Olight makes the lights recommended here. Olight specs and regular prices come from its US product pages and user manuals as of September 2026. The watt-hour budgets and charging counts below are our own arithmetic from published numbers, not measurements.
The best van life lights for most people living in a small van are three portable lights: an Olight Oclip 2 Pro clip light for the galley and bed, a Sphere Ambient Light for low glow, and a Perun 3 headlamp for outside chores. We compared five Olight lights on published specs. The Oclip 2 Pro wins because one 75.5 g light clips, sticks, tilts and dims to 1 lumen.
A van has little floor, and every light needs a place to ride on travel days. Buy too many and they rattle in a drawer; buy the wrong kind and you cook with a phone in your teeth and read by a ceiling light that wakes your partner. This guide gives each job one light and shows what the set costs in power and plug-ins.
This table sums up the best van life lights by job, with Olight's ratings and regular prices as of September 2026.
| Job in the van | Recommended model | Key specs (Olight ratings) | Regular price | Why |
| Best overall: galley counter and bed | Olight Oclip 2 Pro | Flood 530 lm max; Medium 100 lm for 3 h 45 min; Moon 1 lm for 144 h; red 4 lm for 27 h; IP66; 75.5 g | $54.99 (Tidal Blue); $49.99 (Black, Orange) | Clips, sticks to steel, tilts 115° |
| Low glow for the dinette or bed | Olight Sphere Ambient Light (Sphere C) | White 75~22 lm; white low 1 lm for 40 h; red low 0.5 lm for 25 h; IP56; 93 g | $17.99 | 360° glow, magnetic base |
| Outside: water, tires, dog walks | Olight Perun 3 | Med 120 lm for 25 h; Low 30 lm for 89 h; red 15 lm for 70 h; IP68; 150 g | $89.99 | Hands-free, 18 Wh battery |
| A second reading light for a partner | Olight Oclip Pro S | 600 lm max; Low 10 lm for 27 h; Moon 1 lm for 144 h; IPX6; 53 g | $39.99 | Lightest clip light, USB-C |
| Reach past the campsite (optional) | Olight Seeker 4 Pro | 4,600 lm; 16,895 cd; 260 m; Med 300 lm for 11 h; IPX8; 205 g | $139.99 | Only light with 260 m reach |
- 1. Quick Answer: How Many Lights Does a Van Actually Need?
- 2. What Type of Lighting Is Best for a Campervan?
- 3. Best Lighting for Van Life: Galley, Bed, Outside, and Storage Needs
- 4. Best Van Life Lights for 2026 by Job
- 5. Camping Van Lights Compared: Brightness, Beam, Mount, Weight and Size
- 6. How Much Power Do Van Lights Use Each Day?
- 7. How Often Will You Plug In Each Van Light?
- 8. Do Magnetic Lights Work in a Van? Magnets, Clips and Stands
- 9. Space Is Limited: Which Van Lights Should You Choose?
- 10. Heat and Cold: Where Should Van Lights Live?
- 11. Common Mistake: One Type of Light for the Whole Van
- 12. Which Brand of LED Lights Are the Best?
- 13. What Are the Most Reliable Vans for Vanlife?
- 14. How the Numbers in This Guide Were Worked Out
- 15. Your Van Lighting Setup Checklist
- 16. FAQ
Most vans need three portable lights, four at most: one clip light that works on the galley counter and at the bed, one low-glow light for the evening, and one headlamp for chores outside. Add a long-reach flashlight only if you park on unlit land. Choose rechargeable lights, keep them on USB where you can, and give each one a fixed home.
To browse further, see Olight's outdoor and camping lights and its Oclip clip lights. This guide is for small vans. If you travel in a larger rig, our best RV camping lights guide builds a family kit around a headlamp for each adult, which is why its overall pick differs from this one.
The best lighting for a campervan is battery-powered LED: rechargeable portable lights, built-in 12 V LED fixtures, or both. Never use a fuel lantern inside the van. The Consumer Product Safety Commission says, "Never use fuel-burning portable heaters or lanterns while sleeping in enclosed areas such as tents, campers and vehicles."
That line comes from the CPSC's page on portable heaters and camping equipment, which adds that the rule "is especially important at high altitudes, where the risk of carbon monoxide poisoning is increased."
The CDC's carbon monoxide basics page explains why: "CO is found in fumes produced any time you burn fuel in cars or trucks, small engines, stoves, lanterns, grills, fireplaces, gas ranges, or furnaces." It also gives a rule for the van itself: "Have a mechanic check the exhaust system of your car or truck every year. A small leak in the exhaust system can lead to a buildup of CO inside the car."
Warning: The CPSC's rule names vehicles: no fuel-burning portable heaters or lanterns while you sleep in the van. Carbon monoxide is colorless and odorless, so use battery lights inside.
Van life lighting has four jobs. The galley needs about 100 lumens aimed at the counter. The bed needs 1 to 10 lumens for reading and a red mode for night trips. Outside needs a hands-free light for 10 to 30 minutes of chores. Storage needs a dim light for finding things under the bed. Each job has its own mount problem in a van.
This framework matches each van job with the mode and mount that suit it, based on Olight's rated modes and listed mounting features.
| Van job | Light and mode (Olight rating) | How it mounts in a van |
| Cooking at the galley | Oclip 2 Pro flood Medium 100 lm | Clipped to a strap or grab handle, head tilted down |
| Dinette glow after dinner | Sphere C white high 75~22 lm | Magnetic base on bare steel, or on a shelf |
| Reading in bed | Oclip 2 Pro flood Low 10 lm or Moon 1 lm | Clipped to a curtain tie, aimed at the page |
| Getting up at 3 a.m. | Oclip 2 Pro red Low 4 lm, or Sphere C red low 0.5 lm | Left in place by the bed |
| Filling water, checking tires, walking the dog | Perun 3 Med 120 lm on the headband | Worn, or stuck to a steel wheel arch |
| Under-bed storage and the garage | Oclip 2 Pro Low 10 lm or Sphere C white low 1 lm | Clipped to the bin edge or set on the floor |
The Oclip 2 Pro appears in four of six rows because its clip, magnets and tilt solve the van's mount problem. Every inside job runs at 100 lumens or less.
The best van life lights for 2026 split the work by job: the Oclip 2 Pro as the everyday light for the galley and the bed, the Sphere Ambient Light for glow, the Perun 3 for outside chores, the Oclip Pro S as a second bed light, and the Seeker 4 Pro only for campsites where you need reach. Each pick below names its limit.
Olight Oclip 2 Pro: Best Overall Van Life Light
The hard part of van lighting is placement: paneled walls, a curved ceiling, a shallow counter. For the Olight Oclip 2 Pro clip light, Olight says "The clip grips objects up to 14 mm thick, including collars, straps, and MOLLE webbing," and "Tail and clip magnets turn it into a magnetic work light." The head tilts 115° and the clip rotates 360°.
Its floodlight runs Medium 100 lumens for 3 hours 45 minutes, Low 10 lumens for 25 hours and Moon 1 lumen for 144 hours. Red Low runs 4 lumens for 27 hours, and a spotlight reaches 125 m. Tidal Blue is $54.99 (regular price, September 2026); Black and Orange are $49.99. Premium versions add a 1,000 mAh Mobile Charging Dock that Olight says gives "twice the total runtime."
The limits: the Oclip 2 user manual says, "Do not immerse the product in water or other liquids, as it will damage the product," so keep it clear of the sink. And 14 mm is thinner than a 3/4-inch (19 mm) plywood bed platform, so clip it to webbing, not to the bed edge.
Olight Sphere Ambient Light: Best for Low Glow in the Dinette or Bed
The hard part of evening light in a van is glare: every bare emitter sits within arm's reach of your face. The Olight Sphere Ambient Light spreads light through a transparent shell with a "360-degree light-emitting surface design," and Olight notes "The strong magnet at the base still lets you stick it to metal surfaces."
The Sphere C is rated at 75~22 lumens for 100 + 150 minutes on white high, 1 lumen for 40 hours on white low and 0.5 lumens for 25 hours on red low. It costs $17.99 (regular price, September 2026).
The limits: 75 lumens is glow, not a cooking light, and Olight states, "The purchase of Sphere C will not include a USB-C cable."
Olight Perun 3: Best for Outside Chores
The hard part outside a van is that both hands are busy with a jug, a hose or a leash. The Olight Perun 3 headlamp ships with a headband, magnetic tail, clip and lanyard, so it rides on your head at the spigot or sticks to a wheel arch.
It runs Med 120 lumens for 25 hours, Low 30 lumens for 89 hours and red at 15 lumens for 70 hours, and holds the kit's largest battery at 18 Wh. It costs $89.99 (regular price, September 2026).
The limits: 150 g, and its MCC3 cable needs a USB Type-A port (5 V, 2 A), per its manual. For lighter options, see our best camping headlamp guide.
Olight Oclip Pro S: Best Second Light for a Partner
The hard part of sharing a van bed is two reading schedules. The Olight Oclip Pro S clip light weighs 53 g and charges by USB-C in about 1.5 hours, according to its manual. It runs 10 lumens for 27 hours on Low, 1 lumen for 144 hours on Moon and red at 4 lumens for 26 hours. It costs $39.99 in Black (regular price, September 2026).
The limits: it is rated IPX6, and its manual says, "Do not immerse the product in water or other liquids, as it will damage the product." Its 365 nm UV mode needs care: don't look into the UV emitter, and avoid skin and eye exposure.
Olight Seeker 4 Pro: Optional Reach for Dark Campsites
The hard part on unlit public land is seeing what is 100 m away. The Olight Seeker 4 Pro flashlight is rated at 4,600 lumens and 260 m, charges by USB-C through its holster and costs $139.99 (regular price, September 2026).
The limits: 205 g and no job inside the van; skip it if you park in campgrounds and towns.
On paper, the five van lights span 75 to 4,600 lumens and 53 to 205 g. For inside the van, the numbers that matter are the lowest mode, the mount and the size: the Oclip 2 Pro and Oclip Pro S both reach 1 lumen and clip on, while the Sphere C gives the widest glow. The Perun 3 and Seeker 4 Pro earn their weight outside.
This table compares all five van lights on Olight's published ratings and regular prices as of September 2026.
| Model | Max output | Peak intensity | Beam distance | Lowest white mode | Weight | Size (Olight) | Water rating | Mount | Regular price |
| Oclip 2 Pro | 530 lm (flood) | 3,906 cd | 125 m | 1 lm, 144 h | 75.5 g | 60.2 × 28 × approx. 35 mm | IP66 | Clip (14 mm), tail and clip magnets | $49.99 to $54.99 |
| Sphere C | 75 lm | Not listed | Not listed | 1 lm, 40 h | 93 g | 60 mm diameter, 54.5 mm tall | IP56 | Magnetic base | $17.99 |
| Perun 3 | 3,000 lm | 6,400 cd | 160 m | 5 lm, 20 days | 150 g | 116.8 mm long, 28 mm head | IP68 | Headband, magnetic tail, clip | $89.99 |
| Oclip Pro S | 600 lm | 1,600 cd | 80 m | 1 lm, 144 h | 53 g | 57 × 28 × 27 mm | IPX6 | Clip, magnet | $39.99 |
| Seeker 4 Pro | 4,600 lm | 16,895 cd | 260 m | 5 lm, 15 days | 205 g | 133 mm long, 28 mm body | IPX8 | Holster | $139.99 |
A typical evening with the USB-C galley, bed and glow lights uses about 1.9 watt-hours of battery energy, based on Olight's rated battery sizes and runtimes, not measured. That is roughly 13.6 Wh a week, less than the 18 Wh in one Perun 3 battery. The ambient glow uses the most because it runs the longest.
The method: the Oclip 2 manual lists 2.22 Wh, and the Sphere C spec lists 3.7 V and 700 mAh, so 3.7 × 0.7 = 2.59 Wh. Battery energy ÷ rated runtime gives average drain per hour, assuming the full rated capacity is usable.
This table converts van-relevant modes into average battery drain per hour, based on Olight's rated battery capacities and runtimes, not measured.
| Light and mode (Olight rating) | Battery | Rated runtime | Average drain per hour of use |
| Oclip 2 Pro, flood Medium 100 lm | 2.22 Wh | 3 h 45 min | 2.22 ÷ 3.75 = 0.59 Wh |
| Oclip 2 Pro, flood Low 10 lm | 2.22 Wh | 25 h | 2.22 ÷ 25 = 0.089 Wh |
| Oclip 2 Pro, red Low 4 lm | 2.22 Wh | 27 h | 2.22 ÷ 27 = 0.082 Wh |
| Sphere C, white high 75~22 lm | 2.59 Wh | 100 + 150 min | 2.59 ÷ 4.17 = 0.62 Wh |
| Sphere C, white low 1 lm | 2.59 Wh | 40 h | 2.59 ÷ 40 = 0.065 Wh |
| Sphere C, red low 0.5 lm | 2.59 Wh | 25 h | 2.59 ÷ 25 = 0.10 Wh |
One surprise: the Sphere C's 0.5-lumen red low (0.10 Wh per hour) drains faster than its 1-lumen white low (0.065 Wh). Red is for your eyes, not your battery.
This table builds one example evening for a solo traveler, based on Olight's rated figures, not measured; swap in your own hours.
| Task | Light and mode | Time | Battery used |
| Cooking and dishes | Oclip 2 Pro, flood Medium | 1 h | 0.59 Wh |
| Reading in bed | Oclip 2 Pro, flood Low | 1 h | 0.089 Wh |
| Night trip outside | Oclip 2 Pro, red Low | 10 min | 0.014 Wh |
| Dinette glow | Sphere C, white high | 2 h | 1.24 Wh |
| Total per evening | About 1.94 Wh |
The sum is 0.59 + 0.089 + 0.014 + 1.24 = 1.94 Wh per evening, or 1.94 × 7 = 13.6 Wh per week. The Perun 3 is counted as a share of its charge instead: 20 minutes of chores on Med is 20 min ÷ 25 h = 1.3% of a full charge. Charging losses mean your power bank gives up more, so treat these as a planning scale.
In the example evening, you would plug in about 5.6 times a week: the Sphere C every 2.1 days, the Oclip 2 Pro every 3.2 days and the Perun 3 about every 75 days. Two changes cut that to about 3 plug-ins a week: run the Sphere on high for one hour instead of two, and buy the Oclip 2 Pro Premium with its charging dock.
Plug-ins matter more than watt-hours in a van. Days per charge is battery energy ÷ daily use: Oclip 2 Pro 2.22 ÷ (0.59 + 0.089 + 0.014) = 3.2 days; Sphere C 2.59 ÷ 1.24 = 2.1 days; Perun 3 25 h ÷ 20 min = 75 days.
This table shows weekly USB charging events before and after the two changes, based on Olight's rated figures, not measured.
| Light | Daily use (example) | Days per charge | Plug-ins per week | After the two changes |
| Oclip 2 Pro | 0.69 Wh | 3.2 | 2.2 | About 1.1 (Premium dock, "twice the total runtime") |
| Sphere C | 1.24 Wh | 2.1 | 3.4 | 1.9 (1 h high + 1 h white low = 0.69 Wh a day) |
| Perun 3 | 20 min on Med | 75 | 0.1 | 0.1 |
| Total | 5.6 | About 3.0 |
With the Premium dock, you charge the dock while you drive and let it top up the light in the evening. For solar and cloudy-day charging, our comparison of rechargeable camping lights and solar lanterns covers the tradeoffs.
Tip: Put every USB-C light on one multi-port charger in a fixed spot. The Sphere C manual recommends "a USB adapter with a power output of 5W (DC 5V 1A) or higher," and says a weaker source can make charging take longer.
Magnetic lights work in a van only where there is bare steel: door frames, pillars, wheel arches and uncovered roof ribs. Once the walls are paneled in plywood or covered in felt, a magnet has nothing to grip. That is why a clip matters as much as a magnet.
Check each surface before you rely on it:
- Bare steel: hold a fridge magnet there first. The Oclip 2 Pro's tail and clip magnets, the Perun 3's magnetic tail and the Sphere C's base all need it.
- Plywood or felt walls: add a strap, loop or hook, then clip the Oclip 2 Pro or Oclip Pro S to it.
- A 3/4-inch (19 mm) bed platform: it is wider than the Oclip 2 Pro's 14 mm clip, so clip to a cargo strap or curtain tie instead.
- Counters and shelves: stand the Sphere C on its base behind a lip or on a non-slip mat for travel days.
Looking for a magnetic light with a stand? Olight's $9.99 Charging Dock Holster for the Oclip 2 series lets you "attach it to steel surfaces with its magnetic base." For a light that stands on a counter, use the Sphere C.
Safety note: The Oclip 2 manual says, "If you have an ICD or pacemaker, avoid close or prolonged contact with this product to prevent possible interference." Don't clip a magnetic light to your chest pocket if you have an implant.
When space is limited, choose by the number of people and the jobs, not by brightness. A solo traveler needs two lights, adding a headlamp only for regular outside chores. A couple adds a second clip light for the bed. Stop when each job has a light, because every extra light needs a mount, a cable and a place to ride.
Use these build rules, with totals at Olight regular prices in September 2026 (using the $49.99 Black Oclip 2 Pro):
- Two-light minimum, solo: Oclip 2 Pro + Sphere C. $49.99 + $17.99 = $67.98. The Oclip 2 Pro doubles as the outside light on its spotlight.
- Solo with daily outside chores or a dog: add the Perun 3. $67.98 + $89.99 = $157.97.
- Couple: add the Oclip Pro S for the second reading light. $157.97 + $39.99 = $197.96.
- Unlit public land: add the Seeker 4 Pro only if you check the area around the van most nights. $197.96 + $139.99 = $337.95.
For bigger rigs with lanterns on picnic tables, our RV camping lantern guide covers hanging heights and table light.
Van lights should live and charge in the shaded living space, never on the dash or in a window line. Their manuals set hard limits: the Oclip 2 must not be placed, charged or used where a car may pass 60 °C, and the Oclip 2 Pro and Oclip Pro S cannot charge below 0 °C. NHTSA adds that parking in the shade does little to cool a closed vehicle.
The manual limits are specific. The Oclip 2 manual says, "Do not place, charge, or use this light in a car or other environment where the temperature may exceed 60°C," and that it "cannot be charged in environments below 0°C or above 45°C." The Sphere C manual says not to store it in a car above 60 °C and that above 40 °C "it may fail to charge the product." The Oclip Pro S cannot charge below 0 °C or above 50 °C, and the Perun 3 manual lists a working temperature of 0-40°C.
NHTSA's heatstroke campaign page says, "Rolling windows down or parking in the shade does little to change the interior temperature of the vehicle." The U.S. Fire Administration's battery safety page is direct: "Don't put lithium-ion batteries in direct sunlight or keep them in hot cars. This is a fire risk." It also says, "Do not charge them at temperatures below 32 degrees F (0 degrees C) or above 105 degrees F (40 degrees C)." Our best flashlight for overlanding guide shows how fast a closed cab passes these limits.
Note: Before you leave the van in sun, move lights and power banks into a shaded cabinet low in the van.
A frequent van lighting mistake is buying one type of light for every job: a string of fairy lights, a single headlamp, or a big lantern. Each fails somewhere. Fairy lights do not light a cutting board. A headlamp blinds whoever you turn toward in a space this narrow. A big lantern has no place to hang and rolls on travel days.
The fix is the four-job split above: a clip light for tasks and a diffuse light such as the Sphere C for glow.
No single brand is best for every van. Judge brands by what they publish: runtimes for every mode measured to the ANSI/PLATO FL 1 standard, battery capacity, an IP water rating, a mode at 1 lumen or less, a common charging port and temperature limits in the manual. A brand that publishes all six lets you plan a watt-hour budget like the one above.
The U.S. Department of Energy's LED Basics page says, "Good-quality white LED lighting products are expected to have a useful life of 30,000 to 50,000 hours or even longer." So the battery and seals usually decide a portable light's life, not the LED. For warranty and support comparisons, see our guide to the best flashlight brands.
We found no government ranking of vans for van life reliability, and survey rankings change every model year. The practical test is the specific van: check its recall history by VIN, read the owner complaints for its year, make and model, and have the exhaust checked every year before you sleep in it.
NHTSA's recall lookup explains that a VIN search shows "if a specific vehicle needs to be repaired as part of a recall," while a search by "year, make and model" returns "general results for recalls, investigations, complaints and manufacturer communications." NHTSA advises: "Register your vehicle, tires, car seats & equipment and check recalls twice a year."
Every Olight number here is copied from its US product page or user manual, and every calculation is shown next to its result. Nothing was measured. The table lists the source, basis and count behind each figure, so you can redo it with a calculator.
This method table lists each measure, its source, the basis used and how many times it was applied.
| Measure | Source | Basis | Count |
| Output, reach, runtimes | Olight product pages and manuals | Olight ratings; manuals cite FL 1-2019 (current: FL 1-2025) | 5 lights |
| Battery energy | Manuals and specs | Oclip 2 as listed; Sphere C 3.7 V × 0.7 Ah | 2 lights |
| Drain per hour | Wh ÷ rated runtime | Full capacity, even draw | 6 modes |
| Evening budget, plug-ins | Drain × example hours; Perun 3 as minutes ÷ runtime | One example evening | 4 tasks, 3 lights |
| Temperature limits | Manuals; USFA | Quoted from source text | 4 lights |
| Prices | Olight US store | Regular price, September 28, 2026 | 5 lights |
Set up your van lights in one evening at home before the trip. This checklist turns the best van life lights above into a working system, with a job, a mount, a charging slot and a travel spot for each light.
- Start with two lights: an Oclip 2 Pro for the galley and bed, and a Sphere C for glow. Add the Perun 3 only if you do outside chores most nights.
- Mount by surface: test steel with a fridge magnet, add straps or loops on paneled walls, and remember the 14 mm clip limit.
- Set the modes: 100 lumens for cooking, 10 or less for reading, red for night trips.
- Build one charging station: a multi-port USB charger, a USB-C cable for the Sphere C, and a USB-A port for the Perun 3.
- Store it cool: off the dash and out of the sun, and no charging above 40 °C (104 °F) or below freezing.
- Lock lights for travel: the Oclip 2 manual says, "If the product is carried or transported, please lock it."
- Keep fuel lights out: no fuel lanterns or heaters inside, and a yearly exhaust check for the van.
