from the generator's outlet in a wet yard. Ready.gov warns, "Touching a wet generator or devices connected to one can cause electrical shock."
A practical rhythm for a long outage: charge power banks from the generator or a car while it is light out, then recharge the lights from the banks indoors after dark. The Baton 4 standard edition needs its MCC magnetic cable for that, and the Marauder Mini 2's manual lists about 3.5 hours for a full USB-C charge, so start it early in the day.
Set up your emergency flashlight plan in one afternoon with the list below. Each step ties back to a table in this guide, so you can check it against your own rooms and spec sheets before the next storm, and every light should be charged or stocked before you put it away.
- Count lights: one per person, one per room used after dark, one AAA backup.
- Put a personal flashlight on every nightstand, locked, and show everyone the battery check.
- Place a marker light in the hallway and bathroom, and a diffused light where the family gathers.
- Stick a magnetic light near the breaker panel and the stove.
- Take alkaline cells out of stored lights and keep them in retail packs beside each light.
- Charge every rechargeable light fully, then recheck when the clocks change.
- Keep one power bank charged, with the MCC and USB-C cables in the same bag.
- Keep candles, fuel lanterns and generators out of the plan indoors, and fit battery-backup CO alarms.
For a one-page version of the whole home kit, our printable camping checklist includes a 72-hour home emergency list you can print.
