Olight sells some of the gear discussed here. Olight specs and regular prices come from its US product pages and user manuals as of October 2026. Night lengths come from U.S. Naval Observatory data. Runtime, cost and brightness figures are calculations from those published numbers, not field measurements.
In night vision vs thermal for hog hunting, thermal wins the search: it finds warm pigs in brush edges, tall grass and full darkness without any light. Digital night vision with an IR illuminator wins the confirmation, because it shows shape, terrain and what sits behind the hog. If you can buy only one, buy thermal to find pigs.
You hear the sounder before you see it: grunts and snapping stalks on the far side of a brushy fence line. A spotlight would scatter them. Your night vision shows a white wall of mesquite leaves 10 yards away and nothing beyond it. Your partner's thermal shows two warm blobs in a gap, then nothing. Here is why, and how to split the work.
This table sums up night vision vs thermal for hog hunting on the jobs that decide a hog night.
| Job on a hog night | Thermal imaging | Digital night vision + IR | Who wins | By how much |
| Finding pigs at the edge of brush | Shows body heat in gaps between leaves | Near leaves reflect IR and wash out the view | Thermal | Large in brush, small in open pasture |
| Seeing in total darkness | Needs no light at all | Needs an IR illuminator | Thermal | Thermal works with zero added light |
| Telling a hog from a calf, dog or person | Shape and heat, little surface detail | Shape, texture and fences | Night vision | Clear edge once the target is in IR range |
| Seeing what is behind the target | Shows warm things only | Shows the backstop, fences and roads | Night vision | Decisive for a safe shot |
| Entry cost from Olight | TS004 at $499 | Odin IR at $169.95 plus a scope | Night vision is cheaper to start | Thermal adds $499 to any night vision kit |
- 1. Quick Answer: Which Should You Buy for Hogs?
- 2. Thermal Monocular vs Night Vision: How Each Sees a Hog
- 3. Seeing Pigs Through Brush: What Actually Happens
- 4. Night Vision vs Thermal for Hog Hunting by Terrain: Brush, Corn and Open Pasture
- 5. Are Thermals Better Than Night Vision?
- 6. Which Is Better for Hunting, Night Vision or Thermal Scope?
- 7. What Night Vision Scope Is Best for Hog Hunting?
- 8. The Scan, Confirm, Shoot, Recover Workflow
- 9. Will One Charge Last a Texas Winter Night?
- 10. What Does Each Setup Cost?
- 11. Who Should Choose Thermal, Night Vision or Both?
- 12. Texas Rules for Night Hog Hunting
- 13. Test It Yourself: A Brush Visibility Check
- 14. Your Hog Night Checklist
- 15. FAQ
Buy thermal first if you hunt brushy country, creek bottoms or field edges, because heat shows up where reflected light does not. Add digital night vision with an IR light if you shoot at night, because it gives a clearer view of the target and its background. You can also pair them: a handheld thermal for scanning, night vision on the rifle for the shot.
Texas Parks and Wildlife credits night optics for gains in hog control. Its wild pig ecology and management page says "Night vision optics and the recent increase in use of sound suppressed rifles has greatly enhanced the success of this method." The same page adds a warning about cover: "Night shooting is highly effective in agricultural fields, but its efficacy also declines as vegetation density increases and wild pig density decreases."
Olight's range of thermal imaging monoculars is sold under its OSelect line, and the model this guide uses for the math is the TS004 thermal imaging monocular. For the night vision side, the Olight Odin IR rail-mount light adds an infrared beam to a white weapon light. Olight does not sell a night vision scope, so that part of a kit comes from another maker.
Thermal and night vision read two different kinds of energy. A thermal monocular reads the long-wave infrared that warm surfaces give off, so a hog shows up because it is warmer than the grass. Digital night vision reads reflected light, including near-infrared from an illuminator, so a hog shows up only when enough light lands on it and bounces back to the sensor.
The TS004 lists a spectral range of "7.5~14 μm" on its product page. Its user manual describes the range a little differently, saying "Infrared detectors mainly detect 8 to 14μm long-wave infrared areas, and can only be used to measure surface temperature."
Night vision works in the near-infrared, at much shorter wavelengths. The Odin IR manual lists its infrared output as "IR LIGHT( WAVELENGTH 850NM )," which is 0.85 μm.
This table compares the two methods on the traits that matter in a hog field.
| Trait | Thermal (TS004 example) | Digital night vision with IR (Odin IR example) |
| What it detects | Long-wave infrared from warm surfaces, 7.5 to 14 μm per the product page | Reflected near-infrared light, 850 nm from the Odin IR |
| Needs added light | No | Yes, in true darkness |
| What a hog looks like | A bright or dark shape, depending on the palette | A gray-scale animal with hair, ears and legs |
| What stops it | Any solid surface between you and the hog | Any surface that blocks or reflects the beam first |
| Main weakness in brush | Leaves hide the heat behind them | Near leaves glare and hide the scene behind them |
Neither device sees through a solid screen of leaves. Thermal shows heat that reaches the lens through gaps, so a pig appears in pieces and in motion. Night vision fails differently: the IR beam hits the nearest leaves first, and those close leaves can come back far brighter than a hog farther out. Knowing which failure you face tells you where to stand.
The TS004 page says it "effectively penetrates fog and dense vegetation." Read that as finding heat through gaps in cover and light fog, not through leaves. Its manual says the detectors "can only be used to measure surface temperature," so a leaf shows at leaf temperature and a hog behind a solid screen of leaves stays hidden. The manual answers a related question directly: asked whether the TS004 can see "underwater, through glass or through a wall," it says "No."
That still gives thermal a real edge in brush. A warm patch only a few pixels wide stands out against cool leaves, and a hog that moves flickers from gap to gap. Scan slowly and watch for heat that blinks in and out of the same spot. Our guide to the thermal monocular for deer recovery covers searching thick cover on foot.
Why near branches wash out a night vision view
An IR illuminator spreads its beam over a larger area the farther the light travels, so close objects get far more light per square foot than distant ones. For a beam from a single source, light per area falls with the square of the distance.
This table keeps one IR setting fixed and compares the light landing on near leaves with the light landing on a hog 50 yards out, using the square of the distance ratio.
| Leaves at | Hog at | Calculation | Light on the leaves vs the hog |
| 2 yards | 50 yards | (50 / 2)² = 25² | 625 times as much |
| 5 yards | 50 yards | (50 / 5)² = 10² | 100 times as much |
| 10 yards | 50 yards | (50 / 10)² = 5² | 25 times as much |
| 25 yards | 50 yards | (50 / 25)² = 2² | 4 times as much |
These numbers are geometric estimates, not measured. They ignore how well leaves and hog hair reflect 850 nm light, and they assume the same beam reaches both. The pattern still holds: a branch 2 yards from your muzzle gets hundreds of times more light than the hog. Our IR illuminator guide uses the same rule for a different question, how far each power level reaches.
Tip: Move so the nearest leaves sit outside the beam, or step to a lane where the first cover is at least half the distance to the pigs.
Terrain decides which device carries the night. In brush and creek bottoms, thermal finds pigs that night vision misses behind near leaves. In standing corn, both lose sight inside the rows, so you work the edges. In open pasture and freshly rooted fields, either works, and night vision's clearer picture of the background becomes the bigger advantage.
Texas Parks and Wildlife's management page says that when available, wild pigs "will select for agricultural crops, often making up over 50% of the vegetative portion of their diets."
This table matches each terrain to the device that does the main work.
| Terrain | What blocks your view | Thermal role | Night vision role | Where to set up |
| Mesquite or brush line | Leaves at many depths | Main scanner; watch gaps for moving heat | Confirm once a hog steps into a gap or clearing | Back off the brush so the nearest leaves are well out in front |
| Standing corn | Stalks in every direction | Watch field edges and the end rows | Confirm hogs as they leave the rows | Downwind corner where trails enter the field |
| Harvested or rooted field | Little or nothing | Fast first sweep of the whole field | Main view for target and background | Field edge with a safe backstop behind the hogs |
Thermals are better than night vision at finding animals, and night vision is better at showing detail. Thermal needs no light, shows heat in brush gaps and spots a warm hog in full darkness. Night vision with an IR light shows a clearer picture of the animal, its surroundings and what lies behind it. For hogs, better depends on the job you need done.
For detection, thermal leads. The TS004 lists a detection distance of 410m and an identification distance of 91m, without stating the target size. The product page puts the second number another way, promising "clear detail visibility within 100 yards," and 100 yards is about 91.4 m, so the two statements line up.
For identification and shot safety, night vision has the edge. Thermal shows a warm outline on a palette of white hot, black hot, red hot, bird or fusion. It does not show fence wire, a cool steel gate or a dark road behind a hog. A reflected-light image does.
For hog hunting, a thermal scope is better when hogs hide in cover and a night vision scope is better on open fields with clear backstops and a budget limit. The stronger answer is a split setup: a handheld thermal to search, a night vision scope with an IR light on the rifle to confirm and shoot. That way neither device has to do both jobs.
The 330 g TS004 is a handheld monocular, not a weapon sight, so you can sweep a field without lifting a rifle. Texas Parks and Wildlife says night vision optics and suppressed rifles let hunters "remove large portions of wild pig populations, whole sounders in some cases, at one time in large open terrain." Our guide to the best rifle light for hog hunting covers spill, light color and switch placement for the shooter's side.
The best night vision scope for hog hunting is one that holds zero under your rifle's recoil, runs a full winter night on its batteries, and works with a separate IR illuminator you can turn down in brush. Olight does not make night vision scopes, so judge any model on those three points, then add an illuminator such as the Odin IR if the scope's built-in IR falls short.
Use this checklist when you compare night vision scopes for hogs:
- Recoil rating for your caliber. Check the maker's manual for the calibers it covers.
- Battery life against your night. A December night in South Texas runs close to 14 hours, as shown below.
- An external IR option. A separate light lets you choose beam power and mount position.
- Mount fit. The scope and the IR light both need rail space without blocking each other.
The Odin IR covers point 3: it comes with a Picatinny mount, so it rides on its own rail section, apart from the scope. The manual says you select modes "By rotating the ring at the head of the flashlight to select IR (infrared ray only), OFF, WH (white light only)." IR High is 150 mW for 22.5 hours and IR Low is 30 mW for 91 hours, per Olight's specs.
In brush, the 30 mW Low setting can keep close leaves from glaring; save 150 mW for open fields. The limit: Olight rates IR output in milliwatts only, so you cannot compare its reach with a scope's built-in IR.
Warning: The Odin IR manual says "DO NOT shine the light directly into human eyes. This may cause temporary blindness, or permanent damage to the eyes." It also says "Keep out of reach of children," and to "unscrew the tailcap and remove the battery to cut off the circuit" before long storage or transport.
A hog night goes best in four stages: scan with thermal, confirm with night vision or white light, shoot only with a clear target and backstop, then recover with thermal again. Each stage has one main device and a fallback.
This table assigns each stage to a device, using the TS004 and Odin IR as examples.
| Stage | Main device | What you are doing | Fallback | Settings to use |
| 1. Scan | Thermal monocular | Sweep field edges and brush gaps for warm shapes | Night vision on open ground | TS004 at 1x zoom, a palette you read quickly |
| 2. Confirm | Night vision scope + IR | Check species, size, other animals and people | White light if legal and needed | Odin IR on IR Low in brush, IR High in the open |
| 3. Shoot | Night vision scope | Fire only with the hog and its background clear | Hold the shot | Same IR level; spotter keeps watching on thermal |
| 4. Recover | Thermal monocular | Find a downed hog and watch for any that stayed | White light for the last steps | TS004 at 2x or 4x to check outlines |
Stage 2 is where accidents are prevented. Thermal shows warmth, and calves, dogs and people are warm. The TS004 lists an AI algorithm that "can identify people and vehicles." Treat that as an extra alert, not a safety system: no alert replaces your own look at the target and what lies beyond it.
For a second set of eyes in Stage 1, the TS004 connects to a phone through the TopInfrared app for live viewing, so a partner can watch the thermal feed while the shooter stays on the scope.
No, not if the TS004 stays on from sunset to sunrise in December. On the U.S. Naval Observatory's figures for San Antonio, the night of December 21 to 22, 2026 runs 13 hours 45 minutes, while Olight rates the TS004 at 11 hours. Switch it off between scans, or plan a top-up of roughly one hour (a straight-line estimate), and one unit covers the night.
This table compares night lengths from the U.S. Naval Observatory sun and moon data service for San Antonio (29.42° N, 98.49° W) with the TS004's rated 11-hour battery life. Times are local: CST in December, CDT in June.
| Night in San Antonio | Dark period | Length | TS004 rated runtime | Gap |
| Dec 21 to 22, 2026 | Sunset 17:40 to sunrise 07:25 | 6 h 20 min + 7 h 25 min = 13 h 45 min | 11 h | 2 h 45 min short |
| Dec 21 to 22, 2026 | Civil twilight 18:06 to 06:59 | 5 h 54 min + 6 h 59 min = 12 h 53 min | 11 h | 1 h 53 min short |
| Jun 20 to 21, 2026 | Sunset 20:37 to sunrise 06:35 | 3 h 23 min + 6 h 35 min = 9 h 58 min | 11 h | 1 h 02 min spare |
A winter night is 13 h 45 min minus 9 h 58 min = 3 h 47 min longer than a summer one.
Two ways close the gap, both based on Olight's rated figures, not measured:
- Power it down between scans. 11 ÷ 13.75 = 0.80, so if the TS004 is on no more than 80% of the night, about 48 minutes of each hour, the rated battery covers sunset to sunrise.
- Top it up mid-hunt. The manual says "It takes about four hours to get TS004 fully charged." If charging ran at a steady rate, 2.75 h of missing runtime would need 2.75 × 4 ÷ 11 = 1.0 hour on a USB power source. Olight does not publish the charging curve, so treat this as a rough plan.
The Odin IR's 22.5-hour IR High rating covers the 13 h 45 min night with 22.5 − 13.75 = 8.75 hours to spare, based on Olight's rated runtime, not measured. Its manual lists a full charge at "5.5 hours," marked "For reference only," and says to "Only charge with standard MCC3, not compatible with other MCC." Check your scope's own battery life too.
Note: The TS004 manual says to charge it "via the USB-A to USB-C cable," so a USB power bank and that cable are the simplest recharge plan.
Warning: The TS004 page lists IP67, yet its manual says "Keep the thermal monocular away from water to avoid electricity leakage or short circuit." The Odin IR page lists IPX8, yet its manual says "The tail switch may not work while immersed in sea water or other conductive media." Keep both out of creeks and dry them after rain.
At Olight's regular prices, a thermal-first setup starts at $499 for the TS004. A night-vision-first setup starts at $169.95 for the Odin IR plus the price of a night vision scope from another maker. A full split setup costs $668.95 plus that scope.
This table builds three entry setups from Olight's regular prices as of October 2026. "Scope price" stands for whatever night vision scope you choose.
| Setup | Olight items | Olight regular price | Other items you add | Total |
| A. Thermal scan only | TS004 thermal monocular | $499 | A white weapon light you already own | $499 |
| B. Night vision shoot only | Odin IR rail-mount light | $169.95 | Night vision scope | $169.95 + scope price |
| C. Split: scan + shoot | TS004 + Odin IR | $499 + $169.95 = $668.95 | Night vision scope | $668.95 + scope price |
Going from B to C costs $668.95 − $169.95 = $499, the price of the TS004. Going from A to C costs $169.95 plus your scope.
For other models at this price point, see our guide to the thermal monocular under $500.
Choose thermal if you hunt brush, creek bottoms or large ranches where finding hogs is the hard part. Choose night vision with an IR light if you sit over open fields with good backstops and want the lower entry cost. Choose both if you hunt with a partner, run a control program, or shoot where livestock, dogs or people may be near.
This table matches hunters to the setup that fits them best.
| You are | Choose | Why | Watch out for |
| A rancher checking brushy pastures | Thermal (Setup A) | Finds heat in gaps and covers ground fast | Confirm targets before any shot near livestock |
| A farmer sitting over a rooted field | Night vision + IR (Setup B) | Clear target and background on open ground | Near brush at the field edge can glare on High |
| A two-person hog control team | Both (Setup C) | Spotter scans, shooter confirms and fires | Agree on calls and stages before dark |
| A hunter on the tightest budget | Night vision + IR (Setup B) | $169.95 for the Olight part | Brush will limit what you can see |
In Texas, landowner authorization is the key condition for hunting feral hogs on private land without a license. Texas Parks and Wildlife says "No hunting license is required to hunt feral hogs on private property with landowner authorization," and "Hunter Education requirements apply." Rules change, so read the current pages each season.
These lines come from TPWD's Outdoor Annual page on nongame and other species, under "Feral Hogs and Coyotes." The same page says "Transportation and release of live feral hogs is unlawful, unless in compliance with Texas Animal Health Commission (TAHC) regulations." For nongame animals it adds: "If hunting at night, as a courtesy please contact your local game warden." It also makes it unlawful to hunt "any wild animal or wild bird on a public road or the right-of-way of public roads."
Rules on night hunting, lights and optics differ by state. Our guide to hunting with a light laws compares states. Check your own state wildlife agency's current regulations before you use thermal or night vision.
You can check how your own devices handle brush with a warm jug, measured distances and two looks per distance. We have not run this check ourselves; it is a plan for you. Do it after dark on land you control, with no firearm in hand, and record what each device shows.
This table lays out a simple self-check and what to write down each time.
| Step | Setup | What to record | Repeats |
| 1. Pick a target | A sealed jug of hot tap water behind a brush line | Air temperature and whether the brush is wet or dry | Once per night |
| 2. Mark distances | 25, 50 and 75 yards from the brush, paced or measured | Exact distance from you to the brush and to the target | Once |
| 3. Thermal look | Thermal at 1x, then 2x | Visible, partly visible or not visible; how many gaps show heat | Twice per distance |
| 4. Night vision look | IR Low, then IR High | Same three grades; note glare from near leaves | Twice per distance |
| 5. Move the brush closer | Stand 2, 5 and 10 yards from the brush line | Whether glare gets worse on IR High as you close in | Twice per distance |
If night vision shows the jug from 25 yards back but not from 5 yards back, you have found foreground glare in your own gear.
Safety note: The TS004 manual says "Do not point the thermal monocular at the sun or other strong energy sources for a long period of time. Otherwise there might be damage to the detector in the monocular." Keep the lens away from campfires and truck headlights during the check.
This checklist turns the night vision vs thermal for hog hunting choice into a plan for tonight. Work through it in order before you leave the truck, so you know what each device does, when it runs out and who calls the shot.
- Choose by terrain. Brush and creek bottoms: thermal first. Open fields: night vision with IR. Mixed ground or two hunters: both.
- Do the runtime math. Look up tonight's sunset and sunrise for your location. If the night is longer than 11 hours, plan scan breaks or a TS004 top-up of about an hour.
- Set the IR level. IR Low for brush and close cover, IR High for open ground.
- Get permission in writing. In Texas, landowner authorization is the condition for hunting hogs without a license.
- Call the game warden. TPWD asks night hunters of nongame animals to call as a courtesy.
- Agree on the four stages. Scan, confirm, shoot, recover, with one person calling and one shooting.
- October 31, 2026: First published.
