Olight makes the lights compared here. Olight specs and regular prices come from its US product pages and manuals as of September 2026. Clearance, shadow and balance figures are geometry based on published numbers, not field measurements. This is general information, not legal advice.
A rifle light for night hunting belongs on the handguard at a 45-degree offset or at 3 or 9 o'clock, with the bezel near the muzzle, not at 12 o'clock under the scope. On most scoped rifles the Olight Odin S is the best all-round pick. The Odin wins on reach, and the Odin Mini wins on weight. Check your state's current rule first.
This table compares the three Olight choices for a rifle light for night hunting on the points that matter under a scope, using Olight's rated specs and regular prices as of September 2026.
| Dimension | Olight Odin | Olight Odin S | Olight Odin Mini | Which is better | By how much |
| Peak intensity | 22,500 cd, 300 m | 15,600 cd, 250 m | 14,400 cd, 240 m | Odin | 6,900 cd more than the Odin S |
| Maximum output | 2,000 lumens | 1,500 lumens | 1,250 lumens | Odin | 500 lumens more than the Odin S |
| Weight with battery | 216 g | 193 g (192 g in the Picatinny manual) | 176 g | Odin Mini | 40 g lighter than the Odin |
| Backup power | Custom 21700 only | Custom 18650 or two CR123A | Custom 18500 only | Odin S | Only one that runs on store-bought cells |
| Switch in the box | Magnetic remote switch | Pressure switch with LO and HI buttons | ROD-7 magnetic remote switch | Odin S with gloves | Low and High on separate buttons |
| Regular price | $159.95 | $149.99 | $139.95 | Odin Mini | $20 less than the Odin |
You bolt a light to the top rail, look through the scope, and part of the objective lens is looking at the back of a flashlight. You move it to the side, and your gloved thumb can't find the switch. And nobody at the counter can say whether your state allows a light on a rifle at night. This guide takes those problems one at a time.
- 1. What Is the Best Flashlight for Hunting Rifles?
- 2. Scope-Clearing Mount Positions: 12 O'Clock, 45-Degree Offset, or 3 and 9
- 3. How Far Forward Should a Rifle Light Sit to Avoid Barrel Shadow?
- 4. Best Rifle Light for Hunting Under a Scope: Odin vs Odin S vs Odin Mini
- 5. Does a Weapon Light Make a Scoped Rifle Front-Heavy?
- 6. Pressure Switch or Thumb Switch: Which Is Easier With Gloves?
- 7. What Type of Light Is Best for Night Hunting?
- 8. What Color Light Will Not Spook Deer?
- 9. Common Mistakes With a Rifle Light at Night
- 10. Night Hunting Laws and Rifle Lights: Your State's Current Rule Decides
- 11. Rifle Light for Night Hunting Setup: Install and Check Before the First Night
- 12. FAQ
For a scoped hunting rifle, the best flashlight is a weapon light built to ride a rail under recoil, with a remote pressure switch, an IPX8 rating and a head small enough to sit off the top of the handguard. Among Olight's rifle lights, the Odin S suits most scoped rifles because it takes CR123A backups and locks with a screw clamp.
Olight's rail-mounted lights range includes pistol lights, lasers and IR units, but three white-only Odin models fit a rifle with a magnified scope. All three share a 29 mm (1.14 in) head, an IPX8 rating and a remote switch in the box. They differ in reach, length, battery and the switch you press.
This guide leaves the laser models out on purpose. Alabama's hunting rule, quoted in the laws section below, counts "a laser sight" as an attached light source. The FDA says Class IIIa (3R) lasers "can be momentarily hazardous when directly viewed," and Class IIIb (3B) lasers carry an "immediate eye hazard when viewed directly," per its laser hazard classes page. The FAA warns that "Pointing a laser at an aircraft is a federal crime" on its laser safety page. If you run a light-laser combo anyway, read its class label, never let the beam cross a person, a road or the sky, and check your state's rule on lasers.
If you hunt feral hogs in groups and care most about beam spread at a feeder, our guide to the best rifle light for hog hunting covers that side. This guide covers where the light goes, how it clears the scope and barrel, and which switch works in cold hands.
Note: Olight's ratings follow the ANSI flashlight standard, in different editions. The Odin and Odin Mini manuals cite ANSI/NEMA FL1-2009 and the Odin S manual cites ANSI/PLATO FL 1-2019. The current edition is ANSI/PLATO FL 1-2025, which adds "a standardized test method for Short-Duration Elevated Brightness," according to PLATO's publication notice.
On a scoped rifle, mount the light at a 45-degree offset or at 3 or 9 o'clock on the handguard, and push the bezel as close to the muzzle as the rail allows. A 12 o'clock light sits in the path the objective lens looks through unless the scope rides unusually high. Side positions trade that problem for barrel shadow and switch reach.
Light from a distant target reaches your scope in nearly parallel rays, so the objective lens gathers light through a tube in front of it about as wide as the lens. Anything inside that tube blocks part of that light. How visible that is depends on the scope and magnification, so always look through the eyepiece.
The check takes two numbers: the height of the scope's centerline above the rail the light sits on, and the objective lens radius. The light head must stay below the lens's lower edge, which sits at centerline height minus radius.
This table gives the minimum scope centerline height for an Odin-family head at 12 o'clock to clear the lens, using Olight's rated 29 mm (1.14 in) head. Olight does not publish mount height, so add yours on top.
| Objective lens | Objective radius | Head height (minimum) | Centerline needed above the rail |
| 40 mm | 0.79 in | 1.14 in | 1.93 in plus mount height |
| 44 mm | 0.87 in | 1.14 in | 2.01 in plus mount height |
| 50 mm | 0.98 in | 1.14 in | 2.13 in plus mount height |
For a 40 mm scope, 1.14 in plus 0.79 in gives 1.93 in. To find your centerline height, measure from the rail top to the bottom of the objective bell and add half the bell's outside diameter. If you land below the table, a 12 o'clock light is in the lens's path.
This table sets three clock positions against the problems a scope adds.
| Position | Objective lens clearance | Barrel shadow in the scope | Support hand reach |
| 12 o'clock | Poor unless the scope sits very high | Least | Needs a remote switch |
| 45-degree offset (11 or 1 o'clock) | Good; the head drops out of the lens's path | Small, toward the opposite lower corner | Thumb or remote switch |
| 3 or 9 o'clock | Good | On the barrel side of the picture | Remote switch for most grips |
Not sure which slots your handguard has? Our Picatinny vs M-LOK guide covers rail types, adapters and zero shift.
Tip: With the rifle unloaded, look through the scope at its lowest and highest power against a bright wall. A dim crescent or darker edge at low power means the light is in the lens's path. Move it before you zero anything.
Put the bezel at or near the muzzle, or near the end of the suppressor if you run one. The farther back the bezel sits, the narrower the slice of beam that clears the barrel on that side. With the bezel 12 inches behind a fat suppressor, the shadow edge can fall inside a 3x scope's view. At 2 inches back, it stays far outside.
Call the gap between the light's centerline and the nearest surface of the barrel or suppressor g, and the bezel's distance behind the muzzle L. Rays aimed toward the barrel at more than arctan(g ÷ L) hit it before they leave the rifle, so that angle is the clear half-beam on the barrel side.
Your scope shows a narrow cone. Vortex lists the Crossfire II 3-9x40 at 34.1 ft to 12.6 ft of field of view at 100 yards, and the Crossfire II 4-12x40 AO at 24.7 to 8.4 ft. From center to edge at 3x, that is arctan(17.05 ÷ 300) = 3.25°. The same math gives 1.20° at 9x, 2.36° at 4x and 0.80° at 12x.
This table gives the clear half-angle on the barrel side, calculated as arctan(g ÷ L), based on geometry and Vortex's published field of view, not measured.
| Gap to barrel or suppressor (g) | Bezel 2 in behind | Bezel 6 in behind | Bezel 12 in behind |
| 1.00 in | 26.6° | 9.5° | 4.8° |
| 0.75 in | 20.6° | 7.1° | 3.6° |
| 0.50 in | 14.0° | 4.8° | 2.4° |
The shadow edge enters the picture only when the clear angle is smaller than the scope's half-angle. Every cell beats the 3.25° of a 3-9x40 at 3x except one: a 0.50 in gap with the bezel 12 in back gives 2.4°, so the shadow shows on one side at 3x and sits right on the edge at 4x (2.36°).
The figures start from the emitter's center, and a 29 mm bezel is a wide source, so the real edge is soft. The fix costs nothing: move the light forward.
The three Odin-family lights share a 29 mm head and an IPX8 rating, so the choice comes down to reach, length, backup power and your rail. The Odin reaches farthest, the Odin S alone takes CR123A cells, and the Odin Mini is 21 mm shorter than the Odin at 115.5 mm against 136.5 mm. Each ships with a mount for one rail type.
This table collects Olight's rated modes and box contents from the product pages and user manuals, September 2026.
| Rated spec (Olight) | Odin | Odin S | Odin Mini |
| High mode | 2,000 ~ 1,000 ~ 760 ~ 300 lumens, 2 + 9 + 125 + 24 minutes | 1,500~650~300 lumens, 3.5 + 110 + 18 minutes (included battery); 1000~550~300 lumens, 10+45+26 minutes (CR123A) | 1,250~900~700~200 lumens, 6 + 11 + 39 + 14 minutes |
| Low mode | 300 lumens, 8 hours | 300 lumens, 5 hours 10 minutes (included battery); 3 hours (CR123A) | 200 lumens, 5 hours |
| Battery | Custom 5000mAh 21700 | Custom 3500mAh 18650 or two CR123A | Custom 2040mAh 18500 |
| Mount in the box | Slide rail mount with mechanical lock; Pic Rail Adapter | Integrated bracket with screw-locking clamp, M-LOK or Picatinny edition | M-LOK Rail Mount |
| Switch in the box | Magnetic remote switch with stand | Pressure switch and pressure switch mount | ROD-7 switch and RM3R pressure switch mount |
Olight Odin S: Best All-Round Pick for a Scoped Rifle
A dead custom battery ends a cold night early. The Olight Odin S runs on its 18650 or on two CR123A cells through the included holder, at a lower 1000~550~300 lumens. Olight says its screw-locking clamp "offers reliable stability even under intense recoil," and its pressure switch has "a securely fitting screw cap."
The limits: it reaches less far than the Odin, and its manual lists a working temperature of 0~40°C, which a winter stand can fall below. The Odin and Odin Mini manuals list no working temperature at all, so don't read that as a colder rating for them. The default M-LOK Matte Black edition is $149.99. The page listed the M-LOK Desert Tan and Picatinny Matte Black editions as sold out in September 2026, so on a Picatinny rail you wait or pick the Odin.
Olight Odin: More Reach for Long Fields
Long fields need intensity more than output. The Olight Odin has the highest candela here at 22,500 and ships with a Pic Rail Adapter; for M-LOK, Olight's M-LOK Rail Mount ($29.95) lists the Odin as compatible. The limit: 2,000 lumens lasts 2 minutes, then 1,000 lumens for 9 minutes and 760 lumens for 125 minutes, so plan around 760. It is also the longest and heaviest, on one custom battery.
Olight Odin Mini: The Light-Carbine Choice
A short carbine gets front-heavy fast. The Olight Odin Mini is the lightest at 176 g and ships with a ROD-7 switch. For Picatinny, add Olight's Pic Rail Adapter ($29.95), which lists the Odin Mini as compatible. The limit is endurance: High runs 6 + 11 + 39 + 14 minutes, about 70 minutes in all, so it suits short sits.
Olight's current lifetime warranty and return policy (last updated June 3, 2026) lists "Flashlights / Weapon Lights / Lanterns" under a lifetime warranty for products purchased after 2023 and excludes "Deliberate damage, misuse, or unauthorized modifications." The printed Odin and Odin Mini manuals show older terms, so go by the current page.
This table matches each light to the hunter it fits.
| Hunting light for rifle use | Choose it if you | Skip it if you |
| Odin S | Hunt long, cold nights and want CR123A backups on an M-LOK handguard | Need a Picatinny edition now, or often hunt below its listed 0°C working temperature |
| Odin | Shoot across long fields and want the most reach | Carry a short, light rifle or want store-bought backup cells |
| Odin Mini | Run a short carbine and hunt short sits | Keep the light on for long stretches |
A weapon light moves a scoped rifle's balance point forward by less than an inch. Based on Olight's rated weights, an Odin mounted 12 inches ahead of the balance point on a 7-pound rifle and scope shifts it about 0.76 inch, and an Odin Mini about 0.63 inch. You feel it on shooting sticks, but it rarely decides the choice.
The shift is m × d ÷ (M + m): m is the light's weight, d how far ahead of the old balance point it sits, and M the rifle, scope and rings. Olight's weights convert to 0.476 lb for the Odin (216 g), 0.425 lb for the Odin S (193 g) and 0.388 lb for the Odin Mini (176 g). For the Odin on a 7 lb rifle: 0.476 × 12 ÷ 7.476 = 0.76 in.
This table gives the forward shift at d = 12 in, based on Olight's rated weights, not measured. Olight does not publish the weight of the separate Odin and Odin Mini mounts, so they are left out.
| Light | Rifle and scope 7 lb | Rifle and scope 9 lb |
| Odin (0.476 lb) | 0.76 in | 0.60 in |
| Odin S (0.425 lb) | 0.69 in | 0.54 in |
| Odin Mini (0.388 lb) | 0.63 in | 0.50 in |
Moving forward costs little. Pushing an Odin 4 inches farther out on an 8-pound rifle adds 0.476 × 4 ÷ 8.476 = 0.22 in of shift, while moving the bezel from 6 to 2 inches behind the muzzle widens the clear half-angle from 9.5° to 26.6° with a 1.00 in gap. Clear the shadow first.
With thick gloves, a switch that separates Low and High by position is easier to run than one that separates them by how hard you press. The Odin S pressure switch has separate LO and HI buttons. The Odin and Odin Mini switches give Low with a light press and High with a hard press, which takes more feel through a glove.
The Odin manual says: "Click the tail switch lightly to produce a low light output or press the tail switch hard to produce a high light output." It adds: "When you press and hold the switch, the flashlight will be in momentary mode; when you release the tail switch, it will turn off." The Odin Mini manual gives the same steps.
The Odin S Picatinny manual splits the job: "Press the LO/HI button quickly for Low mode/High mode, and press again to turn it off." Its page notes a strobe you can enable or disable; once enabled, "double-pressing the tail switch or remote switch can activate it," so leave it disabled if you don't want strobe on a stand.
Mount the pad where your support thumb already rests on the sticks, and practice with your hunting gloves on an unloaded rifle. The standalone ROD-7 lists compatibility with the Odin and Odin Mini at $32.95, but its page showed "Notify me" in September 2026; the Odin Mini already ships with one.
Warning: The Odin and Odin Mini manuals warn that "The tail switch may not work while immersed in sea water or other conductive media. Please try to keep it clean and dry." Wipe the switch after a wet creek crossing and test it before you rely on it.
The best setup for night hunting is two or three lights with separate jobs: a headlamp for walking and chores, a handheld to scan where scanning is legal, and a rifle-mounted white light to confirm the target and take the shot where your state allows it. A rifle light is the wrong tool for scanning, because every sweep points the muzzle.
The first of NSSF's rules of firearms safety says: "Never point your gun at anything you do not intend to shoot." A rifle light used to scan points the rifle at every cow, dog and truck the beam finds.
- Walking and chores: a headlamp on a low setting, so both hands stay free and you don't light up the whole field.
- Scanning: a handheld spotlight, where legal. Our guide to the best rechargeable spotlight for hunting compares how long those lights hold output across many short scans, and Olight's hunting lights collection covers long-throw handhelds.
- Confirming and shooting: the rifle light, switched on only when the rifle is already on an animal you found with the scanning light, thermal or binoculars.
No light color is invisible to deer. A 1994 study of white-tailed deer found cones peaking near 450 to 460 nm and about 537 nm, plus a rod pigment near 497 nm, so deep red sits farthest from all three and is likely the least noticeable. For a rifle light the question is often moot, because rules such as Alabama's and Missouri's limit hunting lights to named night species, and deer are not among them.
The study, by Jacobs and colleagues, concluded that deer have "the requisite retinal basis for dichromatic color vision," per the PubMed abstract. It measured where sensitivity peaks, not where it stops, so red is dimmer to a deer, not hidden.
All three Odin models are white only. In Alabama, a light attached to a gun is lawful only in the licensed nighttime feral swine and coyote season, and Missouri bars "Artificial lights to search for, harass, or disturb wildlife" outside its coyote provisions. Where deer share a field with a legal night species, a deer in your beam is never a target.
Most rifle light problems at night come from mounting it where it is convenient instead of where it clears the scope and barrel, and from planning around the biggest lumen number. Each has a simple fix you can make at home with an unloaded rifle.
- Mounting at 12 o'clock under a low scope. Fix: run the centerline check, and move to a 45-degree slot if you fall short.
- Setting the bezel far behind a suppressor. Fix: move it forward; a 0.50 in gap drops from 14.0° to 2.4° of clearance as the bezel goes from 2 to 12 inches back.
- Resting the muzzle in the dirt with the light on. Fix: turn it off. The Odin and Odin Mini manuals say "DO NOT cover the light head when the flashlight is on, or place the light head on the ground."
- Running High over and over in summer heat. Fix: the Odin Mini manual says "DO NOT activate high mode repeatedly under high temperature to prevent the light body from overheating and hurting the user's hand."
- Changing the rifle to make a light fit. Fix: use a mount made for your rail. NSSF's ninth rule says "Any alteration or change made to a firearm after manufacture can make the gun dangerous and will usually void any factory warranties."
Safety note: The Odin and Odin Mini manuals also warn "DO NOT throw the light directly into human eyes. This may cause temporary blindness, or permanent damage to the eyes." and "Keep out of reach of children."
There is no national rule for rifle lights at night. States set the species, season, land type and even whether a light may be attached to the gun, so the same light can be lawful in one state and banned in the next. Read your state wildlife agency's current regulations before every season, and follow the text, not a forum summary.
This table compares three states that treat a rifle-mounted light differently, from each state's official source in September 2026. It is a summary, not legal advice.
| State and rule | What it covers | What it means for a rifle light |
| Alabama, Ala. Admin. Code r. 220-2-.11(2) | Bars hunting with a light attached to a gun, laser sights included, except with the nighttime feral swine and coyote license in that season | Legal only with that license, on those species, in that season, on private or leased land |
| Kentucky, 301 KAR 2:251, Section 7(8) | Coyote lights only Dec. 1 to Mar. 31 and May 16 to June 30, never where a deer or elk firearm season is open; rifles on private land only in those windows | No legal use for a coyote rifle light outside those dates |
| Missouri, 3 CSR 10-7.410 (hunting methods), per MDC | Artificial light, night vision and thermal for coyotes Jan. 1 to Sept. 30, except spring turkey season | Only with other legal methods, and only for coyotes |
Alabama's rule, Ala. Admin. Code r. 220-2-.11 (the certified version effective January 14, 2024, on the Alabama Legislative Services Agency site), says at subsection (2): "It shall be unlawful for any person to hunt with a bow or gun that has a light source attached that is capable of casting a beam of light (including a laser sight) forward of said bow or gun or to possess such a light source adapted for attachment to said bow or gun while hunting except for laser type range finders with computational capabilities; or as provided by Rule 220-2-.02(1)(c) for conditional use of laser sighting devices by legally blind hunters; or when the person possesses a current nighttime feral swine and coyote license and is hunting those species during the date of the established special nighttime feral swine and coyote hunting season." The state's season page limits that season to privately owned and leased lands. It "Begins at 12:00 am on the day after the last day of gun deer season in that zone" and ends 30 minutes before sunrise on the opening day of archery deer season. The same page lists a 2026 feral swine night season, May 8 to August 30, as "Dogs only - no firearms allowed."
Kentucky's 301 KAR 2:251, Section 7(8), lets you take a coyote after dark year-round, but "It shall not be allowed in a county or area where a deer or elk firearm season is open." It also says "Artificial light or other means designed to make wildlife visible at night shall only be used from December 1 through March 31, and from May 16 through June 30 on public and private land." It adds that such a light "shall not be connected to or cast from a mechanized vehicle," and on public land allows only a bow, crossbow or shotgun without single-projectile shells. The Legislative Research Commission page also flags a proposed version of this regulation, so check it again before the season.
Missouri's coyote regulations page says the extra equipment "is allowed in conjunction with other legal hunting methods to pursue and take coyotes." That window is new. MDC's 2026 coyote season notice says the changes "took effect Jan. 1, 2026," and some third-party copies of the rule still show the older February-to-March window, so go by MDC.
For 12 more states, see our guide to hunting with a light laws; our hog rifle light guide compares Texas and Oklahoma.
Safety note: NSSF's fourth rule says "Firing at a movement or a noise without being absolutely certain of what you are shooting at constitutes disregard for the safety of others." Confirm the species, what stands behind it and where the bullet will stop.
Install the light with the rifle unloaded, following Olight's manual for your model. Then check three things through the scope in daylight and at dusk: the light is out of the objective lens's path, the barrel shadow stays outside the picture at your lowest power, and your gloved hand finds the switch without looking.
For the Odin, the manual says to "Slide the product into the rail mount until you hear a click, then turn the button 90 degrees clockwise as the mark shows to fix the product." For the Odin S, "lock the knob locking lever on the rail mount with tools to make it ready for use (turning it clockwise)," and "Do not put your fingers against the movable rail mount on the opposite side of the knob locking lever."
Use this checklist before your first night with a rifle light for night hunting:
- Read your state's current rule for species, season, land type and attached lights.
- Pick the slot: a 45-degree offset or 3 or 9 o'clock, bezel close to the muzzle or suppressor end.
- Check the lens path against a bright wall at the lowest and highest power.
- Check the shadow at dusk on a fence line 50 to 100 yards out, at the lowest power.
- Fit the switch with hunting gloves: 20 presses for Low and High without looking.
- Pack backups: two CR123A cells for an Odin S, or a charged handheld for the walk out.
- Store it right: the Odin and Odin Mini manuals say that if the light will be "put aside for a long time or be transported, please unscrew the tailcap and remove the battery to cut off the circuit."
