Olight makes the lights compared here. Olight specs and regular prices come from its US product pages and user manuals as of September 2026. The scores, lux and glare figures below are our own arithmetic from those published ratings, not measurements.
The best spotlight for camping is the Olight Marauder Mini 2 ($219.99, regular price, September 2026). Its spotlight reaches a rated 750 m for eyeshine or a drifting paddle, yet dims to a 0.5-lumen moonlight and adds a red channel. It scores 80 of 100 on our four-criterion camp scorecard, ahead of the Seeker 4 Pro (75) and Warrior X 4 (48).
This table gives the best spotlight for camping in each situation, using Olight's rated specs and regular US prices in September 2026.
| Scenario | Outdoor camping spotlight pick | Key specs (Olight ratings) | Price (regular, Sept 2026) | One-line reason |
| Best overall: car camping, lakeshores, forest campgrounds | Olight Marauder Mini 2 | Spotlight 1,350 lm, 140,000 cd, 750 m; spotlight moonlight 0.5 lm; red light; 465 g; IPX8 | $219.99 | Longest reach here plus the lowest white setting and a red channel |
| Walk-in sites and one-handed carry | Olight Seeker 4 Pro | 4,600 lm, 16,895 cd, 260 m; Moon 5 lm; 205 g; IPX8 | $139.99 | Less than half the Marauder Mini 2's weight, with holster lock and an auto-off timer |
| Most reach per dollar, paired with a headlamp | Olight Warrior X 4 | 2,600 lm, 99,310 cd, 630 m; lowest mode 300 lm; 249 g; IPX8 | $129.99 | 630 m of reach for the lowest price, but nothing dimmer than 300 lumens |
| Vehicle base camp on big water or open range | Olight Marauder 3 | Spotlight 1,500 lm, 250,000 cd, 1,000 m; 840 g; IPX8 | $369.99 | The farthest reach Olight lists, if you can carry 840 g |
Campers who buy a spotlight hit two problems. Their headlamp and lantern often run out of reach somewhere past 50 m, so a noise at the edge of camp stays a mystery. Then the big light they buy is heavy, hot after a few minutes on full, and bright enough to wake the loop when it swings across a tent.
This guide covers what a handheld spotlight is for at camp, which of Olight's camping flashlights fit that job, and how to use one without blinding neighbors or breaking park rules. For boats, farms and search work, see our rechargeable spotlight guide.
- 1. What Does a Spotlight Do at Camp That a Headlamp or Lantern Can't?
- 2. Four Camp Jobs That Actually Need a Spotlight
- 3. Best Spotlight for Camping Compared: Searchlight, Long Thrower and Dual-Beam Light
- 4. How the Lights Score for Camp: Reach, Low Mode, Weight and Grip
- 5. What Is the Best Bright Flashlight for Camping?
- 6. How Many Lumens Is Best for Camping With a Spotlight?
- 7. How Many Lumens Is a Powerful Spotlight?
- 8. What Does Eyeshine at the Edge of Camp Tell You, and What Should You Do?
- 9. How Much Light Lands on the Next Campsite?
- 10. Spotlights, Wildlife and Park Rules: What the Regulations Say
- 11. Common Myths: A Brighter Light Scares Bears, and Rated Distance Is Seeing Distance
- 12. Where the Numbers in This Guide Come From
- 13. Best Spotlight for Camping: Your Pre-Trip Checklist
- 14. FAQ
A spotlight shows you things 50 to 300 m away: eyeshine at the edge of a meadow, a canoe on the far bank, a trail sign across a clearing, or a person walking back late. A headlamp lights your hands and the next few steps, and a lantern lights the table. The spotlight comes out for short checks only.
The National Park Service's Ten Essentials list says "Headlamps are the recommended light source because they are hands-free." Buy in that order: start with the best camping headlamp for you, add the best lantern for camping for the table, and treat the spotlight as the third light, bought for reach.
This table shows how the three lights split the work at a typical campsite.
| Camp light | Its job | Where it fails | How long it stays on |
| Headlamp | Hands-free light for cooking, pitching, the restroom walk | Long reach, on most camp models | All evening |
| Lantern | Even light over the table and inside the tent | Anything past the edge of camp | All evening |
| Handheld spotlight | Eyeshine, far shorelines, trail markers, searching for a person | Close work, glare off tent walls, pack weight | A few seconds at a time |
If you want one daily-carry light that also behaves at camp, see our best tactical flashlight for camping guide. This one is about the most reach you can hold in one hand.
Four camp jobs genuinely need a spotlight: checking a noise at the edge of camp, finding gear on water or a far shore, locating a site, trail or road after dark, and searching or signaling for a person. Cooking, reading a map and walking to the restroom are better done with a headlamp or lantern on a low setting.
- A noise at the edge of camp. Stand still, hold the light at eye level, and sweep once in a slow arc on a middle spotlight level, not turbo. Find the eyeshine, then drop the beam to the ground in front of the animal.
- Lost gear on the water. Sweep the surface for a drifting paddle or dry bag in overlapping passes on a steady middle level. The Marauder Mini 2's spotlight holds 600 lumens for 170 minutes after its first 4-minute stage on its highest level, according to Olight's rating.
- Finding your site or trail. The beam shows the far edge of a clearing, a fire ring or a trailhead sign before you commit the car or your feet.
- Searching or signaling. A spotlight's narrow beam can reach a searcher across a lake or clearing. The NPS Outdoor Emergency Plan tells lost hikers to flash SOS and warns that signaling drains batteries. None of the three handhelds here lists an SOS mode, so you make the pattern with the switch.
The best spotlight for camping comes in three shapes: a dual-beam light such as the Marauder Mini 2, a slim long thrower such as the Warrior X 4, or a large searchlight such as the Marauder 3. The Seeker 4 Pro is a fourth option, a wide-beam light with enough reach for a lakeshore. All four are rated IPX8 and are rechargeable.
This table lists every model in this guide on Olight's published ratings, including the lowest white setting, which decides whether a light is usable near a tent.
| Camp flashlight spec (Olight rating) | Marauder Mini 2 | Warrior X 4 | Seeker 4 Pro | Marauder 3 |
| Type | Dual beam plus red and side light | Single-beam thrower | Wide single beam | Large dual-beam searchlight |
| Max output | 10,000 lm (flood); 1,350 lm (spot) | 2,600 lm | 4,600 lm | 25,000 lm (flood); 1,500 lm (spot) |
| Peak intensity | 140,000 cd | 99,310 cd | 16,895 cd | 250,000 cd |
| Beam distance | 750 m | 630 m | 260 m | 1,000 m |
| Top spot or turbo runtime | Spotlight 1,350~600~400 lumens, 4+170+50 minutes | 2,600~1,000~300 lumens, 3 + 140 + 20 minutes | 4600~1200~600 lumens, 2.5 + 122 + 35 minutes | Spotlight 1,500~750~500~250 lumens, 3+700+200+200 min |
| Lowest white setting | Spotlight moonlight 0.5 lm, 95 days | Regular Low 300 lm, 8 hours | Moon 5 lm, 15 days | Spotlight moonlight 0.5 lm, 14 months |
| Red light | Yes, 1 to 400 lm | No | No | No |
| Weight with battery | 465 g (16.38 oz) | 249 g (8.78 oz) | 205 g (7.23 oz) | 840 g (29.63 oz) |
| Charging | USB-C or MCC | USB-C or MCC3 | USB-C in holster or MCC3 | USB-C |
| Price (regular, Sept 2026) | $219.99 | $129.99 | $139.99 | $369.99 |
The runtime row answers the heat complaint: the top stage lasts only 2.5 to 4 minutes before rated output drops. A camp check should last seconds, so this matters only on a long search, where the second stage is your working output.
Lumens alone mislead: the 4,600-lumen Seeker 4 Pro reaches 260 m, the 2,600-lumen Warrior X 4 630 m. Our explainer on flashlight throw vs flood covers why candela sets reach.
On a four-criterion camp scorecard worth 100 points, the Marauder Mini 2 scores 80, the Seeker 4 Pro 75 and the Warrior X 4 48. The Marauder Mini 2 wins on reach and the lowest white setting, the Seeker 4 Pro wins on weight, and the Warrior X 4 matches the Marauder on reach but loses the low-mode and control points that matter near a tent.
This table shows each criterion, how points were given from Olight's product pages and manuals, and the result. The 840 g Marauder 3 is left out as a vehicle light.
| Criterion (25 points each) | How points were given | Marauder Mini 2 | Seeker 4 Pro | Warrior X 4 |
| Reach | 600 m or more = 25; 300 to 599 m = 18; under 300 m = 12 | 25 (750 m) | 12 (260 m) | 25 (630 m) |
| Lowest white setting | 1 lm or less = 25; over 1 to 10 lm = 18; 11 to 100 lm = 8; over 100 lm = 0 | 25 (0.5 lm) | 18 (5 lm) | 0 (300 lm) |
| Weight | 210 g or less = 25; 211 to 300 g = 18; 301 to 500 g = 10 | 10 (465 g) | 25 (205 g) | 18 (249 g) |
| Grip and control | Automatic lockout = 10; brightness dial = 5; red light = 5; holster in box = 5 | 20 (no holster) | 20 (no red) | 5 (holster only) |
| Total | 80 | 75 | 48 |
The sums: 25 + 25 + 10 + 20 = 80; 12 + 18 + 25 + 20 = 75; 25 + 0 + 18 + 5 = 48. If you walk your gear in, count weight twice: the Seeker 4 Pro then leads, 75 + 25 = 100 against 80 + 10 = 90. Our tactical camping guide named the Warrior 3S because it asks a different question: which daily-carry light behaves at camp.
Olight Marauder Mini 2: Best Overall Spotlight for Camping
The hard part is real reach and a gentle camp setting in one light. The Olight Marauder Mini 2 uses separate channels: a spotlight rated at 140,000 candela and 750 m, a 10,000-lumen floodlight, a red light and a side light, chosen with a rotary selector and set with a rotary knob.
Three manual details matter at camp. It locks itself: "When the flashlight is turned off and no operation is performed within 10 seconds, the lockout mode will be activated automatically." Red keeps your level: "When switching between red and white light modes, the flashlight retains its current brightness level." And strobe works only when the light is "set to the white floodlight mode."
The $219.99 price applies to the default finish; Olight lists a Roadster edition at $229.99. Its limits: 465 g is heavy for a pack, and the box holds a plastic protective case and a USB-C wrist-strap cable but no holster. One data note: Olight's highlights say it "runs up to five months in moonlight mode," which matches the 150-day side-light moonlight rating; the spotlight moonlight is rated 95 days. Compare the rest of the Marauder series on its series page.
Olight Seeker 4 Pro: Best for Walk-In Sites
On a walk-in site, the 260 g you save can matter more than reach. The Olight Seeker 4 Pro weighs 205 g in its standard finishes and dims steplessly down to a 5-lumen Moon. Its manual says: "While off, press and hold the switch for 1s to enter Moonlight mode." It also locks "if put back to the holster," and offers "a long timer (9 minutes) and a short timer (3 minutes) for automatic light-off when in use."
At 16,895 candela and 260 m, it is a wide-beam light with some reach, not a true spotlight. The price and weight above are for the default Matte Black CW version. The spec sheet also lists a Neutral White (4000K~5000K) LED and a 350 g Silver-Plated Bronze version, and not every finish was in stock in September 2026, so check the variant you select.
Olight Warrior X 4: Most Reach per Dollar, Paired With a Headlamp
The Olight Warrior X 4 is rated for 630 m at 249 g and $129.99 for the default Matte Black, with a holster and USB-C cable in the box. Olight says it "balances the spot and spill well." Its dimmest setting, though, is Regular Low at 300 lumens, and it has no red light, so use it only as a scanner beside a headlamp. The page lists the Glacial Valley and Flat Dark Earth versions as sold out.
Note: The 840 g Marauder 3 reaches a rated 1,000 m; treat it as a vehicle or base-camp searchlight, not a light you carry around camp.
The best bright flashlight for camping is one whose brightness you can turn down. For reach with a true camp low, choose the Olight Marauder Mini 2: 750 m on the spotlight and 0.5 lumens at the bottom. For a lighter bright light, choose the Seeker 4 Pro: 4,600 lumens, 205 g and a 5-lumen Moon mode.
Inside camp, the brightest mode glares off tent fabric and wakes neighbors. Before buying any light sold as the brightest camp flashlight, check that its lowest white setting is under 10 lumens and one press-and-hold away once the light is unlocked.
For camping with a spotlight, the lumen figure that matters most is the lowest spotlight level. Use 0.5 to 5 lumens inside the campsite, a middle level of roughly 100 to 400 spotlight lumens for checks out to the tree line, and full output only for a few seconds when something far away needs a closer look.
Olight rates the Marauder Mini 2's 100-lumen spotlight level at 30 hours and its 400~100 lumen level at 6 + 4 hours. The Seeker 4 Pro runs Low, 50 lumens, for 60 hours and Medium, 300 lumens, for 11 hours. The Warrior X 4 has nothing below 300 lumens.
A powerful spotlight is defined by candela, not lumens. The spotlight channels on Olight's two dual-beam lights top out at only 1,350 and 1,500 lumens, yet they are rated at 140,000 and 250,000 candela and 750 m and 1,000 m of reach. Their floodlights hit 10,000 and 25,000 lumens but light the near field.
So look at peak candela and rated beam distance first, then at the lumens of the setting you will use. The standard behind those numbers is changing: PLATO says the ANSI/PLATO FL 1-2025 revision adds a turbo test that helps consumers "distinguish a brief burst of maximum output from performance that can be sustained over a longer period." The Marauder Mini 2 manual cites ANSI/NEMA FL 1-2009 and the Seeker 4 Pro manual ANSI/PLATO FL 1-2019.
Eyeshine at the edge of camp tells you an animal is there, roughly where it is and whether it is moving toward you. It rarely tells you the species, since color varies with the animal, your distance and your light. Judge by distance and movement, then act: lower the beam, let the animal leave, and back away if the eyes come closer.
The National Park Service explains the glow in a deer monitoring article from Pea Ridge National Military Park: "Many animals have this eyeshine, including dogs, cats, cattle, horses, and even some reptiles, amphibians, fish, birds, and insects!" Park staff count deer there with spotlights as a planned survey, and the article notes that "When the light beam hits their eyes, they freeze until their eyes can adjust." A frozen animal is not a calm one, so don't hold the beam on its face.
Color is a weak clue. The Indiana Department of Natural Resources' raccoon profile says eye shine "can help with identification but also vary by individual animal, how far you are from the animal, and the light source. Raccoon eye shine is typically bright yellow."
This table turns what you see in the beam into a next step, using Yellowstone's 25-yard and 100-yard distances as the yardstick.
| What the beam shows | Spotlight move | Next step at camp |
| One pair, still, well beyond 25 yards (23 m) | Drop the beam to the ground in front of the eyes, then to a middle level or off | Let the animal leave; note which way it went |
| Eyes moving sideways or away | Switch off or aim at the ground | Stay where you are; the check is over |
| Eyes coming closer | Stop scanning; keep a low beam on the ground between you | Back away and gather the group |
| Eyes inside 25 yards, or a bear, wolf or cougar inside 100 yards (91 m) | Keep the light low so you can see your footing | Walk, don't run, to a car or building, as Yellowstone advises for an approaching bear |
| Many small points low in the grass | Lower the output | Likely small animals or insects, which the NPS lists among animals with eyeshine |
Tip: In daylight, pace off 23 m (25 yards) and 91 m (100 yards) from your tent and pick a landmark at each, such as a boulder or the fire ring on the next site. At night, eyeshine short of that landmark is inside the distance Yellowstone asks you to keep.
Safety note: If the eyes come toward you, stop scanning. Yellowstone's safety page says: "If an animal moves closer to you, back away to maintain a safe distance."
A spotlight on full output, swept across a campground, puts hundreds to thousands of times more light on a tent than a full moon does. On full output, the Marauder Mini 2 would put an estimated 622 lux on a tent 15 m away, about 3,100 times a bright full moon. Even its 100-lumen spotlight level lands about 230 times full moonlight there.
The moonlight benchmark comes from a paper in the journal Astronomy & Geophysics: Kyba, Mohar and Posch wrote in How bright is moonlight? that "most full Moons at mid-latitudes will produce only 0.05–0.2 lux." This guide uses 0.2 lux, so the multiples are the smallest they could be.
This table estimates the light on a surface 15 m away, an example distance to the next site, and 23 m, Yellowstone's 25-yard minimum for elk and bison. Figures are based on Olight's rated candela and lumens, not measured.
| Light and setting | Estimated candela | Lux at 15 m | Times full moon (0.2 lux) | Lux at 23 m | Times full moon |
| Marauder Mini 2, spotlight 1,350 lm | 140,000 | 622 | 3,111 | 265 | 1,323 |
| Marauder Mini 2, spotlight 100 lm | 10,370 | 46.1 | 230 | 19.6 | 98 |
| Marauder Mini 2, spotlight moonlight 0.5 lm | 51.9 | 0.23 | 1.2 | 0.10 | 0.5 |
| Warrior X 4, 2,600 lm | 99,310 | 441 | 2,207 | 188 | 939 |
| Warrior X 4, Regular Low 300 lm | 11,459 | 50.9 | 255 | 21.7 | 108 |
| Seeker 4 Pro, Turbo 4,600 lm | 16,895 | 75.1 | 375 | 31.9 | 160 |
| Seeker 4 Pro, Low 50 lm | 184 | 0.82 | 4.1 | 0.35 | 1.7 |
The math: lux = candela ÷ distance squared, so 140,000 ÷ 15² = 140,000 ÷ 225 = 622 lux, and 622 ÷ 0.2 = 3,111. Lower settings scale candela by their share of peak lumens: 140,000 × 100 ÷ 1,350 = 10,370 cd. That assumes the beam keeps its shape when dimmed, which Olight doesn't publish. Olight lists 140,000 cd for the whole light; this guide assigns it to the 1,350-lumen spotlight rated for 750 m.
The lesson is aim, not lumens: a focused 100-lumen spotlight lands about 46 lux on a tent 15 m away, while the Seeker 4 Pro's wide 50-lumen Low lands under 1 lux.
The NPS camp etiquette page asks campers to "Keep lights shielded and pointing down," and notes that "Quiet hours are posted in most campgrounds, typically for a range of time (such as 10 p.m. - 6 a.m.)." Treat quiet hours as spotlight-off hours, face away from tents before you switch on, and sweep outward from camp.
Warning: Never point a spotlight at people or at a vehicle on a road. The Marauder Mini 2 manual carries the caution "Do not stare at operating light source," and a dazzled driver can't see the road.
In national parks, looking at wildlife with a light can be illegal. Under 36 CFR 2.2(e), a superintendent may close all or part of a park to viewing wildlife with an artificial light, and using a light that way in a closed area is prohibited. Zion National Park's current compendium closes the whole park. A separate paragraph bans frightening wildlife.
The federal text is 36 CFR 2.2. Paragraph (e) reads: "The Superintendent may designate all or portions of a park area as closed to the viewing of wildlife with an artificial light. Use of an artificial light for purposes of viewing wildlife in closed areas is prohibited." Paragraph (a)(2) prohibits "The feeding, touching, teasing, frightening or intentional disturbing of wildlife nesting, breeding or other activities."
Zion's 2026 Superintendent's Compendium states: "The park is closed to the use of artificial light for purposes of viewing wildlife." Its justification: "Spotlighting may potentially disturb wildlife; this activity is prohibited to minimize this chance of disturbance." The NPS article Animals Need the Dark adds that artificial light can "interfere with the vision, foraging, and dispersal activities of many mammals."
This table turns those texts into what to do with a camp spotlight.
| Official source | What it says | What to do with your spotlight |
| 36 CFR 2.2(e) | Superintendents may close areas to viewing wildlife with an artificial light | Check the park's compendium for a closure before the trip |
| Zion 2026 compendium | Whole park closed to artificial light for viewing wildlife | Light paths and hazards, not animals |
| 36 CFR 2.2(a)(2) | Prohibits frightening or intentionally disturbing wildlife | Never use turbo or strobe to chase an animal off |
| Yellowstone safety page | 100 yards (91 m) from bears, wolves and cougars; 25 yards (23 m) from other animals | Use reach to keep distance, not to close it |
Outside national parks, state law decides what counts as spotlighting. Our guide to hunting with a light laws compares state rules; check your state wildlife agency's current regulations before you shine a field.
Two myths drive bad spotlight choices at camp: that a brighter beam drives off a bear, and that rated beam distance is how far you can identify things. Park guidance names distance and bear spray for bears, not light, and the rated distance is where the beam falls to roughly moonlight level.
- "A bright enough light will scare off a bear." Yellowstone's bear guidance is about distance, groups and spray: "Bear spray is a non-lethal tool specifically designed to deter bears as a last line of defense." It assigns no role to a flashlight.
- "Rated beam distance is how far I can see." Streamlight's summary of the ANSI FL 1-2009 standard defines beam distance as "The distance from the device at which the light beam is 0.25 lux," about bright full-moon level. At 750 m you may see eyeshine, not identify the animal.
- "Eyeshine color tells you the species." The Indiana Department of Natural Resources says it varies with the animal, your distance and your light.
Every figure here comes from Olight's published ratings, an official agency page or a stated formula; none comes from measurement. This table shows each input and method so you can redo the math with any light.
| Figure | Input and source | Method | Limits |
| Specs and runtimes | Olight US product pages and manuals, September 2026 | Copied as published | Manuals cite FL 1-2009 or FL 1-2019 |
| Scorecard | Beam distance, lowest setting, weight, manual features | Four criteria, 25 points each | Equal weights |
| Lux on a tent or animal | Rated candela; 15 m example; 23 m from Yellowstone | Candela ÷ distance² | Beam center, clear air |
| Candela at lower settings | Peak candela and lumens | Candela × setting lm ÷ peak lm | Assumes beam shape holds |
| Full-moon multiple | Kyba, Mohar and Posch, 0.05 to 0.2 lux | Lux ÷ 0.2 | Conservative |
Before you pack the best spotlight for camping, set it up at home so the first click at camp is a dim one. Most spotlight trouble comes from settings nobody changed, a flat battery or a park rule nobody read.
- Pick for your walk. Car or lakeshore site: Marauder Mini 2. Walk-in site: Seeker 4 Pro. Reach only, beside a headlamp: Warrior X 4.
- Practice the unlock. Rotate the Marauder Mini 2's button more than 60°, or the Seeker 4 Pro's switch more than 90°. Both lock themselves about 10 seconds after you switch off.
- Learn the lowest setting in the dark. Once unlocked, press and hold the Marauder Mini 2's button for Moonlight; on the Seeker 4 Pro, hold the switch for 1 second from off.
- Charge and pack the cable. The Marauder Mini 2 manual notes the MCC3 "is not included in the package," so bring the USB-C wrist-strap cable.
- Read the park compendium for a 36 CFR 2.2(e) closure, and keep the light out of a hot car: both manuals list a 0 to 40°C working temperature.
