Olight sells the TC001 Max thermal camera through its OSelect line and makes the Perun 3 Mini headlamp. Olight specs and regular prices come from its US product pages and user manuals as of October 2026; switch, PDU and UPS figures come from their makers' datasheets as listed on October 30, 2026. PoE, heat and headroom figures are our calculations from those published numbers, not measurements.
A thermal imaging electrical inspection of a network closet works best as a side-by-side comparison. Scan identical adapters, power strip outlets, switch ports and PoE loads, and flag the one that runs warmer than its siblings. Then check the room air against the lowest operating limit in the makers' datasheets. Scan covers and faceplates only, and call a licensed electrician for building wiring.
The usual story: the switch, router, modem, UPS and a power strip share a closet with the door shut, adapters hang off the strip in a tangle, and new PoE cameras went in last spring. Nobody notices the heat until the switch reboots or a plug looks scorched. A phone thermal camera shows which box works hardest, if you know what to compare it with.
This table lists the gear a thermal imaging electrical inspection of a closet needs, with the minimum spec this guide uses for each job.
| Job | Recommended type | Minimum spec to look for | Recommended model (regular price, October 2026) |
| See which identical item runs warmest | Radiometric phone thermal camera | Spot, box and hot-spot tools; stated accuracy; range above 100 °C | TC001 Max ($309): 256 x 192, <40 mK, 3 user-set rectangles |
| Light the back of the rack hands-free | Headlamp that converts to a handheld | A 10 lumen mode for labels, a 100 lumen mode, magnetic tail | Olight Perun 3 Mini ($64.99): Low 10 lm for 30 h, Med 100 lm for 4.5 h |
| Read the air at the equipment intakes | Digital air thermometer | Reads °F and °C | Any; a thermal camera reads surfaces, not air |
| Read the load | Metered PDU, UPS display or switch PoE page | Amps per strip, watts per PoE port | The display or software you already own |
- 1. Quick Answer: How Does a Thermal Imaging Electrical Inspection Work in a Network Closet?
- 2. What to Scan in a Network Closet: Power Strips, Adapters, Switches, Routers, UPS and Outlet Plates
- 3. How to Read the Heat Map: Sibling Differences and Datasheet Limits
- 4. PoE Budget and Heat: Why Most PoE Watts Leave the Switch
- 5. What Poor Closet Ventilation Looks Like on a Thermal Image
- 6. Phone Thermal Camera Tips for a Tight Rack: Distance, Angle and Reflections
- 7. Safety Boundary: Scan Covers and Faceplates Only
- 8. Common Mistake: Opening an Outlet Because It Looked Hot
- 9. Can Electricians Do Thermal Imaging?
- 10. How Much Does an Infrared Electrical Inspection Cost?
- 11. What Are the NFPA 70B Requirements for Thermal Imaging Inspections of Electrical Equipment?
- 12. Network Closet Thermal Inspection Record Template
- 13. Your Network Closet Scan Checklist
- 14. FAQ
It works by comparison. Run the closet at its normal working load, scan each group of identical items from outside the rack, and mark any one that reads clearly warmer than its matching neighbors. Then measure room air near the intakes and compare it with the lowest ambient limit among your devices. You read surfaces only and open nothing.
Comparison beats absolute numbers because adapters are supposed to run warm, and the makers quoted below rate the air around the device, not a safe case temperature. Two same-model adapters under similar loads should look alike. When one does not, you have a lead.
If you are still choosing a camera, Olight's OSelect line lists thermal imaging cameras for phones, and its full range of flashlights covers the light you need behind the rack.
Scan six groups: power strip or rack PDU outlets and plugs, wall-wart power adapters, switch ports and PoE loads, the switch and router cases, the UPS, and the wall outlet plate that feeds it all. Each group has a fair comparison inside it. Mixed groups, such as a router beside a modem from another maker, tell you much less.
This table sets out each sub-scene: what to compare it with, what normal looks like and what deserves a second look.
| Sub-scene | Compare it with | Normal pattern | Worth a second look | What you do |
| Power strip or PDU outlets | Outlets on the same strip with similar loads | Plugs slightly warmer than empty outlets | One outlet face warmer than its peers | Recheck; if it repeats, stop using it and replace the strip or call an electrician |
| Wall-wart adapters | The same model on similar devices | Twins look alike | One much warmer than its twins | Swap in a same-rating spare |
| Switch ports | Ports feeding identical devices | PoE ports warmer than data-only ports | One port warmer than its peers | Read its PoE draw in the switch software |
| Switch and router cases | Same model, same position | Warmest near the vents | Intake as warm as exhaust | Check airflow and stacking |
| UPS | Its own history | Warm while charging | A new warm area at the same load | Check the UPS display and alarms |
| Wall outlet plate | Nearby plates and its own history | Close to the wall around it | Warmer than nearby plates at similar load | Leave it; call a licensed electrician |
Start with the strip, because its outlets carry everything. A metered PDU helps. Tripp Lite's PDUMH15 rack PDU spec sheet lists "12A total capacity; 12A max per outlet" and a meter that "continuously reports PDU load level in amps." Log the reading with every scan. A display showing 6.5 A means the strip runs at 6.5 / 12 = 54% of its de-rated capacity.
Read the heat map in two passes. First, compare siblings: same model, same load, same position, same distance. Second, compare the closet air with each maker's operating temperature range. A case reading is not the datasheet number, because makers rate the air around the device.
This table shows four makers' operating ranges, quoted from their own datasheets on October 30, 2026.
| Device (maker) | Listed operating range (maker's wording) | Other heat figure the maker lists |
| Ubiquiti USW-Lite-8-PoE switch | Ambient Operating Temperature "-15 to 40° C (5 to 104° F)" | 27.3 BTU/hr excluding PoE output |
| Cisco Business CBS350-24P-4G switch | Operating temperature "23° to 122°F (-5° to 50°C)" | 820.62 BTU/hr worst case |
| Tripp Lite PDUMH15 metered PDU | Operating Temperature Range "32° to 104°F (0° to 40°C)" | 12 A de-rated continuous |
| Tripp Lite SMART1500LCD UPS | Operating Temperature Range "32° to 104°F (0° to 40°C)" | AC Mode BTU/Hr. (Full Load) 78 |
Sources: Ubiquiti's USW-Lite-8-PoE tech specs, Cisco's Business 350 Series data sheet and Tripp Lite's SMART1500LCD spec sheet.
The weakest-link rule
Your closet's air limit is the lowest maximum among everything inside it. Here, three of four devices top out at 40 °C (104 °F), so the ceiling is 40 °C even though the Cisco switch accepts 50 °C.
How much margin should you keep? The DOE's Data Center Air-Management Tool user's manual, from Lawrence Berkeley National Laboratory, lists the "standard ASHRAE (2021) recommended range (65°-80°F)", about 18 to 27 °C, and the ASHRAE "allowable A1 (59°-90°F)" range, about 15 to 32 °C, for equipment intakes. The A1 top is an allowable limit, not a target. Against a 104 °F ceiling, it leaves 104 − 90 = 14 °F, or about 7.8 °C. The manual adds that "server fans speed up at intake temperatures above 77°F (25°C)." A closet idling above 90 °F is already outside the A1 range.
Sibling comparison rules
No published severity table covers plug-in network gear, so ask whether a difference is fair: same model and rating, similar load, similar spot, same door state. An adapter resting on the UPS, or a port feeding a PoE+ camera beside a data-only PC, is not a fair pair. A real finding repeats on two scans a week apart.
Most PoE power does not stay inside the switch. It travels down the cable and turns into heat at the camera or access point, with a budgeted share lost along the cable run. What stays in the switch is its own electronics plus conversion losses, so a busy PoE switch runs warmer than a data-only one without keeping its whole PoE load as heat.
Each IEEE PoE type sets what the switch (the PSE) supplies and what the powered device (PD) can count on. This table takes the figures from Microchip's IEEE 802.3bt white paper and works out the gap.
| PoE type (standard) | PSE output per port | PD minimum input | Budgeted cable loss (calculated) | Share of PSE output | Per meter over 100 m |
| Type 1 (802.3af) | 15.4 W | 12.95 W | 15.4 − 12.95 = 2.45 W | 15.9% | 0.0245 W/m |
| Type 2 (802.3at, PoE+) | 30 W | 25.5 W | 30 − 25.5 = 4.5 W | 15.0% | 0.045 W/m |
| Type 3 (802.3bt) | 60 W | 51 W | 60 − 51 = 9 W | 15.0% | 0.09 W/m |
| Type 4 (802.3bt) | 90 W | 71.3 W | 90 − 71.3 = 18.7 W | 20.8% | 0.187 W/m |
Microchip states the Type 4 case directly: for a PSE sourcing 90W output, "the PD should expect only 71W while 19W are budgeted for 100m cable power loss." That worst case is spread along the whole run, so a patch cord in the closet carries only a sliver of it.
Budget math for two small-office switches
Ubiquiti lists the USW-Lite-8-PoE with 4 PoE+ ports, "30W" maximum per port and "52W" total PoE availability. That covers 52 / 30 = 1.7 ports at full PoE+, or 52 / 4 = 13 W each if all four share it equally. Cisco lists 195W of PoE across 24 ports on the CBS350-24P-4G, which is 195 / 30 = 6.5 devices at a full 30 W, or 195 / 24 = 8.1 W per port on average.
How much heat stays in the box
Ubiquiti lists 8W maximum excluding PoE output and 60W including it; the gap, 60 − 8 = 52 W, is its PoE budget, and 8 W x 3.412 = 27.3 BTU/hr is its listed heat figure. Cisco gives one heat figure for the CBS350-24P-4G, 820.62 BTU/hr. Divided by 3.412, that is 240.5 W, within 1 W of the 239.7 W worst-case draw with PoE that Cisco lists at 110 V. Cisco's figure therefore counts every watt from the wall, including the PoE watts that leave on the cables.
Our own estimate, not a Cisco figure: if the full 195 W PoE budget leaves through the ports, about 239.7 − 195 = 44.7 W, or 152.5 BTU/hr, is released inside the switch. That is 10.3 W more than Cisco's 34.42 W system figure without PoE, which fits conversion losses that grow with PoE load. The 195 W that leaves becomes heat mostly in the cameras and access points, plus up to the budgeted cable loss along the runs.
Poor ventilation shows up as heat in the wrong place. Equipment intakes read as warm as exhausts, the top of the rack glows while the bottom stays cool, and warm air pools against the ceiling or the top of the closed door. LBNL's manual defines the core problem, recirculation, as "Hot equipment exhaust re-circulated back to the equipment intakes."
The same manual lists typical temperature rises across IT equipment of 10 to 20 °F (6 to 11 °C) for mainly traditional equipment and 20 to 30 °F (11 to 17 °C) for mainly modern equipment. Trouble starts when that exhaust finds its way back to an intake.
This table matches common thermal patterns in a closet to a likely cause and a fix you can make without touching wiring.
| Pattern on the image | Likely cause | Fix you can make |
| Top third of the rack clearly warmer than the bottom | Warm air rising and trapped in a closed closet | Move the warmest gear lower; add a vented door or exhaust path |
| Intake face of a device as warm as its exhaust | Exhaust recirculating to the intake | Turn devices so they all breathe the same direction; close open gaps between them |
| Device stacked directly on a UPS or router reads hot underneath | Heat conducted and trapped between cases | Add a shelf gap or move one device |
| Image shows a flat, even surface with no detail | Scanning through a glass or acrylic door | Open the door; a thermal camera cannot see through it |
The TC001 Max user manual confirms that last row: the camera reads surfaces and cannot sense heat through glass, acrylic or water.
Your closet's heat budget
Add up what stays in the closet. Using the three datasheets above as an example: 8 W for the Ubiquiti switch, about 44.7 W for the Cisco switch at full PoE (our estimate above), and 78 / 3.412 = 22.9 W for the Tripp Lite UPS at full load. That totals 75.6 W, about 258 BTU/hr, or 75.6 x 24 / 1,000 = 1.81 kWh of heat a day. If you take Cisco's 820.62 BTU/hr as written, the total rises to 8 + 240.5 + 22.9 = 271.4 W, so size cooling between those two figures.
Note: Door open versus door closed is worth checking yourself; nothing here was measured. Leave the door shut for an hour at normal load, open it, and capture the same five points within a minute. Repeat after an hour with the door open, and log the PDU amps both times.
Hold the camera far enough back to frame a whole group of siblings, tilt it slightly off square so you do not image your own reflection, and lock the temperature span so colors mean the same thing across shots. Compare items with the app's boxes, not by color, and never scan through glass.
The TC001 Max thermal camera fits this job because it plugs into the phone you already carry. Olight lists a 256 x 192 sensor, <40 mK sensitivity, 25 Hz, a 56° x 42° field of view, a 0.2 m (0.66 ft) minimum focus distance and an object range of -20 to 550 °C. Accuracy is "±2° C or ±2% of reading, the larger value shall prevail." Its tools include center, hot and cold spots plus "3 dot, 3 line and 3 rectangles," with Level and Span Mode.
The box includes a USB-C extension cable and a USB-C to Lightning cable, the working range of -10 to 50 °C sits above the 40 °C ceiling of most closet gear, and its Dual Fusion mode helps you tell one black adapter from the next. Olight's spec table lists 30 g and its highlights 33 g. The price is $309 (regular price, October 2026). For what a budget thermal imager can and cannot do, see our $300 camera guide.
Field habits that keep readings honest:
- Mind reflections. The manual warns against measuring in strong direct light or near reflective surfaces such as glass. Glossy faceplates mirror your body heat. Step sideways; a reflection moves, a real hot spot stays.
- Wait for the click. By default the shutter refreshes itself every 30 seconds, per the manual, and the image pauses briefly when it does. Capture after it settles.
The limits: the wide lens means standing close to small items, and the camera depends on your phone. It finds differences; it does not make you an electrical inspector.
Lighting the back of the rack
Behind a rack, the labels sit in your shadow. The Olight Perun 3 Mini headlamp keeps both hands free for the phone and the cable. For the cool white (CW) version, Olight lists Med 100 lumens for 4.5 hours, Low 10 lumens for 30 hours and Moon 2 lumens for 10 days, plus red light at 5 lumens for 19 hours, up to Turbo 1,250~350 lumens for 2 + 60 minutes. It weighs 54 g with battery and is rated IPX8.
The quick-release bracket turns it into a handheld, and the magnetic tailcap can hold it to a steel cabinet door or frame while you work. The standard kit, with headband and MCC magnetic cable, lists at $64.99 (regular price, October 2026).
Know where it falls short. The spec page of its user manual lists a working temperature of 0-40°C, the same ceiling as much of the gear in the rack, and the manual warns that a battery left in extreme heat can explode or leak flammable liquid or gas. Do not store it in a hot closet. Use Low or Med, keep the warm headlamp out of the thermal frame, and keep its aluminum body away from the plug area of any strip or PDU.
If you are not a licensed electrician, your thermal imaging electrical inspection stops at the surface. Scan device cases, adapter bodies, plug faces, power strip housings and outlet cover plates from outside the rack. Do not remove outlet plates, open a PDU, UPS or power supply, pull plugs to look inside receptacles, or touch any conductor. The U.S. Fire Administration's home electrical fire flyer leaves electrical work to a qualified electrician.
Inside your boundary: scanning closed equipment, reading PDU, UPS and PoE loads, moving gear for airflow per each maker's instructions, and replacing a strip or adapter with a correctly rated one. Outside it: anything behind an outlet plate, inside a PDU or UPS, or in the electrical panel. The clear space you need in front of the breaker panel is covered in our guide to electrical panel working space requirements.
Warning: Do not daisy-chain power strips in the closet. The Naval Postgraduate School's extension cord and power strip safety page says interconnecting these devices "is a violation of Occupational Safety and Health Administration (OSHA) regulations and the National Electrical Code because doing so can cause them to become overloaded, which could lead to their failure and a possible fire." The USFA flyer adds: "Don't overload extension cords or wall outlets."
The common mistake is treating a warm spot as a diagnosis and opening the outlet or strip to find the cause. A thermal image shows surface temperature, not what is wrong behind it; heat at a plate can come from the plug, the load or the receptacle. Opening it exposes live parts, and the cause still needs a qualified person working with the circuit de-energized.
What to do instead: photograph it with the visible overlay, log the load and the difference against its sibling, and call a licensed electrician. If the warm part is an adapter body, swapping in a same-rating spare is a fair check.
Two more mistakes waste a scan: scanning at 3 a.m., when light load hides a weak spot, and trusting color instead of locked-span numbers.
Yes, but a license to do electrical work and qualification as a thermographer are separate credentials, and a closet may need one, the other or neither. Two frameworks you will see are employer certification based on ASNT's SNT-TC-1A, with Levels I to III, and ISO 18436-7, with three categories. For a network closet, you need an electrician when the warm spot is in the building wiring.
The Infraspection Institute tip on certification notes there are "few standards addressing certification." It describes SNT-TC-1A as suggested curricula and experience for the thermal/infrared method, and says "it is up to an employer to determine his/her client's needs for and to set certification requirements accordingly."
The international route is ISO 18436-7:2014, which "specifies the requirements for qualification and assessment of personnel who perform machinery condition monitoring and diagnostics using infrared thermography" and sets "a three-category classification programme." Its scope is machinery condition monitoring, not electrical work as such. ISO lists the 2014 edition as current, last reviewed and confirmed in 2025. For which cameras electricians pick and how they work on open, energized equipment, see our guide to the best thermal imaging camera for electricians.
This table sorts closet findings by who should take them next.
| Finding in the closet | Who to call |
| A warm outlet plate or plug, a breaker that trips under load, or discoloration at an outlet | Licensed electrician |
| One adapter or switch warmer than its identical siblings | You or your IT provider: swap and recheck |
| Whole closet near the 40 °C device limit | Building manager or HVAC contractor |
| A report needed for an insurer or a maintenance program | A certified thermographer |
We found no verifiable price range for infrared electrical inspections from a government agency, standards body or professional association, so this guide gives no number. The price depends on how many panels and pieces of equipment are scanned, travel, the thermographer's certification level, the report you need and whether the work happens after hours under load.
This table lists the factors that move a quote and what to ask about each.
| Factor | Why it changes the price of infrared camera electrical inspections | What to ask |
| Scope | More panels, PDUs and UPS units take more time | Ask for a price per item or per hour, and the list of items included |
| Load timing | Scans need normal load, which can mean after-hours visits | Ask whether a daytime scan is possible |
| Report format | A signed report with images and temperature differences takes longer than a walk-through | Ask for a sample report |
| Credentials | Certification levels and frameworks differ | Ask which level or category, and who issued it |
For one small closet, a phone-camera self-check covers the comparison work. A paid survey makes sense under a formal maintenance program or when an insurer asks for a report. How inspectors word scan findings is covered in our guide to the thermal camera for home inspector reports.
NFPA 70B is the Standard for Electrical Equipment Maintenance. Its 2023 edition turned it from a recommended practice into a standard, and NFPA now lists a 2026 edition as current. According to the Infrared Training Center's summary of the 2023 edition, temperature differences must be documented, and thermal inspection is due at least every 12 months, or every six months for equipment in Condition 3.
NFPA's NFPA 70B page shows the title, the 2026 current edition and a free access link. The full text is sold, so the clause points below come from two ITC summaries of the 2023 edition, on NFPA 70B thermography rules and on documenting findings. Clause numbers may differ in the 2026 edition, so check the current text before you cite one.
This table lists 2023 clauses as ITC describes them and what you can borrow for a closet log.
| NFPA 70B 2023 clause, per ITC | What the summary says | What to borrow for a closet |
| 7.4.1 | Thermography measures the difference between similar components under similar loading, and between components and ambient air | Compare siblings at similar load; record room air |
| 7.4.3 | "temperature differences between the area of concern and the reference area shall be documented" | Log the warm item, its reference sibling and the difference |
| 9.2.2, 9.1.3.1 and the Chapter 9 table | At least every 12 months; every six months for Condition 3, which includes "urgent actions identified from predictive techniques" | Pick a fixed interval; rescan sooner after any finding |
| 8.6.2 | Test records list tester, equipment, nameplate data, environment, date, results and comments | Use the record template below |
One point does not carry over. ITC's summary says covers should be removed before the inspection to keep a clear line of sight. That work belongs to qualified persons under an electrical safety program. In your closet, covers stay on.
A record makes the next scan meaningful. Log the same points in the same order with the same camera settings, and note load and room air each time. The fields borrow from the 2023 test-record list as ITC summarizes it. Keep one row per finding, with thermal and visible images.
This table lists each field and an example entry. The example values are for illustration only, not a real finding.
| Field | Example entry |
| Date, time and who scanned | Oct 7, 2:30 p.m., office manager |
| Door state before scan | Closed 3 hours, scanned within 1 minute of opening |
| Room air at intake height | 31 °C (88 °F) |
| Camera and settings | TC001 Max, span locked 25 to 55 °C |
| Load | PDU 6.5 A; switch PoE 112 W |
| Group scanned | Five identical camera adapters |
| Warmest item and its reference | Adapter 3 at 49 °C vs adapters 1, 2, 4, 5 at 41 to 43 °C |
| Difference | 6 °C over the warmest sibling |
| Action and who | Swapped adapter 3 with a same-rating spare; rescan next week |
Use this list for your first thermal imaging electrical inspection of a network closet. Every step happens outside the equipment, and every number goes into the log so next month's scan compares like with like.
- List every device and circle the lowest operating maximum in its datasheet.
- Scan during normal working hours, with the door shut beforehand.
- Open the door and capture the strip, adapters, switch ports, UPS and wall plate within a minute.
- Draw boxes over identical items and note the warmest and its reference.
- Read room air at intake height and the PDU or UPS load.
- Check PoE draw per port in the switch software.
- Fix airflow first: unblock vents, separate stacked devices, stop daisy chains.
- Call a licensed electrician for any warm outlet plate, plug or tripping breaker.
- October 1, 2026: First published.
