Olight makes some of the lights discussed here. Olight specs and prices come from its product pages as of September 2026; field rules come from each field's published rulebook, linked where they appear.
A tactical flashlight for airsoft is a rail-mounted or handheld light that lets you see into dark rooms and night fields. Your field's rulebook decides what you can run, so check its lumen cap, strobe rule and laser rule first. Then pick a light under that cap with a usable low mode and a mount that locks tight to your rail.
This quick table sums up the five checks that decide whether a light works for airsoft.
| What to check | Why it matters | Rule of thumb |
| Field lumen cap | Some fields ban lights above a set output | Published caps we found range from 1,300 to 2,000 lumens |
| Strobe rule | Some fields ban strobe outright | Choose a light with no strobe, or one that lets you switch strobe off |
| Laser rule | Many fields ban or restrict lasers | Skip light and laser combos unless your field allows them |
| Rail type | Airsoft rails copy real-steel profiles, but fit varies | Confirm Picatinny, M-LOK or pistol rail, then check for wobble |
| Low mode and runtime | Indoors, full output bounces back into your eyes | A low mode of 100 to 300 lumens covers most indoor rooms |
Most players learn the rules the hard way. You buy a bright light, bring it to a new indoor arena and hear at the safety briefing that strobes are banned and lasers stay in the car. Or the light fits your rail at home and then walks forward a slot after an hour of gas blowback recoil. Others blast a white hallway at full power and lose their own vision to the glare. The sections below deal with each of those problems, using published field rules and Olight's official specs.
- 1. What Is the Best Airsoft Flashlight?
- 2. Airsoft Field Rules on Lumens, Strobe and Lasers
- 3. Airsoft Rails vs Real Firearm Rails: Will a Weapon Light Fit?
- 4. How Many Lumens Do You Need for Airsoft CQB?
- 5. Olight Lights for Airsoft Compared
- 6. Will Your Light Last a Night Game?
- 7. Common Airsoft Flashlight Myths
- 8. Is It Legal to Have a Tactical Flashlight?
- 9. Eye Protection and Carrying Airsoft Guns in Public
- 10. Is 500 FPS Allowed in Airsoft?
- 11. Tactical Flashlight for Airsoft Setup Checklist
- 12. FAQ
The best airsoft flashlight is one your field allows, with output under the posted lumen cap, no strobe or a strobe you can disable, and no laser if lasers are banned. After that, look for a low mode between 100 and 300 lumens, momentary activation and a clamp that locks onto your rail without play. Brand and peak lumens come last.
A light that breaks a field rule stays in your gear bag no matter how good it is. A light that follows the rules still has to suit the fight you play. Indoor CQB rewards a wide beam and a low mode. Outdoor night games at larger fields reward reach, which comes from candela rather than lumens.
This table explains each spec you will see on a light's box, the unit it uses, a typical range for weapon lights and how to judge whether it is enough for airsoft.
| Spec | Unit | Typical range on weapon lights | How to judge it for airsoft |
| Maximum output | Lumens (lm) | 500 to 1,500 lm | Must sit under your field's cap; more is not better indoors |
| Low mode | Lumens (lm) | 100 to 300 lm | The mode you will use most in rooms and hallways |
| Peak beam intensity | Candela (cd) | 4,000 to 16,000 cd | Higher candela reaches farther outdoors; less important indoors |
| Beam distance | Meters or feet | 130 to 250 m | Useful for outdoor night games; overkill for a warehouse |
| Runtime | Minutes or hours | 40 minutes to 5 hours depending on mode | Must cover your game length at the mode you actually use |
| Weight | Ounces or grams | 3 to 7 oz | Adds up at the end of a long barrel over a full day |
| Activation | Tail switch, rear paddles or remote pad | Varies | Momentary-on lets you light and release fast |
| Strobe and laser | Yes or no | Varies | Must match your field's rules |
Lumens measure total light out of the head. Candela measures the brightest point of the beam, and beam distance follows from it. If those terms are new to you, the Olight guide to candela vs lumens vs lux explains how the three connect.
Tip: Ask the field whether it counts a light's maximum rated output against the cap. Most published rules name a single lumen number, so the safe reading is the highest output your light can produce, not the mode you plan to use.
Airsoft field rules on lights differ from one field to the next. Among the rulebooks below, Nashville Airsoft caps flashlights at 1,300 lumens, Tacticool Extreme Sports caps them at 1,500 lumens and bans strobe, and American Airsoft Club's guidelines ban lasers and lights over 2,000 lumens. Always read your own field's rules before you buy.
There is no national rulebook for airsoft lights in the US. Each field writes its own, and rules change without notice. This table collects the light and laser clauses from published rulebooks, checked on September 24, 2026.
| Field (rulebook) | Lumen rule | Strobe rule | Laser rule | Night play note |
| Nashville Airsoft arena rules (indoor, Nashville, TN) | "All flashlights must be 1300 lumens or less" | Not stated | Not stated | Not stated |
| Tacticool Extreme Sports rules (indoor) | "Flashlights max 1500 lumens" | "cannot use strobe functions in the game" | Red or green lasers for marking and pointing only; "They cannot be used for aiming" | Flashlights are mandatory at night games |
| American Airsoft Club guidelines | Flashlights over 2,000 lumens not allowed | Not stated | Lasers not allowed | Not stated |
| SQAirsoft (Escue Airsoft) rules | Not stated | Not stated | Red lasers only, under 5 mW, no IR; "Do not point lasers at anyone's eyes" | Red, orange or pink light or glow stick required as a dead rag |
| SS Airsoft rules (Flowery Branch, GA) | Not stated | Not stated | "Do not point lasers above the neck"; the face includes the face mask | Not stated |
| Power Ops Airsoft rules (Madison, GA) | Not stated | Not stated | "Lasers are allowed for night games only" | "Flashlights are allowed" |
Read the table as a sample, not a national picture. Two patterns stand out. Lumen caps, where a field posts one, sit between 1,300 and 2,000 lumens. Laser rules are stricter than light rules, and they range from full bans to color, power and aiming limits. Strobe rules are less often written down, but some fields ban strobe outright. Outside the US, Scorpion Airsoft's site rules in the UK state plainly: "No lasers are permitted" and "No Strobe Lights are permitted."
Use this four-step routine before you buy or bring a light to a new field.
- Find the written rules. Look for a "Rules," "Field Rules" or "Safety" page on the field's site, then check the date it was updated.
- Search for four words. Lumens, strobe, laser and flashlight. If a rule is missing, it is not the same as permission.
- Ask before game day. Message the field with your exact model and its maximum lumens, and keep the reply.
- Listen at the safety briefing. Referees can change rules for night games or special events, and the briefing wins over the website.
Note: Field rules change often. Treat every rule quoted here as a snapshot from September 2026, and follow the current rules and staff calls at your field.
Most real-steel weapon lights fit airsoft guns, because airsoft replicas copy real rail profiles such as Picatinny (MIL-STD-1913), M-LOK and pistol accessory rails. The catch is fit. The Picatinny profile sets a slot width of 0.206 in and slot spacing of 0.394 in, and a replica rail can be cut looser or tighter than that. Always check for play after mounting.
The MIL-STD-1913 standard sets a locking slot width of 0.206 in (5.23 mm), slot centers every 0.394 in (10.01 mm) and a slot depth of 0.118 in (3.00 mm). The older Weaver rail uses narrower, rounded slots. That is why an accessory made for a Weaver rail will usually fit a Picatinny rail, while a Picatinny accessory may not fit a Weaver rail.
This table compares the rail types you will meet on airsoft guns and what each means for mounting a light.
| Rail type | Where you see it | What the light needs | Common airsoft fit issue |
| Picatinny (MIL-STD-1913) | Rifle handguards, top rails, some pistols | A clamp with a recoil lug sized for 0.206 in slots | Slots cut loose or rounded, so the lug rocks |
| Weaver-style | Older or budget replicas | A mount that accepts narrower slots | A Picatinny lug may not drop into the slot |
| M-LOK | Modern rifle handguards | M-LOK T-nuts and screws, or a mount with them | Thin replica handguards can flex under torque |
| Pistol accessory rail (Glock-style) | Pistol frames | A pistol light with the right insert or cross-bar | Short replica rails leave little room for the cross-bar |
What changes on an airsoft gun is how the parts are made. A real-steel rail is machined to carry a light through repeated recoil. An airsoft rail only needs to hold accessories through gas blowback or an AEG's vibration, and makers cut them with different care. You cannot see the difference until the light is on the gun.
Use this mounting checklist on any airsoft rail.
- Measure a slot. Calipers across one slot should read close to 0.206 in for Picatinny. A clearly wider slot means the recoil lug will rock.
- Seat the lug forward. Push the light toward the muzzle before tightening, so the lug bears on the front wall of the slot.
- Tighten to the maker's spec. Use the wrench in the box, and add a witness mark with a paint pen across the clamp and rail.
- Twist and pull. With the gun unloaded and the magazine out, try to rock the light by hand. Any click or play means a rail problem.
- Recheck after the first game. If the paint mark has moved, the rail or clamp is not holding.
Warning: Airsoft fields ban real firearms on the field, and Nashville Airsoft's rules state "Real weapons are not permitted during any game." If you move one light between a real firearm and an airsoft gun, remount and recheck it every time, and never bring a real firearm to an airsoft field.
For more on mount types, see the Olight guide to rail mounts for tactical flashlights.
For airsoft CQB, 100 to 300 lumens lights a typical room or hallway, and a maximum of 800 to 1,300 lumens covers larger warehouse spaces while staying under most published caps. The number matters less than a low mode. Up close, a bright hotspot on a white wall reflects back into your eyes, so the dimmer setting often shows you more.
The physics is simple. Illuminance in lux equals candela divided by distance in meters squared. A light that reaches far outdoors puts a very bright spot on a wall a few feet away, and pale walls reflect much of that light back at you.
This table works that formula out for three Olight lights at full output and at their low mode. Low-mode candela is estimated by scaling peak candela by the lumen ratio, which assumes the beam shape stays the same; Olight does not publish low-mode candela.
| Distance | Odin Mini high (14,400 cd) | Odin Mini low (about 2,304 cd) | Odin S high (15,600 cd) | Odin S low (about 3,120 cd) | Baldr S high (4,400 cd) | Baldr S low (about 550 cd) |
| 1 m (3.3 ft) | 14,400 lux | 2,304 lux | 15,600 lux | 3,120 lux | 4,400 lux | 550 lux |
| 3 m (10 ft) | 1,600 lux | 256 lux | 1,733 lux | 347 lux | 489 lux | 61 lux |
| 5 m (16 ft) | 576 lux | 92 lux | 624 lux | 125 lux | 176 lux | 22 lux |
| 10 m (33 ft) | 144 lux | 23 lux | 156 lux | 31 lux | 44 lux | 6 lux |
Two things follow from the table. First, the low modes still put tens to hundreds of lux on a spot 16 feet away. That is far above the 0.25 lux that the ANSI/PLATO FL 1 standard uses to define a flashlight's beam distance, which Safariland's guide to the FL 1 standard describes as "roughly the brightness of full moonlight." Second, switching the Odin Mini from 1,250 to 200 lumens cuts the hotspot by 84 percent. On the Odin S, dropping from 1,500 to 300 lumens cuts it by 80 percent.
You can check the arithmetic against Olight's own numbers. The square root of 14,400 divided by 0.25 is 240, and Olight lists the Odin Mini's beam distance as 240 m. The Odin S works out to about 250 m, which matches its listed 820 ft (250 m).
Here is how that plays out in three common spots.
- White hallway, 10 feet long. Use low. At full output the wall at the end glows so bright that you lose detail in the corners near you.
- Dark warehouse bay, 30 to 50 feet deep. Full output earns its keep here. Light in short bursts, then release.
- Stairwell or small room. Point the beam at the floor a few feet ahead so spill light fills the room without a hotspot on the wall.
Safety note: Your goggles protect you from BBs, not glare. Keep the beam off other players' faces at close range, and follow any field rule on where lights may point.
If you want a feel for how bright a given lumen number looks, the Olight guide on how bright 2000 lumens is walks from 10 to 10,000 lumens with everyday comparisons.
Among Olight's rail lights, the Odin Mini is the easiest pick for airsoft: its 1,250 lumens fits under every lumen cap in the field table above, and it has no strobe and no laser. The Odin S adds reach and a strobe you can switch off, and the PL-3R Valkyrie is the laser-free pistol option. Both are rated at 1,500 lumens, which exceeds Nashville Airsoft's 1,300-lumen cap.
This table lists Olight's official specs and prices, checked September 24, 2026, alongside how each light lines up with the field rules above.
| Spec (Olight) | Odin Mini | Odin S | PL-3R Valkyrie | Baldr S |
| Max output | 1,250 lumens | 1,500 lumens | 1,500 lumens | 800 lumens |
| Output levels | High 1,250~900~700~200 lumens; Low 200 lumens | High 1,500~650~300 lumens (included battery); Low 300 lumens | High 1: 1,500~600~300 lumens; High 2: 1,000~600~300 lumens; Low 300 lumens | High 800~300 lumens; Low 100 lumens |
| Peak intensity | 14,400 candela | 15,600 candela | 10,200 candela | 4,400 candela |
| Beam distance | 787 ft (240 m) | 820 ft (250 m) | 672 ft (205 m) | 426 ft (130 m) |
| Weight | 6.21 oz (176 g) with battery | 6.81 oz (193 g) with battery | 3.77 oz (107 g) with battery | 3.35 oz (95 g) |
| Length | 4.55 in (115.5 mm) | 5.02 in (127.5 mm) | 3.19 in (81 mm) | 2.48 in (63 mm) |
| Rail | M-LOK mount included; Picatinny with the optional Pic Rail Adapter | M-LOK or Picatinny edition | Sliding key-block; 1913 adapter included | Glock insert installed; Picatinny insert included |
| Strobe | No | Yes, can be enabled or disabled | Yes, 13 Hz at 1,500 / 1,000 lumens | No |
| Laser | No | No | No | Yes, green or blue |
| Waterproof | IPX8 | IPX8 | IPX6 | IPX4 |
| Under a 1,300 lm cap (Nashville) | Yes | No | No, rated 1,500 lm | Yes, but check the laser rule |
| Under a 1,500 lm cap with no strobe (TES) | Yes | Yes, with strobe disabled | Yes, if you never trigger strobe | Green version only; laser for marking, never aiming |
| Where lasers are banned (American Airsoft Club) | Yes | Yes | Yes | No |
| Regular price | $139.95 | $149.99 | $99.99 | $129.95 |
Olight Odin Mini for most indoor and mixed fields. The hard part of airsoft lighting is staying legal at every field you visit. The Odin Mini's 1,250-lumen maximum sits under each published cap in the table, it has no strobe mode, and it carries no laser. Its 200-lumen low mode is the one you will use most indoors, and Olight rates that mode at 5 hours. The package includes an M-LOK mount, a ROD-7 magnetic remote switch and a pressure switch mount, and the tail switch also works for handheld use. The limits: Picatinny rails need the optional Pic Rail Adapter, which is not in the box, and at 4.55 in long it is a rifle light, not a pistol light. The product page showed a sale price of $97.96 on September 24, 2026, against the $139.95 regular price.
Olight Odin S rail light for outdoor night games. Big outdoor fields need reach, and the Odin S has the highest candela here at 15,600 cd. Olight says its strobe can be turned on or off: press the tail or remote switch five or more times and hold the last press for over one second. That lets you disable strobe for fields that ban it. It also runs on its 18650 battery or two CR123A cells, which matters when your rechargeable dies mid-event. On CR123A cells Olight lists high as 1000~550~300 lumens, but the light is still rated at 1,500 lumens, and that rating is the number a field will ask about. The limits: its 1,500-lumen maximum is over Nashville Airsoft's cap and right at the Tacticool Extreme Sports cap, so it is not the light for every indoor arena. On September 24, 2026, the M-LOK Matte Black edition was in stock, while the Picatinny Matte Black and M-LOK Desert Tan editions were listed as sold out.
Olight PL-3R Valkyrie rail light for pistols at laser-free fields. A pistol rail leaves little room, and a laser-free field still expects you to see into dark rooms. The PL-3R Valkyrie is a 3.19 in, 3.77 oz light with no laser, a sliding key-block for rail fit and a 1913 adapter in the box. A setting switch picks High 1 at 1,500 lumens or High 2 at 1,000 lumens, and its 300-lumen low mode runs 100 minutes. It also works with the optional sRPL-7 magnetic remote pressure switch for rifle-size builds. The limits: its 1,500-lumen rating is over Nashville Airsoft's cap even with High 2 selected, unless the field agrees to judge the setting you run. Its strobe flashes at 13 Hz, inside the 3 to 30 Hz range the Epilepsy Society lists as common seizure triggers. The product page does not describe a strobe lockout, so never trigger strobe at a field that bans it. Its IPX6 rating is also below the Odin lights' IPX8. The regular price is $99.99; on September 24, 2026, the page showed $69.99 for a bundle with an sRPL-7 switch.
Olight Baldr S: a laser light, so check first. The Baldr S is a compact pistol light at 3.35 oz, with 800 lumens, a 100-lumen low mode and no strobe. It fits Glock-style rails with the insert already installed, and a Picatinny insert comes in the package. Every version pairs the white light with a laser: green on the Baldr S, blue on the Baldr S BL. That rules it out where lasers are banned. SQAirsoft allows only red lasers, and Tacticool Extreme Sports allows only red or green lasers for marking, so the blue version is out at both. It suits players whose fields allow visible lasers under clear rules. If your field bans lasers, choose the PL-3R Valkyrie above or another light from Olight's PL series weapon lights.
For more mounted options, browse Olight's rail mount lights.
A light will last a night game if its runtime at the mode you actually use covers the time it is on, not the length of the whole game. In short bursts, even a small battery goes a long way. For example, a light that is on 10 percent of a 3-hour game only runs 18 minutes in total.
Olight lists runtime for each mode as a sequence of steps. The Odin Mini's high mode reads "6 + 11 + 39 + 14 minutes," which means 6 minutes at 1,250 lumens, then 11 minutes at 900, 39 at 700 and 14 at 200. This table turns the listed runtimes into total minutes and compares them with an assumed 3-hour night game.
| Light and mode (Olight) | Listed runtime | Total minutes | Share of a 3-hour game if left on | Time on at 10% use in a 3-hour game |
| Odin Mini high | 6 + 11 + 39 + 14 minutes | 70 | 39% | 18 min, covered |
| Odin Mini low (200 lm) | 5 hours | 300 | 167% | 18 min, covered |
| Odin S high, included battery | 3.5 + 110 + 18 minutes | 131.5 | 73% | 18 min, covered |
| Odin S low, included battery (300 lm) | 5 hours 10 minutes | 310 | 172% | 18 min, covered |
| Odin S high, CR123A | 10 + 45 + 26 minutes | 81 | 45% | 18 min, covered |
| PL-3R Valkyrie High 1 | 2 + 36 + 8.5 minutes | 46.5 | 26% | 18 min, covered |
| PL-3R Valkyrie low (300 lm) | 100 minutes | 100 | 56% | 18 min, covered |
| Baldr S high, laser off | 1 + 2 + 37 minutes | 40 | 22% | 18 min, covered |
| Baldr S low, laser off (100 lm) | 140 minutes | 140 | 78% | 18 min, covered |
The takeaway: runtime rarely ends a game if you use momentary bursts. It does matter if you leave the light on while walking between objectives. For that, carry a small handheld or headlamp, and save the weapon light for rooms.
A remote pressure switch also makes short bursts easier, because you can light and release without shifting your grip. The Olight guide to the remote pressure switch for a tactical flashlight explains how remote switches work.
Tip: Charge the night before, not the morning of. Olight's runtime figures assume a full charge, so a light that sat in your bag since the last event will not match the table.
The most common airsoft flashlight myth is that a laser light is fine at a laser-free field as long as you never switch the laser on. Fields that list lasers as not allowed equipment ban the device, not just its use, and a referee cannot tell at a glance whether it is off. If your field bans lasers, bring a light without one.
This table pairs common myths with the facts and the source behind each.
| Myth | Fact | Basis |
| "I just won't turn the laser on." | Some fields list lasers under equipment that is not allowed at all | American Airsoft Club guidelines |
| "More lumens always wins." | Up close, a bright hotspot washes out your own view; a low mode often shows more | Lux arithmetic in the CQB section above |
| "If the rules don't mention strobe, anything goes." | Some fields ban strobe outright, and briefings can add rules | Tacticool Extreme Sports rules; Scorpion Airsoft site rules |
| "Strobe is harmless in a game." | About 3% of people with epilepsy have photosensitive epilepsy, and 3 to 30 flashes per second are common trigger rates | Epilepsy Society |
| "Any light that says Picatinny will lock on." | Replica rails vary; slot width and lug fit decide it | MIL-STD-1913 dimensions |
| "A low-power laser is always safe." | Federal laser rules treat Class IIIa output as an eye hazard when viewed directly | 21 CFR 1040.10 (FDA) |
The strobe point deserves weight. The Epilepsy Society's guide to photosensitive epilepsy says that "Between 3-30 hertz (flashes per second) are the common rates to trigger seizures," and that most people who develop it are between 7 and 19 years old. Many fields welcome players from age 10, so a strobe ban protects real players.
On lasers, the FDA's performance standard for laser products, 21 CFR 1040.10, says Class IIIa levels "are considered to be, depending upon the irradiance, either an acute intrabeam viewing hazard or chronic viewing hazard." That is why fields that allow lasers still ban aiming them at faces.
Warning: Never point a laser at anyone's eyes, including through goggles, and never point any laser at the sky. Avoid eye exposure to the beam at all times.
Yes, it is legal to own a tactical flashlight in the US, with or without a rail mount. The legal limits apply to lasers and to how you use a light. Pointing a laser at an aircraft is a federal crime, and the FAA can fine violators up to $32,646 per violation. Airsoft fields set their own light rules on top of the law.
The FAA's laser safety initiative states: "Pointing a laser at an aircraft is a federal crime." Pilots reported 10,993 laser strikes to the FAA in 2025. A rail light with a built-in laser falls under the same rules when you take it outside the field, so keep lasers pointed down and off when you walk to and from outdoor games.
The same FDA standard requires each Class II, III and IV laser product to state its maximum output on the warning label. Before you bring a laser to a field that allows one, read that label. SQAirsoft, for example, allows only red lasers under 5 mW. Olight lists the Baldr S BL's blue laser as Class IIIa with an output under 5 mW.
Lights also answer to local rules on where and how you use them. A bright light is not illegal, but shining one at drivers, neighbors or people outside a game can lead to complaints or local charges. Use your light only on the field.
Every field rulebook in this guide requires eye protection, and most demand full-seal goggles rated to ANSI Z87.1+ that stay on the whole time you are on the field. Off the field, keep your airsoft gun cased and out of sight. US-market airsoft guns carry orange tips for a reason, and some states make showing a replica in public an offense.
This table sums up eye protection clauses from the same rulebooks.
| Field | Eye protection rule |
| Ballahack Airsoft | Fully sealed, "rated to resist impacts (ANSI Z87 +)," with retention; mesh goggles not allowed unless worn over other eye protection |
| Power Ops Airsoft | "Full seal eye protection goggles (ANSI rated lensed) are required, along with full-face protection" |
| American Airsoft Club | "Full seal ANSI Z87+ eye protection and adequate face protection that protects your mouth are both mandatory" |
| SQAirsoft | Eye protection "must be ANZI 87.1+ rated"; this field allows mesh eye pro |
Ballahack Airsoft's ruleset also sets age-based face protection, so check the rules for younger players. Players under 18 should play with a parent or guardian who knows the field's age rules.
Carrying a replica in public is a separate matter. Federal rules for toy, look-alike and imitation firearms list approved markings in 15 CFR 272.3, including "a blaze orange ... solid plug permanently affixed to the muzzle end of the barrel." States add their own laws. In California, Penal Code section 20170 says: "No person may openly display or expose any imitation firearm in a public place." The same section defines a public place to include a parking lot and an automobile, whether moving or not, so a replica on your passenger seat or in the field's lot can count.
Follow these habits from your car to the field and back.
- Keep the gun in a case or bag until you reach the field's staging area.
- Remove the magazine and fit a barrel sock or bag before you leave the playing area.
- Leave the orange tip in place.
- Check your state and city laws on imitation firearms, since they vary widely.
500 FPS is not allowed for general play at the fields in this guide, and it is far above indoor CQB limits. A 0.20 g BB at 500 FPS carries about 2.32 joules, while the general limits here run from 1.23 to 1.55 joules. Some outdoor fields allow higher energy only in DMR or sniper classes that come with a minimum engagement distance (MED).
Muzzle energy in joules equals half the BB's mass times its speed squared, which is why fields now write limits in joules and name the BB weight. This table lists published limits and converts each to a common basis.
| Field | Published general limit | Energy or equivalent speed | Higher class, if any |
| Nashville Airsoft (indoor) | AEG and GBB 1.55 joules on .20 g | About 408 FPS on .20 g | HPA 1.35 joules on .28 g |
| Amped Airsoft Arena (Pittsburgh, indoor) | Under 1.23 joules or 365 FPS with .20 g | About 1.24 joules at 365 FPS on .20 g | Not listed |
| Palm Beach Airsoft | 380 FPS with .20 g | About 1.34 joules | Not listed |
| Power Ops Airsoft (outdoor) | 1.50 joules; 359 FPS (.25 g), 401 FPS (.20 g) | 1.50 joules | DMR 366 to 460 FPS (.25 g), 2.5 joules, 50 ft MED, semi-auto only; sniper 460 to 550 FPS (.25 g), 3.5 joules, 100 ft MED |
| Ballahack Airsoft | Under 400 FPS with .20 g or 1.49 joules | 1.49 joules | Tiers up to 2.81 joules (measured with .40 g), 75 ft MED |
A 500 FPS gun on 0.20 g BBs, at 2.32 joules, is over every general limit here. At that energy it could only play in a higher class, such as Power Ops' 2.5-joule DMR class (semi-auto, 50-foot MED) or Ballahack's 2.81-joule tier (75-foot MED). On 0.25 g BBs the same speed means about 2.90 joules, which fits Power Ops' 3.5-joule sniper class with its 100-foot MED and the class rules that come with it.
To set up a tactical flashlight for airsoft, start with the field's rules, then match the light, mount and settings to them. Confirm the lumen cap, strobe rule and laser rule. Mount the light tight, mark the clamp and set up momentary activation. Practice using the low mode, and charge before every game.
Run through this list before your next game.
- Read your field's current rules for lumens, strobe, lasers and night play, and ask about anything missing.
- Pick a light whose maximum output is under the cap, with no laser if lasers are banned.
- Disable strobe if the light allows it, or choose a light without one.
- Measure your rail, seat the recoil lug forward, tighten and paint a witness mark.
- Route any remote switch cable tight to the handguard.
- Practice lighting in short bursts, and use the low mode in rooms.
- Charge the light the night before, and pack a red or orange dead light for night games.
- Wear full-seal ANSI Z87.1+ goggles, and keep your gun cased off the field.
- September 21, 2026: First published. Olight specs, prices and field rules checked September 24, 2026.
