Olight makes some of the lights discussed here. Olight specs and regular prices come from its US product pages and user manuals as of September 2026; the Nitecore figures come from Nitecore's own product page. Every runtime-per-step, sag and display figure below is a calculation from published numbers, not a measurement.
An OLED flashlight shows battery state on a small screen, often as runtime, voltage or output, while indicator LEDs show it in steps. A screen is better when you plan a shift to the hour. Four to seven indicator LEDs are enough when you only need "charge tonight or not." Both estimate from battery voltage, so neither is exact under heavy load or in the cold.
The pain is familiar. Before a night shift or a trail, two green dots glow and you cannot tell whether that means five hours or two. Then you hear that screens drain the battery or crack when dropped. This guide checks which lights carry which readout, works out how much runtime one step hides, and ends with a home check.
This table sums up how an OLED flashlight screen compares with indicator LEDs, using the published specs of the lights covered below.
| Dimension | Screen (Olight Marauder 3, Nitecore EDC29) | Indicator LEDs (Seeker 4 Pro, Warrior 3S, Marauder Mini) | Which is better | By how much |
| Resolution | A number: remaining runtime, or voltage and lumens | 4 to 7 steps, 10 to 25 percentage points each | Screen | One step hides about 2 to 6.6 hours at a working mode |
| Accuracy under load and cold | Estimated from the battery | Estimated from the battery | Tie | Both shift with voltage sag |
| Water rating | IPX8 (Marauder 3); IP54 (EDC29) | IPX8 on all three | Indicator lights in this set | IPX8 vs IP54 for the EDC29 |
| Rated drop | 1 m on both | 1.5 m on all three | Indicator lights in this set | 0.5 m |
| Planning a shift | Reads hours at the current brightness | Needs a quick calculation | Screen | Saves the math, not the uncertainty |
| Regular price | $369.99 (Marauder 3) | $119.95 to $199.99 | Indicator lights | $170 to $250 less |
- 1. Quick Answer: Is an OLED Flashlight Worth It for Battery Readouts?
- 2. Which Olight Flashlights Have a Battery Display or Indicator?
- 3. Three Ways a Flashlight Shows Battery: Single LED, Multi-Step LEDs and a Screen
- 4. How Does a Flashlight Estimate Battery Level? Voltage Curves and Load
- 5. How Much Runtime Hides Inside One Indicator Step?
- 6. Does a Flashlight Screen Increase Standby Drain?
- 7. Why Does the Battery Number Jump on High Output?
- 8. Flashlight OLED Display vs Indicator LEDs: Accuracy, Drops, Water and Cold
- 9. Common Mistake: Red Means the Light Is About to Die
- 10. Who Should Choose a Screen and Who Should Choose Indicator LEDs?
- 11. Which Flashlight Do Navy SEALs Use?
- 12. Is a 200,000 Lumen Flashlight Legal?
- 13. Why Is There So Much Hate on Olight?
- 14. OLED Flashlight Test: Check Your Own Readout in One Evening
- 15. FAQ
An OLED flashlight is worth it if you plan work by the hour and want a readout in runtime or volts instead of a color. For most carry and outdoor use, a four-step indicator does the job. On Olight's ratings, one step on the Seeker 4 Pro hides about 2.75 hours at 300 lumens, which is fine for deciding whether to charge tonight.
The bigger truth is that every readout is an estimate. Battery University says voltage-based state of charge "can be inaccurate because cell materials and temperature affect the voltage" (BU-903). A screen makes the estimate look precise, not exact. The same page warns, "Much of the make-believe is hidden behind a fancy readout."
Olight's current range of flashlights does not include a model it calls an OLED flashlight. It does sell one light with a numeric display, the Marauder 3, and several with micro-perforated indicator LEDs. If you mostly want to know how long a battery will really last, our guide to flashlight runtime explains why rated hours and real hours differ.
Among the five Olight lights checked for this guide, only the Marauder 3 has a numeric display, which Olight calls a "laser micro-perforated display" that shows remaining runtime. The Seeker 4 Pro and Warrior 3S use four-step battery indicators, the Marauder Mini uses seven steps, and the Baton Ultra shows battery indicator segments without published percentages. None is sold as OLED.
This table lists what each maker publishes about its battery readout, with the steps copied from the user manuals and product pages.
| Light | Readout type | Steps and thresholds (as published) | Low-battery warning | Water and drop rating | Source |
| Olight Seeker 4 Pro | 4 hidden LEDs, lowest turns red | 75% or more; 50% to 75%; 25% to 50%; 10% to 25%; red below 10% | Red below 10% | IPX8, 1.5 m | User manual, Figure 15-2 |
| Olight Warrior 3S | 4-level LEDs by the side switch | 75% or more; 50% to 75%; 25% to 50%; 10% to 25% | Lowest right indicator glows red below 10% while on | IPX8, 1.5 m | User manual |
| Olight Marauder Mini | 7-step LED arc | 85%, 75%, 60%, 45%, 30%, 15% or more; below 15% | Not stated as a separate color | IPX8, 1.5 m | User manual correlation table |
| Olight Marauder 3 | Numeric display plus 7-step LED arc | 85%, 71%, 57%, 42%, 28%, 14% or more; below 14%; red below 7% | Red below 7% | IPX8, 1 m | User manual |
| Olight Baton Ultra | Micro-perforated battery and brightness indicators | Percentages not published | Not published | IPX8, 2 m | Product page gallery and user manual |
| Nitecore EDC29 | OLED display | Shows brightness level, lumen output, remaining runtime, battery voltage, lockout status | Not listed on the product page | IP54, 1 m | Nitecore product page |
The Olight Seeker 4 Pro ($139.99, regular price, September 2026, for every listed color, Matte Black CW by default) is the clearest four-step design. Olight says "1,200 laser micro-pierced holes create new hidden brightness and battery indicators while still keeping IPX8 waterproof." Its manual adds that "In lockout mode, pressing the side switch will display the remaining battery level." It is rated at 4,600 lumens and 260 m, with Medium at 300 lumens for 11 hours.
The Olight Warrior 3S ($119.95, regular price, September 2026, Black or OD Green; Dream Blue is listed at $119.99) lists "4-level battery and brightness indicators around the side switch." It is rated at 2,300 lumens, 23,000 candela and 300 m, with Medium at 200 lumens for 13 hours.
The Olight Marauder 3 ($369.99, regular price, September 2026, for each color) is the screen light. Olight says its display "dynamically updates estimated runtime as brightness changes." It is rated at 25,000 lumens, 250,000 candela and 1,000 m, weighs 840 g and carries a 118 Wh built-in battery.
The Olight Marauder Mini ($199.99, regular price, September 2026, Black by default) uses a seven-step LED arc, with 7,000 lumens, 600 m and a 24 Wh battery at 462 g. The Olight Baton Ultra ($99.99, regular price, September 2026, Olive Green; the Baton 4 Pro on the same page is $69.99) is the pocket pick at 115 g, 1,800 lumens and 300 m. Its product page shows "micro-perforated brightness and battery indicators, plus a new lockout icon," but neither the page nor the manual lists what each segment means, so treat it as a rough gauge.
A single indicator LED changes color at one or two thresholds, a multi-step indicator lights more dots as charge rises, and a screen prints a value. All three read the same battery estimate. The difference is how finely they slice it: a single LED splits the battery into two or three zones, four steps into five, seven steps into eight, and a screen into many.
Single LED. Usually green above a threshold and red below it. It tells you only whether to charge.
Multi-step LEDs. The Seeker 4 Pro, Warrior 3S and Marauder Mini light one dot per band. Olight's Seeker 4 Pro manual says that while charging, "the battery level indicators on the dashboard will be dynamically illuminated. Once it is fully charged, all battery level indicators will be lit."
Screens. The Nitecore EDC29 product page says its "multifunctional OLED display" can show "brightness level, lumen output, remaining runtime, battery voltage, and lockout mode status." The U.S. Department of Energy describes an OLED as "a solid-state device consisting of a thin, carbon-based semiconductor layer that emits light when electricity is applied by adjacent electrodes" (DOE OLED basics). In a flashlight, OLED refers only to the display. The beam still comes from ordinary LEDs.
A simple gauge estimates battery level from cell voltage; more advanced gauges also track current and temperature. Voltage falls as a lithium-ion cell empties, but it also dips under heavy load and in the cold, then recovers. That is why a readout can drop a step on Turbo and come back when you switch to Medium, without any charge returning.
Battery University explains that "The most blatant error of the voltage-based SoC occurs when disturbing a battery with a charge or discharge," and that for accurate readings "the battery needs to rest in the open circuit state for at least four hours." It adds that some lithium-ion chemistries have such flat curves that "80 percent of the stored energy remains in the flat voltage profile," which leaves the middle hard to read. Texas Instruments' fuel-gauge application report SLUA364B states the core problem: usable capacity "is lower at higher rates and low temperatures because the cell I x R drop causes the Terminate Voltage threshold to be reached earlier."
You can size that I x R drop with one cell maker's numbers. Olight does not name the cells inside its customized 21700 batteries, so the example below uses Molicel's INR-21700-P45B, a 4,500 mAh 21700 whose datasheet lists a typical DC impedance of 15 mΩ at 50% charge, a 4.2 V charge voltage and a 2.5 V discharge limit. The currents are the ones on Molicel's own discharge chart.
This table applies voltage drop = current × resistance to that cell. It is a worked example based on Molicel's rated figures, not a measurement of any flashlight.
| Load (from Molicel's chart) | Calculation | Voltage sag | Share of the 4.2 to 2.5 V window |
| 10 A | 10 × 0.015 Ω | 0.15 V | 0.15 ÷ 1.7 = 8.8% |
| 20 A | 20 × 0.015 Ω | 0.30 V | 0.30 ÷ 1.7 = 17.6% |
| 0 °C instead of 23 °C, 4.5 A | Read from the temperature chart | About 0.1 V lower at mid-discharge | About 6% |
Why does a few tenths of a volt matter? On the same datasheet's slowest (0.2C) curve, read approximately from the chart, the cell falls from about 3.7 V to about 3.5 V while delivering roughly 1,000 mAh, about 22% of its 4,500 mAh. So a 0.2 to 0.3 V sag under a high load can look like a fifth of the battery to a voltage-based gauge. That is about one step on a four-step indicator, which is why a step that drops on Turbo is not proof of lost charge. For how cell types differ in voltage and capacity, see our comparison of flashlight battery types.
One indicator step can hide two to six hours of light at a working mode. On Olight's ratings, a 25-point step on the Seeker 4 Pro equals about 2.75 hours at 300 lumens, and on the Warrior 3S about 3.25 hours at 200 lumens. A 14-point step on the Marauder 3 covers about 6.2 hours at 500 lumens.
The math is step width × rated runtime of the mode you actually use. It assumes the battery drains evenly through the mode, which is a simplification, and it uses the low edge of each step as the worst case. To turn that into a go or no-go rule for an 8-hour night shift, divide 8 hours by the rated runtime, then find the lowest indicator state whose lower edge still clears that share.
This table works through both calculations for the four lights with published thresholds. All figures are based on Olight's rated runtimes, not measured.
| Light and working mode (rated) | Step width | Hours inside one step | Share needed for 8 h | Lowest state that guarantees 8 h | Hours guaranteed at that state |
| Seeker 4 Pro, Medium 300 lm, 11 h | 25 points | 0.25 × 11 = 2.75 h | 8 ÷ 11 = 72.7% | Top state (75% or more) | 0.75 × 11 = 8.25 h |
| Warrior 3S, Medium 200 lm, 13 h | 25 points | 0.25 × 13 = 3.25 h | 8 ÷ 13 = 61.5% | Top step (75% or more) | 0.75 × 13 = 9.75 h |
| Marauder Mini, Level 2 flood 200 lm, 21 h | 15 points (one 10-point step) | 0.15 × 21 = 3.15 h | 8 ÷ 21 = 38.1% | 45% or more | 0.45 × 21 = 9.45 h |
| Marauder 3, Level 2 flood 500 lm, 44 h | 14 or 15 points | 0.14 × 44 = 6.16 h | 8 ÷ 44 = 18.2% | 28% or more | 0.28 × 44 = 12.32 h |
The table shows the real weakness of a four-step indicator: the middle reading is wide. On the Seeker 4 Pro, the 50% to 75% state could mean anything from 5.5 to 8.25 hours at Medium, so it cannot promise an 8-hour shift. On the Marauder 3, the display removes the guesswork, because it prints the remaining runtime at the brightness you are using.
On Low the picture changes: the Seeker 4 Pro's 50 lumens for 60 hours needs only 13.3% for 8 hours, so the 25% to 50% state already guarantees 15 hours.
Tip: Write the "share needed" figure for your own shift on a piece of tape inside your holster or case. One glance at the indicator then answers the only question that matters: does it clear the line?
Possibly, but Olight does not publish standby or display current for any of these lights, so no honest number exists. What the manuals do show is that the readouts are not left on: the Seeker 4 Pro's indicators shut off after a few seconds, and the Marauder 3 turns off all indicators except the lock indicator after power-off. A screen that is off cannot draw display power.
The Seeker 4 Pro manual says that when you remove the light from its holster, the indicators "will display the memorized brightness level and the remaining battery level and then turn off after 5 seconds," and the light locks itself "if no operation is made within 10 seconds after the indicators are off." The Marauder 3 manual says: "After powering off, all indicators turn off, and the lock indicator lights up to indicate the device is locked." It also says the display shows remaining runtime "except in Moonlight mode."
You can still bound the electronics' appetite from a rated runtime. The Marauder 3 lists its spotlight Moonlight at 0.5 lumens for 14 months on a 118 Wh battery. Fourteen months is about 14 × 30.44 = 426 days, or about 10,220 hours. 118 Wh ÷ 10,220 h = 0.0115 W, so everything running in that mode, LED included, averages about 11.5 mW, based on Olight's rated figures, not measured. Whatever the display's controller costs at rest must fit under that ceiling.
The number jumps for two reasons. First, a runtime display recalculates for the brightness you just picked, so switching levels changes the reading instantly. Second, high output pulls the battery voltage down, which a gauge can read as lost charge. The Marauder 3 manual also locks out its top levels below 42% battery.
Start with the display. If the Marauder 3's estimate tracks its rated table, a full battery in floodlight mode would read about 168 hours on Level 1 (7 days), 44 hours on Level 2 and 11.7 hours on Level 3 (500 + 200 minutes). Level 4 (4 + 330 + 20 minutes) and Level 7 (2 + 320 + 20 minutes) land close together at about 5.9 and 5.7 hours, because both step down to 3,500 or 3,750 lumens within minutes. Going from Level 2 to Level 4 cuts the reading by 44 ÷ 5.9 = 7.5 times with no charge used. These are estimates based on Olight's rated runtimes, not measured.
Next, the 42% gate. The manual says, "≥42% battery is required to operate L5 and above," and the Marauder Mini warning manual and the Marauder 3 manual both note, "When the battery is at low voltage, the high mode is restricted." So a light that refuses Turbo is often reporting its own rule, not a fault. Heat does the same, as our thermal step down flashlight guide explains.
The Warrior 3S manual adds a third cause in plain words: "The maximum output brightness will decrease as the battery voltage decreases." And near empty, both Marauder manuals say, "It is normal that the light flickers when the battery is close to running out."
Warning: Do not run a high mode with the head covered or face down. The Warrior 3S manual says covering the head while on may "result in the burning of flammable objects nearby," and the Marauder 3 manual says to keep the light "locked out when carrying or transporting to prevent burning accidents caused by abnormal startup."
On the published ratings here, the indicator-LED lights carry better water and drop numbers than the two screen lights: IPX8 and 1.5 m for the Seeker 4 Pro, Warrior 3S and Marauder Mini, against 1 m for the Marauder 3 and IP54 for the Nitecore EDC29. That reflects these products, not a law of screens. Accuracy is a tie, because both read the same battery estimate.
This table compares the durability ratings each maker publishes.
| Factor | Screen lights | Indicator-LED lights | What it means for you |
| Rated drop | Marauder 3: 1 m; EDC29: 1 m | Seeker 4 Pro, Warrior 3S, Marauder Mini: 1.5 m; Baton Ultra: 2 m | Indicator lights here rate 0.5 to 1 m higher |
| Water | Marauder 3: IPX8; EDC29: IP54 | All four Olight indicator lights: IPX8 | Check the rating, not the readout type |
| Working temperature | Marauder 3: 0 to 40 °C | Seeker 4 Pro, Marauder Mini: 0 to 40 °C; Baton Ultra: 0 to 45 °C | Below freezing you are outside Olight's listed range |
On water, IEC explains that the second numeral of an IP code "rates the enclosure's protection against liquids and uses a scale from 0 (no protection) to 9 (high-pressure hot water from different angles)" (IEC IP ratings).
On cold, Battery University notes, "Cold temperature increases the internal resistance and lowers the capacity," and that the loss "will recover in room temperature" (BU-502). So a readout that drops a step on a frozen trailhead may climb back in your pocket. The indicator dots themselves are LEDs, which DOE lists as having "good performance in cold temperatures" (DOE LED basics). For a full pre-trip routine covering water, cold and drops, see our guide to outdoor flashlights.
Red does not mean seconds left. On the Seeker 4 Pro and Warrior 3S, red means below 10%; on the Marauder 3, below 7%. At a low mode that is still hours of light. The real risk is different: on the Marauder lights, high modes are restricted at low voltage, so a long-reach beam may not be there.
On Olight's ratings, on the Warrior 3S, 10% of the 130-hour Low mode is about 13 hours at 15 lumens. On the Seeker 4 Pro, 10% of the 60-hour Low mode is about 6 hours at 50 lumens. On the Marauder 3, 7% of the 44-hour Level 2 floodlight is about 3.1 hours at 500 lumens. These are linear estimates based on Olight's rated runtimes, not measured, and output may sag near the end.
The opposite mistake costs more: reading a middle state as "plenty" before an 8-hour shift, which the step table shows the Seeker 4 Pro and Warrior 3S cannot promise at Medium. If a light shows red and still will not respond, work through our flashlight not working checks before assuming a dead battery.
Safety note: The Warrior 3S manual warns, "DO NOT shine the light directly into human eyes. This may cause temporary blindness, or permanent damage to the eyes." Check a readout with the head pointed at the ground, not at your face.
Choose a screen if you plan by the hour: night-shift security, search teams on long callouts, or anyone running a big light from a vehicle. Choose indicator LEDs if you mainly need "charge tonight or not," want a higher drop rating, or carry the light in a pocket. Among current Olight lights, only the 840 g Marauder 3 offers a runtime display.
This table matches common users to the readout and the Olight light that fits, with the limit to know.
| You are | Better readout | Olight pick (regular price, September 2026) | Why | Limit |
| Night-shift worker planning 8 to 12 hours | Runtime display | Marauder 3, $369.99 | Reads hours at the current level; 44 h at 500 lm | 840 g; 1 m drop rating; 0 to 40 °C |
| Patrol or duty carry | 4-step LEDs | Warrior 3S, $119.95 | 13 h at 200 lm; red warning below 10% while on | Middle step spans about 3.25 h at Medium |
| Camp, yard and household | 4-step LEDs | Seeker 4 Pro, $139.99 | Shows level on unlock or in lockout; wall-mount holster charges it | 205 g; MCC3 cable sold separately |
| Search or vehicle kit with a finer gauge | 7-step LEDs | Marauder Mini, $199.99 | 15-point steps; spot and flood | 462 g |
| Pocket EDC | Basic battery segments | Baton Ultra, $99.99 | 115 g, 18 h 30 min at 120 lm, USB-C and MCC3 charging | Segment thresholds not published |
Here Olight is not the right answer: if you want a pocket light that prints volts or minutes, Olight does not list one today. The Nitecore EDC29 does, with an IP54 and 1 m rating to weigh.
No public U.S. Navy source names a standard handheld flashlight for SEALs, so any brand list you see online is unconfirmed. For a battery readout, the duty-relevant questions are the ones you can check yourself: does the light warn before it gets low, does it lock out in a holster, and is its water and drop rating stated by the maker?
Two current Olight lights answer those directly in their manuals. The Warrior 3S lights its lowest right indicator red below 10% while on, and its manual says, "Please lock out the switches if the flashlight is left unused, carried, or transported." The Seeker 4 Pro locks automatically 10 seconds after its indicators go off.
We found no U.S. federal rule that caps how many lumens a handheld flashlight may produce. The federal aiming law that exists covers lasers: 18 U.S.C. § 39A(a) reads, "Whoever knowingly aims the beam of a laser pointer at an aircraft in the special aircraft jurisdiction of the United States, or at the flight path of such an aircraft, shall be fined under this title or imprisoned not more than 5 years, or both."
That text is on Cornell's Legal Information Institute, and it applies to laser pointers, not LED flashlights. Where a bright light could break a law is in how it is used, such as glare toward drivers or state hunting rules, so check your state and local rules before you aim one near a road, an aircraft or game.
Most criticism of Olight centers on customized batteries and magnetic chargers, frequent sale pricing, and a 2022 recall. The battery point ties directly to readouts: because many Olight cells are proprietary or built in, owners rely on the light's own indicator instead of a standard charger's display. Several current models answer that with documented indicators and auto-lockout.
The recall is a matter of record. The CPSC recall notice says M2R Pro and Warrior Mini lights "can be turned on inadvertently and overheat while stored in the holster or a consumer's pocket, posing a burn hazard to consumers," and covered about 215,100 units. Current manuals respond with lockout: the Seeker 4 Pro locks itself after 10 seconds, and the Marauder 3 lights a lock indicator after power-off.
The battery and price complaints are fair trade-offs to weigh. If proprietary cells are a dealbreaker, that is a valid reason to look elsewhere.
You can run a simple OLED flashlight test, or an indicator test, at home with a full charge, a timer and a notebook. Run the light on the mode you use most, log the readout every 10 minutes, and compare when each step changes with the rated runtime. The gap shows how your gauge behaves.
- Charge fully, unplug, and let the light rest for an hour.
- Pick your working mode, such as Medium on a Seeker 4 Pro or Warrior 3S, or Level 2 on a Marauder 3.
- Stand the light on a hard, non-flammable surface with the head pointing at a wall several feet away. Never leave it covered or unattended.
- Every 10 minutes, record the readout: dots lit, or the number on the screen.
- Note the time each step drops. On a four-step light at Medium, expect roughly 2.75 to 3.25 hours per step on Olight's ratings.
- Switch to Turbo for 30 seconds, read the indicator, then return to Medium and read it again a minute later. A temporary drop is voltage sag.
- Repeat once in a cold garage or porch, staying within the maker's working range, to see the cold shift.
Warning: The Marauder 3 manual says, "Do not leave the light in a car or any place where the temperature may exceed 60°C," and "Do not charge at temperatures below 0°C." It also says, "Keep away from babies and children." The Baton Ultra and Marauder 3 manuals both warn, "Do not immerse the flashlight in seawater or other corrosive media as it will damage the product."
Your readout checklist before any long night:
- Divide your hours of need by the rated runtime of your working mode.
- Trust only a state whose lower edge clears that share.
- Read the indicator at rest and warm, not right after Turbo or in the cold.
- Treat red as "switch to Low and charge soon," and lock the light before carrying it.
- September 26, 2026: First published.
